Old 07-28-2012, 08:36 AM   #1
Fam-Bambi's Avatar
2012 22' FB Sport
Columbus , Indiana
How often do you check your tire pressure?
We have moved camp a lot this week and would like opinions as to "best practices" on the frequency of checking tire pressure. Also, what if you forget to take a cold reading? Can you still check after being underway? Thanks.
Shari & Greg
Fam-Bambi is offline   Reply With Quote
Old 07-28-2012, 08:47 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Once a month when the tires are cold should be good. If you are traveling a lot, you can check them each morning, before you get on the road.
Old 07-28-2012, 09:08 AM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have a PressurePro in the truck. Before every trip, I check while hooking up. It takes a minute or so for all four tires to register on the PressurePro once I back up to the trailer.
During the trip, I check each morning and every hour or so when stopped at a traffic light or on a straight stretch of highway. The pressure rises as the tires warm up, but all tires should be pretty much the same. Tires on the sun side will be a pound or two higher than the shady side.
I also carry an IR thermometer. In really hot weather, I check tire temperatures occasionally at rest stops or lunch stops. A hot bearing or a hot brake will show up on the thermometer.
John W. Irwin
WBCCI #9632
Old 07-28-2012, 09:13 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I also have a tire pressure monitoring system, And check before I head out. I have set the alarm to go off when my pressure hits 55psi. I run at 60 psi. I have read to Malay threads about tire blow out damage and figured the $260 for the monitor was cheap. It also keeps track of the tire temp.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-28-2012, 09:39 AM   #5
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
I check our tire pressure once a month or before a trip, whichever is sooner. Also check about once a week when on a trip.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-28-2012, 09:53 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I checked daily when I had GYMs (and had to add air a least once a week), now that I have Michelins, I check weekly (and rarely add air). Of course I visually check when hooking up to travel.
Wayne&Sam is online now   Reply With Quote
Old 07-28-2012, 09:54 AM   #7
Pahaska's Avatar
Hays County , Texas
To me, once a week just doesn't do the trick. Even once a day can be chancy.
On my last trip, during a atop at a rest area, I cycled the PressurePro through the tires and found a slightly low tire. I took the time to put some air in that tire and then kept watch with the PressurePro. I soon found that I had a definite leak and stopped to put on the spare (it was Sunday). When I removed the wheel, I found a nail in the tread.
The PressurePro would have signaled in plenty of time to prevent damage, but I never ran on a low tire which increased my confidence that the tire is good after repair. It also permitted me to find a safe, level place to stop to change the wheel.
This was the second time that the additional checking caught a leak well before I was running on a critically low tire.
John W. Irwin
WBCCI #9632
Old 07-28-2012, 09:59 AM   #8
Scott J-24's Avatar
Point well taken, we will reasses our process. I always do a visual check whenever we stop for gas or a rest break. But maybe TPM would be a good addition to our rig.
WBCCI #1215
Air #54601
Old 07-28-2012, 10:34 AM   #9
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Every stop...
Friday is offline   Reply With Quote
Old 07-28-2012, 11:26 AM   #10
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Visually check once a morning when traveling. Otherwise, just before we depart for a month long trip. I run 45-50 psi in my B F Goodrich Commercial T/A's. Got 85,000 miles out of the first set.
So Long!
Bob Thompson is offline   Reply With Quote
Old 07-28-2012, 11:54 AM   #11
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
The TPM was one of the best investments I've made for towing the AS.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 07-28-2012, 12:49 PM   #12
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
This is about my routine also. When I still had the ST's (Marathons and Maxxis), I was always adding air, and checking the pressure daily. I have now had the Michelin LT's for 35,000 miles. I check them occasionally, and have yet to add any air pressure. I check the tires visually at each stop.
Brian
SuEllyn & Brian McCabe
Old 07-28-2012, 02:44 PM   #13
techiej's Avatar
2011 34' Classic
Vancouver , Washington
Once per month when not in use, every morning when travelling.
techiej is offline   Reply With Quote
Old 07-28-2012, 02:58 PM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our tire pressure monitor system keeps an eye on them.
Two sets of GYMs on two trailers in three years have lost no air on their own. Corroded wheels are more likely to leak air at the beads or stems than tires, so a wheel change may be necessary along with new tires to prevent slow leaks.
doug k
