Old 04-21-2014, 12:49 AM   #1
Oroville , California
How to detach hitch
I purchased my first airstream this week. Also first time towing a vehicle. I can't remove the hitch from the ball. I pulled what appears to be a locking mechanism as much as I could. I'm on fairly level ground. When I jack up the airstream, the back of my truck raises too.
What are the dos and donts that I should follow?
What other facts are needed? Photos?
David95966 is offline   Reply With Quote
Old 04-21-2014, 01:44 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The coupler latch slides forward a bit then up. You may have to jack slightly to get pressure off the ball before
The coupler latch slides forward toward the truck 1/4-1/2", then straight up.
There may be a pin through the hole which will have to be removed before the latch will move. You may have to jack up slightly to get pressure/weight off before you can release the coupler.
When hitching up you will know it is latched because the holes for the pin will line up. When it is light I will take pictures and post.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-21-2014, 03:39 PM   #3
Photos
Here are some photos. Am I not level enough? Is the jack in the wrong place? What else do I need to know.
Not planning on driving this around. Just using it as an extra room.
Old 04-21-2014, 04:50 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Some coupler cups are kind of dished out on the front. When you jack up the trailer, the ball is trapped by the cup and doesn't drop out On my trailer, I found that if I left the truck free to move a bit, it would disconnect easily. I leave the brake off on the truck and even put it in neutral, depending on the slope. Or back up a tad after blocking the trailer wheels.
John W. Irwin
WBCCI #9632
Old 04-21-2014, 04:59 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
jumping on the back bumper is usually enough to kick it loose
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-21-2014, 05:11 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If the coupler is the original Marvel coupler it is 41 years old. If it has not been used much recently it may be dried out or rusty. Soak the coupler with a good WD 40 spray and try the mechanism a couple of times
Old 04-21-2014, 05:58 PM   #7
It off
I got it off. Moved the car an inch. Thanks for the replies. Renews some of my lost faith in humanity.
Old 04-21-2014, 10:15 PM   #8
JFScheck's Avatar
Rockville , Maryland
Images: 33
Try it a few times and grease up that ball while lubeing that coupler!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-22-2014, 12:27 AM   #9
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I was going to guess same thing, your tow vehicle was still pulling on it. Always be very careful around that hitch when you are unhooking, it can fall or jump when you aren't expecting and you or someone else gets hurt. Saw that happen just recently with an experienced camper, the tow vehicle was still pulling or pushing on the trailer, the trailer fell and broke the block under the jack. Lucky no one was in the way.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
