Old 04-15-2019, 11:08 AM   #1
Barretta2's Avatar
2013 23' Flying Cloud
Naples , Florida
Hitch weld failure
Huge shout out of thanks to AirForum folks for posting about possible hitch weld failures. Thanks to those warnings, I just checked my massive hitch ball mount assembly. Full crack around the entire structure. In for repairs now. Thanks, everyone. Have a safe summer!
Barretta2 is offline   Reply With Quote
Old 04-15-2019, 01:06 PM   #2
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Good advice. Just because something comes from the factory doesn't mean they weeded out the bad welders before having them work on your hitch. It's a good idea to check for weld cracks from time to time.
out of sight is offline   Reply With Quote
Old 04-15-2019, 03:10 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Not just a Jeep a concern...GM also.
Go for an up-grade...many good aftermarket options.👍
Our wasn't rusted, just a wimpy round bar design.🥴
Last pic is one we replaced at the GM store🥺
ID:	338256   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-15-2019, 03:47 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Believe we are discussing the Equi-l-izer hitch head failure, but the OP did not specify. Important to inspect all. Hitch, receiver, frames and axle mounts. Inspection keeps you ahead of catastrophic failure.
This report is a surprise, because the trailer is a recent model. If the hitch was new, that makes this a bit different notice as prior head failure was quite old.
Thanks for sharing. Together we know a lot more than we do alone. Pat
PKI is online now   Reply With Quote
Old 04-15-2019, 03:52 PM   #5
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Yup! A year back I had a total failure of a 2017 Ford F-250 hitch. Ford replaced it with a Curt. Ford's were all bad.
Too much slop with the adapter and rounded out holes for the pin. Soft metal, not fixable. I believe Ford used a Reese hitch.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 04-15-2019, 03:57 PM   #6
nryn's Avatar
2019 27' Globetrotter
Chicago area , Illinois
Turk, what did a total failure look like prior to failure? Elongated pin holes? Any other symptoms?
nryn is online now   Reply With Quote
Old 04-15-2019, 04:35 PM   #7
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
The adapter that Ford uses for their hitch from 2 1/2 to 2" has elongated holes in it. It promotes the pin moving in the side holes. Mine got so bad that it was flared. The Ford dealer caught the problem and said: "I wouldn't haul with it like that". A machinist later looked at it and said it could not be fixed.
Ford corporate said that all their hitches are like that. Agreed that they were not right. They bought me a Curt hitch and had it installed. I was impressed with the size of the Curt hitch compared to the Ford.
Amazingly, the Curt hitch had slop using its adapter also! I ended up buying the 2 1/2" version of the propride stinger (no adapter required) and one of these. This device works very well.
Old 04-15-2019, 05:00 PM   #8
nryn's Avatar
Wow, that’s amazing that it flared, though I can imagine that something as heavy as a TT flopping around on a loose sleeve adapter will bend just about anything in short order. Still, surprised Ford corporate would spec such a lousy part for such an integral aspect of a truck designed to do this very thing. Glad they did the right thing for you.
I bought one of those to use with a hitch-mounted bike rack and a cargo carrier on my (then) Volvo wagon, both of which used 1.5”->2” adapters and it did indeed work well.
I bought a ProPride with my Airstream and insisted that it be set up with one of their HD 2.5” receiver bars rather than rely on a sleeve adapter. No slop, but I now know to keep checking it...
Equali-i-zer Hitch Weld Failure kscherzi Hitches, Couplers & Balls 34 01-08-2019 09:41 PM
ProPride stinger weld failure Jammer Towing, Tow Vehicles & Hitches 59 08-14-2013 10:26 PM
Ford Hitch Weld Question paiceman Hitches, Couplers & Balls 12 02-19-2013 04:56 PM
