Old 09-10-2014, 04:51 PM   #15
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Originally Posted by FlyinNitwits View Post
We just bought a 2015 Flying Cloud 23FB and are about to buy a 2012 or 2014 VW Touareg TDi. We live in Vancouver, BC so will be dealing with mountains on our travels.
What hitch is best for us?
Do we need an equalizer and if so, what would people advise?
The Touareg is the way to go if we don't want a truck, right? Mercedes suspension seems to count the ML 350 out and we heard its tongue weight max is too low.
Our 2011 Touareg TDI works just fine with an Equal-I-Zer brand hitch.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 09-10-2014, 05:17 PM   #16
jcl
Vancouver , British Columbia
Do you have a device you can recommend, Jeff? Do you think it essential?
Sorry, imprecise language. They were supplied by the vehicle manufacturer and integrated into the vehicle in my case, Ford or BMW or whoever. Those companies did not generally develop them themselves, they bought them from their suppliers like Bosch and Continental, the effect of which is that each vehicle manufacturer offers systems with slightly different names that are very similar in function.
jcl is offline   Reply With Quote
Old 09-10-2014, 05:42 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Antique Pedaler, is your Touareg hitch receiver reinforced?
Doug and Cheryl
Old 09-10-2014, 06:20 PM   #18
2015 23' FB Flying Cloud
Our local hitch company has just recommended a Reese High Performance Trunnion system, which is apparently WD, sway control and self-centering. Cdn $925 installed.
FlyinNitwits is offline   Reply With Quote
Old 09-10-2014, 06:44 PM   #19
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
The new Touaregs have a fairly robust hitch interface (not sure what they use to be)...4 huge bolts/side into the unibody. However, the "CANAM reenforcement" spreads the WD "lift" across a much larger area and not just the extreme rear attachment points. Can you do without it, probably.....unit you can't . Is it better with? Yes.
"borrowed from Club Touareg forum"
cory_can is offline   Reply With Quote
Old 09-10-2014, 07:18 PM   #20
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Yes but that bar hanging under the bathtub muffler seriously reduces your ground clearance. If you really think you want to add the bracing, remove the muffler and reroute the exhaust. That configuration is just plain ugly.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-10-2014, 07:27 PM   #21
cory_can's Avatar
2015 30' Classic
Calgary , Alberta
I agree, the routing of the reenforcement with factory mufflers isn't ideal. I've seen a few Tourareg's at CanAM and noticed it immediately.
Old 09-11-2014, 08:08 AM   #22
1964 17' Bambi II
Laramie , Wyoming
Images: 11
No. But if I ever get to Ontario I'll do it.
Antique Pedaler
Old 09-11-2014, 08:50 AM   #23
dkottum's Avatar
Thanks. Any problems or advice towing the 25' FC with your Touareg? I like this combination, and I could get rid of a pickup and a car.
Doug and Cheryl
Old 02-28-2018, 03:08 PM   #24
Centerville , Ohio
I have a Can Am reinforced hitch (Under the tank) on my 2013 Treg TDI. I'm planning on getting a Equal-I-Zer WDH. I'm pulling a Rockwood Mini Lite 21', 4,451 GVWR. Can AM recommends an EAZ Lift, but I've been told you have to disconnect it before backing. Not so the Equal-I-Zer. Any thoghts?
TBDub is offline   Reply With Quote
Old 02-28-2018, 03:29 PM   #25
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
You don't have to disconnect the Eaz-Lift, just remove the friction sway bars if doing a sharp turn in reverse.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 02-28-2018, 03:32 PM   #26
2007 27' International CCD FB
San Diego , California
Sorry, but the pictures above of the factory tow hitch sure does not look robust to me. With the factory manuals specifically precluding the use of WD hitches...yet owners are deciding for themselves that this is okay???
There are vehicles that offer both load carrying and weight distribution hitch receiver types for the same vehicle. Both are built way more robust than the picture of factory touareg receiver. Yet, if one were to compare load carrying and WD type receiver hitches side by side, it's becomes obvious why WD hitches are what they are. Generally because they have a significant lever arm component to accommodate the leverage loads that WD applies. Which is similar to what CanAM adds in its reinforcement.
No way would I tow a significant load with the factory receiver only. Maybe with the CanAM mod.
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
2010 Touareg TDI to tow a 2012 25' Flying Cloud... transform Hitches, Couplers & Balls 22 09-12-2014 09:42 AM
Towing Question- 2012 Touareg TDI- Airstreams in general or 2011 Flying Cloud 23fb Roger L Towing, Tow Vehicles & Hitches 21 05-17-2014 07:32 AM
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
Touareg 2 V6 TDI CLK Tow Vehicles 18 07-03-2011 09:47 PM
