Old 05-07-2016, 02:11 PM   #1
Addicted to Road Trips!
Pearl54FC's Avatar
1953 21' Flying Cloud
1949 18' Trailwind
Broomfield , Colorado
Hitch on Trailer
We want to install a 2" receiver on the back of our 2014 30' FC. Question? Where and what would it be welded to??? (for a bike rack)
Pearl54FC is offline   Reply With Quote
Old 05-07-2016, 04:19 PM   #2
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Bad idea. I wanted to do the same thing. Problem is that it will cause she'll separation and 2" receiver is not strong enough to handle all the bouncing that will occur behind the axles There are lots of post on this subject here on the forum
Old 05-07-2016, 04:47 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Is that still a documented problem with modern built Airstreams? Seems it did effect the older models.
MICHAEL
Old 05-08-2016, 04:58 AM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Pearl-
We went with the specially-designed Fiamma bike rack mounted directly above the Airstream rear bumper, and close to the shell. It has Airstream-spec'd arms that also attach to the rear shell/ribs to keep it snug and not bounce or sag with the bike weight. We have our bikes everywhere we go, they load/unload very easily once you get everything adjusted, don't really get all that dirty, and the rack sort of blends in with the coach. I do prefer the rear of the coach without it (aesthetically speaking), but for practicality, it rocks.
I don't know the Airstream answer to the oft-asked "can I put a hitch on the rear bumper of my Airstream", but from the responses on AF, I'm betting it's a no. 80 lbs or more of hitch, bike rack, and bikes hanging 2' back from the bumper definitely could work on the rear end integrity given how these coaches are built. The other thing I really wonder is if you have a rear hitch what's to prevent someone (maybe not you but the next owner?) from putting a cargo rack on it and loading 300 lbs of junk for their trip? Certainly that will not be good for the rear end of the coach...........
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 05-09-2016, 06:46 AM   #5
Pearl54FC's Avatar
1949 18' Trailwind
Thank you!
I was thinking the hitch because I didn't like the idea of a permanent rack like the Fiamma. We have bumper storage where we keep the tank equipment and I wanted to take the rack off occasionally. BUT, I've decided to go with the Fiamma to avoid any rear end issues. Thanks for all responses!!!
Old 05-09-2016, 07:10 AM   #6
FCStreamer's Avatar
2014 30' Flying Cloud
https://www.strombergcarlson.com/car...-model-cc-275/
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-09-2016, 07:29 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
It is still an issue. Has to do with the relatively light weight steel frame that Airstream uses since the semi-monocoque (i.e., unibody) construction allows for a lighter frame. Most "white box" trailers use a very beefy rail-style steel frame because the "sticks & bricks" style framing above the floor offers very little structural rigidity to the entire assembly. One result of the rail frame is the ability to add a hitch for a bike rack of generator and sometime even to tow a small boat trailer (if legal in the respective jurisdiction.)
Bob Martel
WBCCI# 5766
Old 05-09-2016, 07:32 AM   #8
KSA63's Avatar
2011 28' Flying Cloud
Ramara , Ontario
We have an Arvika bike rack mounted to the rear of our FC-28, Can-Am in London Ontario installed it using a method that was engineered by them. The installation uses short pieces of Zip-Dee awning aluminum support rods drilled and fitted so that the rack is easily removed when not required.
Kevin
KSA63 is online now   Reply With Quote
Old 05-09-2016, 08:16 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the Airstream Fiamma rack and it works perfectly and is very convenient. Put the bikes back there and forget about them, they become part of the assembly.
However if we had the rear storage compartment/exterior hatch on our Airstream, I would buy the rack mentioned above from Can-Am. It can be removed easily, but more importantly can be dropped down (even with the bikes on it) for storage access.
Doug and Cheryl
Old 05-10-2016, 06:57 AM   #10
Pearl54FC's Avatar
1949 18' Trailwind
Can you post a photo? Will Can-Am ship a rack as we live in CO. Easily installed? Or custom to each rig? Thank you!
Old 05-10-2016, 07:02 AM   #11
Chelsea , Michigan
Images: 12
CanAm has a website with all the information and they will ship anywhere:
http://www.canamrv.ca/
Bob Martel
WBCCI# 5766
Old 05-10-2016, 07:49 AM   #12
KSA63's Avatar
Ramara , Ontario
I will try to take a picture and post it here, but I believe there is a great picture of the Arvika rack somewhere on these forums that someone else posted.
Try this link to Garfield's Post ... http://www.airforums.com/forums/f238...ml#post1114289
The rack can be removed by taking out the clips on the attachment points. If you remove the top two you can tip the rack back and rest it on a support. This allows you to gain access to the rear storage or to clear the window area for your emergency exit.
Kevin
Old 05-10-2016, 08:31 AM   #13
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I'm going to call Can-Am too. my FC28 has rear storage & I use the bumper for stinky slinky parts storage, so that Fiamma is not my favorite solution. A friend has a late model AS that an AS dealer put a rear receiver on that I think is affixed to the frame rails. . . just sayin'. . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 05-11-2016, 06:59 AM   #14
Pearl54FC's Avatar
1949 18' Trailwind
I saw the photo of the Arvilka on a previous post but it's installed over the propane tanks. I called the Airstream plant and Chris Burch says one of the Fiamma racks made for Airstream allows access to rear compartment and bumper storage so I ordered it. I will post if it indeed works!
« Weight | Top | Best Tires? »
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
