Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-12-2007, 09:42 AM   #1
Tin Diesel
30' 1999 Excella
Tin Diesel's Avatar
Profile:  Kingwood , Texas
How steep is too steep?
We have an opportunity to boondock this summer in a fabulous place in Colorado. Access is via a driveway that is 900' long. There are a couple of 100' intervals on this driveway that have a grade of 15-18% (maybe as much as 20%). No issues with turn radius or anything.
We have a 30' Classic (1999) towed by a 4x4 Ford F250 Diesel. We can go up/down as slowly as we want.
Questions:
1. assuming good road surface, any issues with this combination getting up a grade this steep? (the road is packed gravel, not asphalt, but its brand new)
2. any concerns about gray/black/fresh water tanks? Should they be emptied before going up/down? This is not just a weight issue - we don't want black water spilling out from the toilet seal!!!!
Thanks.
Here's our rig, and our destination!!!
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 02-12-2007, 09:46 AM   #2
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
Having traveled on some roads with slopes in the range you describe, traction will be your most critical issue. The worse condition would be loose gravel. If surfaces are firm and tight, no problems.
2002 Toyota Tundra
Why is it Levee's built by volunteers with sand bags hold better than Levee's built as directed by the Corps of Engineers with millions of taxpayer dollars?
Bob Thompson is offline   Reply With Quote
Old 02-12-2007, 10:04 AM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Do you have Enkay Rock Tamers mounted on your hitch to cut down throwing gravel? They're a good idea for all around use.
Old 02-12-2007, 10:10 AM   #4
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Cann't imagine you don't have the power if your traction hold.
I am wondering in such a situation which would give you more tractions.
1) No WD, let the full weight go to the rear wheels and use 2 wheel drive.
or
2) WD with 4 wheel drive.
How is your truck setup. If one of the rear wheels spins are you dead in the water or will the other still have traction?
Let those who can play, let those who cann't rule.
Over59 is online now   Reply With Quote
Old 02-12-2007, 10:18 AM   #5
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Loss of traction would be a big problem. If the truck slides you may not be able to stop. going backwards. I would try the truck only first.
Do you have limited slip rear end?
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 02-12-2007, 10:51 AM   #6
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Give 'er hell and keep the 4wd on.
Ditto the mudflap comments....
I think you'd be fine. Loose gravel, ok, as long as you don't loose momentum. It's not the safest thing to do, but going by the photos, it doesn't look **that** bad....then again, looks can be deceiving.....
Old 02-12-2007, 11:06 AM   #7
Tin Diesel
30' 1999 Excella
Tin Diesel's Avatar
limited slip
we have limited slip, and have already been up the driveway in the contractor's F250. Even a 2-wheel drive would be fine without a trailer. We're just worried about 'spilling' stuff and whether this is just too steep. I know the Ford has the power!
Oh yeah - yes we have Enkay's.
Old 02-12-2007, 11:39 AM   #8
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
I don't see a problem.
4Wd at a slowish constant speed and you're there. Don't stop until you reach the top.
Airstreams handle really well off pavement. Even in deep sand. So don't worry.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is online now   Reply With Quote
Old 02-12-2007, 11:48 AM   #9
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
With a good surface, I wouldn't worry about going up.
Going down, however, may just scare the bejeesus out of you.
pmclemore is offline   Reply With Quote
Old 02-12-2007, 12:01 PM   #10
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
20% grade is "very" steep.
Compare highway grades at 6 to 8% and they can be tough to pull a heavy trailer up and on the down side they have run outs for runaway trucks.
I doubt 2 wheel drive would climb a 20 deg slope unless paved.
Garry
Old 02-12-2007, 12:01 PM   #11
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Others have touched on my thoughts:
1. On the uphill don't stop or you could find yourself in the position of not being able to go up and loosing control on the way down backwards.
2. On the way down you will have the trailer pushing you and you could loose control. Go as slow as possible.
3. This may be overkill but I guess you could rig a block and tackle or use wheel blocks for the way down. Are you a sailor, got a spare anchor?
Lumatic is online now   Reply With Quote
Old 02-12-2007, 12:05 PM   #12
Tin Diesel
30' 1999 Excella
Tin Diesel's Avatar
other trucks
I should have mentioned that construction trucks will use this road, and it was designed accordingly (big dump trucks, concrete trucks, etc.).
I should have refined my question more, but I think our biggest concern is simply the concept of 'tilting' the trailer that much. Sounds like we'll be OK.
Old 02-12-2007, 12:32 PM   #13
Bob Thompson
'97 Excella 25
Images: 60
Once, my wife failed to turn the shower off at the faucet, which left a trickle at the shower head which she had turned off. We were hooked up to city water and the shower head trickled all night. In the morning, we had 2" of water standing in the shower. Aargh! Luckily, the dump station was about 50 yards away on a level road. It was a nice slow drive to it. It would have been disastrous to drive up or down any grade to get to a dump station.
2002 Toyota Tundra
Old 02-12-2007, 12:51 PM   #14
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Another thing I would really watch is the weather. The weather here in the high country can change dramacticly from morning to evening. A road that was passable in the morning can turn into a nightmare with a little rain or snow mixed in. Alot of roads in the Colorado Mountains turn into creeks with very little rain. Be prepared to wait it out and let the roads dry before proceeding to your next distination.
Glass replacement for Corning! Forrest Windows, Doors, Locks & Vents 104 11-26-2006 10:20 AM
Road passibility - Santa Fe to Breckenridge Zed2 On The Road... 10 04-21-2006 01:29 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
Steep Grades luckydc On The Road... 18 07-27-2004 01:51 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
