Old 04-05-2012, 10:12 AM   #15
vanster's Avatar
1967 17' Caravel
Oakland , California
Thanks again
Hooking up the brake controller this week and a special thanks to AirHeadsRus for the youtube tip
vanster
vanster is offline   Reply With Quote
Old 04-05-2012, 10:19 AM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
P3 is the minimum acceptable. MAXBRAKE or DIRECLINK would be at the top. Yes, there is a difference that is worthwhile.
Old 04-05-2012, 10:45 AM   #17
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
......and don't forget the emergency brake for whenever your tow might select a different 'route'.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-06-2012, 10:10 AM   #18
vanster's Avatar
1967 17' Caravel
E Brake? Is this to be used for "bootleg turns"?
Old 04-06-2012, 12:57 PM   #19
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
Break Away Kit
vanster,
You are on course to install a proportional brake controller, such as Tekonsha Prodigy 2 (or 3) or similar. This applies the electric actuated trailer brakes when the TV brakes are applied, in proportion to the deceleration of the TV.
A necessary part of the system is a kill switch (sometimes called a "break away kit") which will apply full trailer brakes in the unlikely event your hitch fails and the trailer becomes disconnected from the TV. On my '07 Bambi, this switch came from the factory as standard equipment. It is a switch (in a little box on near the tongue) which is hard-wired between the battery and the brakes. A plastic "pin" is inserted in the box to keep the switch normally open (no brakes applied). A safety wire (non-electrical) is looped through the hitch receiver on the TV. If the trailer departs the TV, this safety cable yanks the pin out of the switch, and the brakes are applied.
Part of the hitch / unhitch ritual is to attach / remove this safety cable and pin. The pin is never deliberately removed from the switch for more than a brief moment, so as not to burn out the brake actuators.
Hope this helps...
Charlie
aircampr is offline   Reply With Quote
If you won the lottery... Paul Ouellette Off Topic Forum 44 11-04-2012 10:06 PM
Running the furnace in a 2011 23FB FC GettinAway 2009-2015 Flying Cloud 30 08-11-2012 06:50 AM
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
What is a Univolt? :-) aircooled4 Batteries, Univolts, Converters & Inverters 6 04-09-2012 10:49 PM
Things that go bump in the night rebelstand Tires 27 04-03-2012 06:29 PM
