Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 08-28-2009, 02:54 PM   #1
Profile:  Currently Looking...
Payson , Arizona
How much tow weight is reasonable?
Hello all;
I am new to the forum and fairly new to towing.
I have a 2008 Ford Expedition with the tow package and the 3.31 axel, and a 9000 lb towing capability spec. I recently towed my utility trailer with 2 motorcycles for 5000 miles with no problem. Didn't have any special hitch. Weight approx 3300 lbs. Going up hills (mountains) the car would downshift and I could acheive fairly good speed, 55 mph was easy without too much trouble. Pulling out from a stop and getting up to hwy speed took a bit of time. I now want to purchase a trailer that has a dry weight of 5570 lbs and a GVW of 7350 lbs. Knowing we always carry as much as possible what are your opinions as to how the vehicle will tow with the trailer fully loaded? Should I attempt this at all? Will the rig go uphill ok?
davidceder is offline   Reply With Quote
Old 08-28-2009, 03:18 PM   #2
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Hi Davidceder,
Can only say that I just hada problem with my 2003 Expedition and its transmission....worked on for $2700 actually
My trailer weighs for towing about 76-7800 lbs. I blame the passes in the mtns....we only have 30,000 miles on the Expediton. I realize it is only a 1/2 ton....and then was made ride friendly.
Not being able or wishing to replace the Expediton....we will continue with this set up.
What should we buy? I do not want a pick up.
This "be s" my experience...good luck.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-28-2009, 03:30 PM   #3
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Your tow weight should not exceed 80% of the tow vehicle's towing ability. 7350 lbs might be cutting it a bit close. We all tend to pile a bit more on with each trip.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 08-28-2009, 03:57 PM   #4
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, David. My Navigator, fancier version of Expedition, has a tow rating of 8,900 lbs and I tow a Safari rated at 6,300 lbs. To me, this is my limit although, another 1,000 lbs would be acceptable. I would not go any higher than that with your Expedition. As for the transmission, you will need to learn how and when to manually shift your transmission while towing. This could be the making or breaking of your trans.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 08-28-2009, 05:29 PM   #5
Profile:  2007 25' Safari FB SE
Blaine , Washington
I have about the same setup as Robert but with a 2006 Expedition. We have towed all over the West, up and down a lot of mountains with no problems. However, make sure you are towing with the overdrive turned off.
John
"However beautiful the strategy, you should occasionally look at the results."
Winston Churchill.
Relentless is offline   Reply With Quote
Old 08-28-2009, 06:21 PM   #6
moosetags's Avatar
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
I think your proposed combo is doable, but you you be near your limits. To have a comfortable and safe towing situation, you should look into a quality sway control/weight distribution hitch system and trailer brake controller properly set up.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 08-28-2009, 06:22 PM   #7
Profile:  1975 29' Ambassador
Reno , Nevada
Tow ratings mean very little and the warnings you often see around here even less. That is because there is no one answer for all circumstances.
The factors include the shape of the trailer, its weight distribution and axle placement, the tow vehicle wheelbase and rear overhang to the ball, the roads you normally travel and their elevation and grades, the hitch you use, your driving habits and skills, tires and suspension, and so on.
Ratings make a good guide for start but should always be subject to what you find on the road in terms of how the rig handles. There is a tendency to fall into the 'bigger is better' ethos but that can lead to a harsh ride and its own set of problems. Just right is just enough.
As for the transmission problems: if you have adequate cooling and a proper differential ratio (and tires) and treat it right, it should hold up well. There is no inherent reason for towing to cause a premature catastrophic failure.
Old 08-28-2009, 07:13 PM   #8
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 45
Agree with mooseT and bryan. Getting the connection and other related factors right is key. If the Expy trannys were weak we would have heard a lot more about it by now and there has been no rumblings.
Old 08-31-2009, 09:57 PM   #9
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Don't forget to service the tranny and engine more frequently! When pulling loads like you are thinking about, fluid changes become critical. In fact all of the maintence becomes critical. Before towing the first time I would service the transmission.
Then driving like it has no load on it may get you into component failure also. Gradual accelerations and decellerations are what keeps your equipment lasting a long time.
When driving a rig with 20 to 25 percent of it's load (basically empty) you can get away with a lot of miscare. Step up the load to at or near capacity and what works is having everything at 100% every time. Check all fluids, tire pressures and including the trailer and this will keep your towing experience, a much better event.
This is an area that an ounce of prevention is worth a pound of cure.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Sovereign weight and Preferred tow vehicle JLD 1978 Sovereign 3 03-05-2008 02:52 PM
trailer/tow vehicle axle weight regs safari Local Regs & Licensing 2 02-15-2008 06:43 PM
Am I being reasonable? truebebeblue Trailer Values 12 11-11-2006 04:43 PM
Calculating Tow Vehicle and Trailer Weight - Woes campadk Towing, Tow Vehicles & Hitches 18 09-12-2006 08:58 PM
Do I need sway control, weight bars and a good tow vehicle? Silvertwinkie Hitches 28 07-19-2004 08:42 AM
