Old 06-06-2006, 09:19 PM   #1
1965 26' Overlander
1990 34' Excella
1975 20' Argosy 20
Upper Black Eddy , PA
How many liters?
Still searching for a tow vehicle for my '65 Overlander, dry weight about 4230 lbs. I'm looking for a van with a wheelchair lift, as a disabled family member wants to be an Airstreamer, too!
What is the minimum size engine that could do the job? I know a V8 would be needed, but, a V8 with how many liters?
Not knowing a whole lot about vans (or vehicles in general), are there models that I should avoid (i.e., 1500, 2500, 3500--or with Ford-150, 250, 350, etc.)?
Kathy
kdenault is offline   Reply With Quote
Old 06-06-2006, 09:55 PM   #2
Frank S
peoria , Illinois
Hi kdenault--A full size van makes a very good tow vehicle. I towed my 1973 27' Overlander, weighing 6400 lbs wet, for over ten years with 3/4 ton Chevy window vans, with 5.7 ltr V8, with 3.73, or 4.10 differential. Newer Chevy vans have 5.3 or 6.0 ltr V8. A wheel chair lift will add considerable weight to your van, and might only be available in a 1 ton van. To do the job you should be considering a 3/4 or 1 ton with 5.3 ltr and 4.10 diff., or 6.0 ltr and a 3.73 or 4.10 diff. You will get about the same gas mileage with any of the above, so go for the best performance which would be the largest engine, with the largest numerical diff., 4.10. You willenjoy towing your A/S with a van.--Frank S
Frank S is offline   Reply With Quote
infernal, internal condensation austin Winter Living 14 09-24-2006 09:56 AM
Refill bottles ? brunoffrance Our Community 16 03-14-2004 11:10 AM
Poll: FUEL CONSUMPTION brunoffrance On The Road... 32 02-29-2004 04:37 PM
towing Airsteams in the 1960s ??? oldvws Towing, Tow Vehicles & Hitches 35 03-27-2003 07:11 AM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
