Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 12-25-2013, 04:50 PM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Hitch mounted on AS rear?
Has anyone mounted a hitch receiver on the rear of their AS to be able to accommodate a bike rack? The bike rack specifically made for the AS is neat, but really expensive. I already have a bike rack that I use on my P/U all the time and I could easily slide it into a rear receiver.
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 12-25-2013, 04:54 PM   #2
Retired.
. , At Large
NEVER. EVER. Either buy the factory bike rack, or leave the bikes at home.
Old 12-25-2013, 05:06 PM   #3
Never, ever, do what you propose.
To do so, will cause rear end separation, in part because of the moment arm you created.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-25-2013, 05:09 PM   #4
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Overlander,
Thanks for your pleasant and understanding reply to my query. Someday I too may achieve your forum standing. Then again, why would I want to?
Old 12-25-2013, 05:09 PM   #5
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
There has been a lot written about putting a hitch on the rear of the AS. Most if not all negative. As a result I bit the bullet and purchased the bike rack. You can save a few dollars by putting it on yourself, however, I chosed to have it dealer installed.
urnmor is offline   Reply With Quote
Old 12-25-2013, 05:10 PM   #6
dkottum's Avatar
Battle Lake , Minnesota
Airstreams have a history of the shell separating from the frame at the rear. For this reason I bit the bullet and bought the Airstream rack, which is supported not only by the frame but also by the shell structure. It's well-made, easy to use, holds the bikes firmly. I had another rack from Fiamma on the back of our VW camper and carried bikes on it all over the country with no problems. This one is working as well.
Doug and Cheryl
Old 12-25-2013, 05:40 PM   #7
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Thanks to all who responded to my question and explained to me why I should go with the AS Fianna rack. I guess I should have put the rack on Santa's list. There's always next year. Wait, birthday's coming up. Thanks again...
Cheers,
Old 12-25-2013, 06:01 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II had the spare tire mounted on the back with a 2 inch hitch mount for bikes or whatever when I bought it. I have never used a bike rack on the hitch mount. It seems very well designed with a brace that runs forward and is welded to the frame forward of the bumper and also welded to the bumper. As of now I do not see any damage or issues with it. No leaks or sagging in the rear. If it was up to me I would not have mounted the tire on the rear. There is plenty of room to mount it in front behind the propane bottles. So there is no reason for anyone to criticize me about the placement on the rear.
MICHAEL
Old 12-25-2013, 06:10 PM   #9
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Carver - you're getting great advice from everyone. Sometimes, it's passionate advice to make sure the message comes across. It's all good.
I would also suggest searching for Lynn Currie (hope that's spelled correctly) as she did a phenomenal job with basic front fork clamps inside her trailer. Search for "bike fork" and you'll eventually see something from Lynn and pictures of her solution. I haven't done it yet but will this spring.
Good luck!
Old 12-25-2013, 06:19 PM   #10
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
There is also a bike rack allowing them to be carried above your propane tanks. Not as convenient, and it may not work on all AS/tow vehicle combinations, but might be worth considering. One brand is called Arvika.
Good discussion here:
http://www.airforums.com/forums/f516...ck-104626.html
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 12-25-2013, 06:45 PM   #11
deauxrite's Avatar
2007 27' Safari FB SE
Full Timers just passing through , Arizona for a couple of weeks and then on to Utah!
Hey Carver, I notice that you drive a Pickup..I mounted a hitch receiver on the front of my truck and now my bikes ride in the front of the pickup. They get a bit of road grime and bugs, but they ride just fine up there.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 12-25-2013, 07:16 PM   #12
Retired.
. , At Large
Overlander,
Why indeed would you want to?
http://www.airforums.com/forums/f514...ack-91722.html
http://www.airforums.com/forums/f516...ack-82988.html
http://www.airforums.com/forums/f238...bi-100796.html
http://www.airforums.com/forums/f497...al-100528.html
http://www.airforums.com/forums/f336...ack-90041.html
http://www.airforums.com/forums/f238...ack-93715.html
http://www.airforums.com/forums/f227...ck-109406.html
http://www.airforums.com/forums/f42/...ck-100494.html
Old 12-25-2013, 07:29 PM   #13
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have added a hitch on the back, and also an additional cross brace on my 61 Tradewind with no problems. I carried bikes for several years and now carry an aluminum box which carries light weight but bulky items like empty water jugs and blue tanks.
I have not had any problems however it is a fairly short trailer and the frames were stouter back then than they are on some of the newer models
Conventional wisdom is don't do it.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-26-2013, 05:34 AM   #14
Mantua , Ohio
Opening a can of worms here. Can anyone produce a picture of damage to a 2000 or newer AS from a rear hitch.? Jim
Old 12-26-2013, 09:02 AM   #15
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
AS hitch
Had this type 3 hitch professionally installed by a hitch/welding shop in AZ as part of the deal when we bought our '09 20' FC. Use the Stowaway carrier (waterproof..Thule, Yakima not) for barbecue stuff, hoses and other accessories we don't want to carry inside the trailer or the back of our short-bed F-150. Super convenient since we mostly back-in at campgrounds. Been to Alaska and back with it and over some difficult terrain in north central Washington State. Never a glitch. Easy access to the water hatch and small rear storage compartment. Tail lights, turn signals and now license plate holder added.
Name:	airstream behind.jpg
jkinglet is offline   Reply With Quote
