Old 10-16-2019, 07:36 PM   #1
Silver Spring , Maryland
Hitch Suggestions for F350 Dually Pulling Bambi 16?
We're newbies to Airstream and bumper pulling, but not to RV'ing. We are fulltimers currently residing in an Arctic Fox 32 fiver, and we plan to keep her. That said, we've been looking at used (2006 to 2016 model year) Bambi/Sport 16 coaches, with a thought towards trying more nimble traveling down south this winter than the 32 foot fifth wheel allows.
We are hoping to hear from current or previous Bambi/Sport 16 owners in this community who have experience pulling with a large dually or otherwise heavy (7k+ lbs) TV, particularly regarding suggestions for weight distribution and sway control setups. Having towed only the 12k lbs 5ver, we have no experience with bumper pull sway control rigging, and are a little confused about a compatible sway control system brand and weight ratings to mate our dually with the 16 foot Airstream.
Thanks in advance for any thoughts or resources you might suggest!
RK & Christina (Ark-n-Tina)
Silver Spring, MD
No Airstream Yet
2002 Ford F350 DRW 7.3L Powerstroke
Ark-n-Tina is offline   Reply With Quote
Old 10-16-2019, 07:45 PM   #2
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
There is absolutely no need for a weight distribution or sway control hitch for the rig you mentioned. Generally speaking if your truck weighs more than your trailer then you don't need to worry.
out of sight is offline   Reply With Quote
Old 10-16-2019, 07:49 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
A F350 dually is way past what most people would use to tow a 16'. Unless you load the bed of the truck with concrete blocks, there is pretty much no way you would *need* WD. The rear axle simply isn't going to be overload by the tongue weight of the trailer.
Anti-sway is sort of the same thing. You have a lot of truck and very little trailer. The "need" part of this will be very small.
Net result, pick anything out there (including just a ball) and it's likely to work. If you want to be super sure, get something like an Equalizer and accept that it's overkill.
uncle_bob is online now   Reply With Quote
Old 10-16-2019, 07:49 PM   #4
Long Island , New York
Welcome to the forum!
As a non-expert on towing, my lay opinion is that you would not need any additional weight distribution or sway control, with that rugged a tow vehicle. Does your 2002 F350 have its own OEM sway control? Probably not. If you don't have specific weigh-in data for each wheel [front/back] you might want to go to the CAT scales.
There may be issues with your TV shocks, tires and tire pressure, however, but this is generally above my pay grade. Your new trailer is so much lighter than the 5th wheel, that some adjustments might make sense.
FYI here are some "F-350 Dually" search results for possible posts/threads on AirForums.com, where this specific TV has been discussed:
https://www.google.com/search?q=F350...&bih=727&dpr=2
Good luck,
Peter
Old 10-16-2019, 08:48 PM   #5
2019 30' International
Pennsylvania , Pennsylvania
Just throw the bambi in the truck bed with some ratchet straps over it and you're good to go
Sorry folks, I just couldn't help myself.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 10-16-2019, 08:54 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not a terrible idea
SteveSueMac is online now   Reply With Quote
Old 10-16-2019, 09:27 PM   #7
Talking
Thanks all for the quick, informative, and humorous responses! A special note of thanks to Peter who taught me a new trick about using Google to search for items on a specific web domain. I just read about a dozen different threads that addressed in some fashion my question and reaffirmed the responses in this thread.
I'm used to throwing a couple kayaks in the bed and securing with ratchet straps. I'm gonna source some longer straps for the Bambi.
-RK
Silver Spring, MD
No Airstream Yet
Old 10-17-2019, 04:40 AM   #8
Welcome, RK. If you are using the desktop version of this site, the search function in the blue box above automatically adds "site:airforums.com" as a search term FYI. The other "Search" link in the blue menu bar is an older search function, although it does have one or two unique [and helpful IMO] features.
Peter
Old 10-17-2019, 08:26 AM   #9
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Just throw the bambi in the truck bed with some ratchet straps over it and you're good to go.
With that much truck and that tiny an AS, I was gonna say just find yourself a good piece of rope, but MajorAirHead's idea is probably better.
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 10-17-2019, 08:31 AM   #10
1972 25' Tradewind
Denver , Colorado
FWIW, with a truck that size, you might consider stepping up to a 23 in order to get dual axles. You'll still have a nimble rig, but the benefits of two axles (stability, ease of changing a tire, etc.).
Old 10-17-2019, 08:53 AM   #11
2019 22' Sport
Carlsbad , California
A friction sway bar is the most you need, is super cheap and easy to use. Anything more is a waste of time, money, and effort.
https://www.etrailer.com/Accessories...urt/17200.html
Prettygood is offline   Reply With Quote
Old 10-17-2019, 09:04 AM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
with that huge rig, WD is NOT needed.
i would still recommend sway control
waninae39 is offline   Reply With Quote
Old 10-17-2019, 10:44 AM   #13
2019 25' International
Washington , Washington, D.C.
I'm curious as to how you would use the little Bambi on your southern forays? Would they be long camping trips? Have fun!
PatLee is offline   Reply With Quote
Old 10-17-2019, 11:02 AM   #14
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Expand your search to include 19'ers. The difference in weight and towing characteristics will be small, but functionality, especially for full timing, will be significant - separate black and grey tanks, bigger dry bathroom, additional storage (kitchen drawers where the 16's refrig is, etc).
We think that there is just enough room for two in a 19.
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 10-17-2019, 11:29 AM   #15
SilverFire
2013 16' Sport
EUGENE , OR
Hitch suggestions with Bambi 16
I pull a Bambi 16 Sport with a Sprinter van loaded with a ton+ of stove inventory and use a Husky WD hitch with sway control and have been glad I had it numerous times with high wind, gusting wind, in canyons, and in the open plains, across vast spans of US.
Unpredictable, high gusting wind is dangerous. I find the WD hitch with anti-sway can make the difference of keeping a rig on the road, despite how large your TV is. I also have a Freightliner M-60 and the same applicable using my larger TV. Many of us have crossed WY, SD, NK, MT with numerous semi-trailers on their sides more times than we want to remember.
The Sport is my boondocking hotel at Off-Grid shows. I prefer double axle trailers, however, my inventory requirements limit tow capacity, especially in high wind conditions.
Name:	Off Grid CO1.jpg
SilverFire is offline   Reply With Quote
Old 10-17-2019, 11:43 AM   #16
1996 25' Excella
Tillsonburg , Ontario
Ditto on posts suggesting sway control
Short wheel base trailers can get really antsy back there. My 23 Award was sheer terror without sway control and it had dual axles.
My friend pulled his '72 Tradewinds 25' AS without either behind his GMC Dually and found it OK
JCW
JCWDCW is offline   Reply With Quote
Old 10-17-2019, 02:47 PM   #17
2017 16' Sport
Canyon Country , California
Thought about towing a couple ‘16 Bambi behind the dually? Tow just one is overkill by 5 times! Thought about bigger like 19’ or 22’? Still over kill but bigger for you. My 16’ is a starter AS for me. Will upgrade to bigger to who knows how big.
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 10-17-2019, 03:26 PM   #18
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I would look for at least the 19' Bambi if you want a small trailer.
We had a 19 and found it too cramped and decided on keeping the older 25' it was supposed to replace. A 16' would not be considered under any circumstance if I was planning to tow with a 1 ton, too many better options.
By the way, we towed our 19' on the ball with no weight distribution behind a Tundra (1/2 ton).
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 10-17-2019, 03:46 PM   #19
2015 25' FB Flying Cloud
Huntley , Illinois
350 dual. 16 ft Banbi. You may shake and bounce the bambi to pieces. We pulled a 22 sport. Expedition with equalizer. Horrible bouncing. Really. Get a little bit larger with dual wheels. 19 or 20 If you want small. seriously. You can damage that bambi with that large truck!
cegardner is offline   Reply With Quote
Old 10-17-2019, 06:11 PM   #20
2007 22' International CCD
Or consider an Airsoft system to remove some of the stiffness and vibrations from the hitch setup.
2008 Ford F350 Super Duty 4x4 King Ranch Crew Cab, Dually, 6.4L Turbo diesel engine Lucy749 Airstream Classifieds 0 01-27-2014 02:58 PM
Rough riding F350 Dually.. airbags? Airslide Tow Vehicles 43 09-29-2008 10:29 PM
Dually versus non-dually ShikariJones Tow Vehicles 29 08-27-2008 09:55 PM
Hensley Hitch and a 34' 2001 Excella & F350 jim.bailey@e Towing, Tow Vehicles & Hitches 6 04-18-2008 12:07 PM
MPG of F350 Diesel Dually??? joossens Tow Vehicles 13 06-13-2004 01:55 PM
