Old 08-06-2017, 04:27 AM   #15
2000 30' Excella
Toledo , Ohio
Originally Posted by dcasr View Post
__________
If you go to a 2.5" shank be sure that your ball hitch body that bolts to the shank can accommodate the wider shank. My hitch ball body that fits to either side of the shank and the bolts pass through all of it would not accommodate a wider 2.5 shank....I'd have to buy a ball body for the wider shank....so I'm happy with the adapter.
The 2 1/2" shank drop is machined to 2" at least the one I have is .
woodfox45 is offline   Reply With Quote
Old 08-06-2017, 05:14 AM   #16
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by GMFL View Post
That's my worry with the 2 1/2". It being very heavy to remove
I kept my 2" receiver and use the adapter for this reason and because it provides more flexibility should I need to tow with a different truck in an emergency.
SCOTTinNJ is offline   Reply With Quote
Old 08-06-2017, 06:12 AM   #17
2000 25' Safari
Denver , North Carolina
Originally Posted by wulfraat View Post
I use the 2.5" -> 2" adapter that came with my truck mainly because (1) it came with the truck and I had it and (2) I already owned a 2" shank so this avoided my shelling out $$ for a new shank.
For what it is worth the 2.5" -> 2" adapter works just fine with my 2" shank.
That being said if you don't have an adapter or are buying a new shank anyways I'd just go for a 2.5" equalizer shank. If you loose the adapter for some reason then you are SOL
Purchased the adapter and trying it out this week. I already "forgot" it was in there when I was setting up so I'll be cruising for a 2.5 shank. Lucky it didn't fall out moving from one part of the driveway to the other.
I little worried about how loose everything is with the adapter, not tight at all. Normal for some "slop" and rattle?
mbubbaca is offline   Reply With Quote
Old 08-06-2017, 08:29 AM   #18
Mollysdad's Avatar
The Equal-I-zer web site has a calculator for the shank size.
Airstreams seem to all be about 19" ball height, so you measure to the top of your receiver, plug in that number, and it tells you if you need a lower shank or what holes to put the hitch in.
They sell shanks, or Curt, E-Trailer, and others do also.
https://www.equalizerhitch.com/find-your-shank-size
Old 08-06-2017, 02:12 PM   #19
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Hitch drop 2500 HD
Just put the pin through to hold the adapter in place when not towing. Mine fits pretty well - not too much movement...
wulfraat is offline   Reply With Quote
Combining 4" drop reciever to Hensley 8" drop shank Rascal0729 Hitches, Couplers & Balls 18 07-20-2015 05:52 AM
2015 Chevy 2500 LTZ HD vs GMC 2500 Denali HD Roadtech Tow Vehicles 2 10-21-2014 05:47 PM
07 Tundra vs F250 vs Dodge 2500 vs Chevy 2500 outthere Tow Vehicles 248 01-13-2011 08:48 AM
Hensley Arrow on a 2006 GMC 2500 - what is the 'drop' for the stinger? 72Blazerod Hitches, Couplers & Balls 5 05-13-2010 10:13 PM
Late model 2500 Yukon XL 2500 TV, How good? evsjr Tow Vehicles 10 12-21-2008 05:01 PM
