Old 12-03-2012, 01:42 PM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Hitch Vise
Anyone here using a Hitch Vise to stabilize a sloppy shank/ drawbar?
Looks like a great idea, but does it work? The slop on my Excursion is tremendous... between the oversized receiver, and the undersized Reese drop shank it wobbles around like crazy. I'm hoping this would tighten things up.
Hitch stabilizer: no wobble, anti rattle device for hitch accessories
No association
Old 12-03-2012, 01:51 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine also has bit of excess space, but I don't seem to notice it when hooked up and towing . The Andersen WD hitch really locks everything up very tight.
MICHAEL
Old 12-03-2012, 02:26 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I use a similar one, a home build from a square-topped U-bolt with fine threads and a custom drilled piece of angle. I lock it by using two nuts on each side. It works fairly well, though the bolt tends to stretch some, requiring retightening once in a while. Perhaps the one being marketed is made with somewhat less plastic steel.
Lynn
WBCCI 21043
Old 12-03-2012, 02:30 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
I'll Let You Know...
...I just ordered one.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 12-03-2012, 02:36 PM   #5
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 57
Pictures please...
Dave
Lynn
Old 12-03-2012, 02:37 PM   #6
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Quite the opposite
Finally something to be happy about with my hitch! Until now, I had been only displeased with my hitch due to the opposite problem-- Undersized receiver and improperly bevelled square tubes on hitches. I've had the same hitch in my receiver for 7 months now because it took a few whacks with a mallet to get it in, apparently during the best temperature, and infinite whacks with hammer, heating it up, etc couldn't remove it. I eventually used a cutoff wheel in a grinder and a reciprocating saw to cut it out without damaging the receiver. Now I'm in the process of finding one with the right bevel on the edge.
So I guess you can all be happy that you don't have this problem?
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 12-03-2012, 02:53 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Mine is due on the mail tomorrow. I hope it fits my huge Reese shank.
Old 12-03-2012, 03:31 PM   #8
2011 23' Flying Cloud
Durango , Colorado
Atomic,
I was also considering that Hitch Vise. Please let us know how it works for you.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 12-03-2012, 04:15 PM   #9
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Interested here as well - please give us some feedback and photos.
Alphonse is offline   Reply With Quote
Old 12-03-2012, 04:42 PM   #10
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
Hi, I've been using the hitch-vise for over four years. It works as advertised - I fully endorse it. Here's a link to my post a while back (along with Rock Tamers which I endorse also). I do have a few photos. Use the search function to find more posts on this subject. Russ
http://www.airforums.com/forums/f469...ers-44545.html
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Old 12-03-2012, 05:39 PM   #11
masseyfarm's Avatar
Images: 57
Good pictures, thanks.
I will try to experiment with making one before I buy!!!
Dave
Old 12-03-2012, 06:02 PM   #12
1977 Argosy 24
Milltown , Wisconsin
A friend of mine made his own. He drilled a 1/2" hole in the top of the reciever, and welded a nut over the hole. Then he just ran a bolt into the nut and tightened it into the hitch shank. Cost.... Almost nothing.
ventport is offline   Reply With Quote
Old 12-03-2012, 06:44 PM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question up/down slop...
"He drilled a 1/2" hole in the top of the receiver.."
My concern also....all the "slop" is vertical when towing the boat. Without a lot of tongue weight, rig less is than 2500lbs, it gets a little nerve racking hearing the shank knocking up & down in the Reese Tow Beast V. (Using shims now that help a little)
How exactly does this thing clamp on the drawbar? Is there a shoulder that tightens against both sides?, nothing on top?
Old 12-04-2012, 12:35 AM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it seems to me that this would only help stop the rattling for those who choose to drive around with the hitch in the receiver without their trailer. Once your WD spring bars are in place you hitch is forced upward, thus no rattling. I don't have that problem; Hitch is removed when trailer is disconnected. [I don't have a boat either]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
