Old 09-30-2017, 12:35 PM   #29
2017 28' International
Batesville , Mississippi
This is the Hitch Model: Fastest E2 Hitch, Model 10,000 lbs. Round Bar Hitch, with 2 5/16 Ball.
csondt is offline   Reply With Quote
Old 09-30-2017, 12:38 PM   #30
Originally Posted by Mollysdad View Post
BTW. the "net" says the socket needed for a 2 5/16" ball on an Equalizer hitch is 1 7/8" thin wall.
Fastway E2 Hitch, Model 10,000 lbs. Round Bar Hitch, with 2 5/16 Ball.
Old 09-30-2017, 12:42 PM   #31
Originally Posted by GMFL View Post
Replace the ball with a quality brand like Curt or Reese
Old 09-30-2017, 12:43 PM   #32
Originally Posted by ChiefCarruth View Post
Check your hitch itself, I am assuming that it was the same one that you had before.. I am also assuming that you are not using a hitch that was not made to hall a full-size trailer. The hitch for this trailer usually weighs over 75 lbs.
Old 09-30-2017, 12:47 PM   #33
ITSNO60's Avatar
Tucson , AZ
BTW, I find it much easier to rotate the shank 90 degrees in the truck, then your prying force is applied in a vertical plane so you're not working 1' off the ground.
Why didn't I think of that??? Just when you think you know it all......
Brian
ITSNO60 is online now   Reply With Quote
Old 09-30-2017, 12:50 PM   #34
Hitch Ball Retaining Nut Backing off During Trip
Thanks, after reading the post I believe what happen is the dealer did not get the torque anywhere close to 450 foot pounds of torque required. Before welding it we got it as tight as we could, the design of the bottom side of the hitch will not allow a 2 13/16” socket to fit properly over the nut making it very difficult to achieve the proper required torque.
Old 09-30-2017, 04:18 PM   #35
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
When you do it this way you don't "need" a torque wrench. Just a tape measure and a rough idea of your weight. And a little math.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old Yesterday, 04:21 PM   #36
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
A "BUCKSHEE" METHOD FOR SURE!
MelGoddard is offline   Reply With Quote
Old Yesterday, 04:23 PM   #37
ARE YOU TRYING TO Say SOMETHING????
Old Today, 08:10 AM   #38
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Not sure if that's a compliment or not. I suspect not.
Actually, it's the most accurate method. How do you think torque wrenches are calibrated?
I say whatever works.
Retaining strip or glazing bead for windows 1965 Caravel Texasred Windows, Doors, Locks & Vents 5 10-19-2016 10:45 AM
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 01:57 PM
Plastic Retaining strap RVDreamer Fresh Water Systems 3 02-02-2015 08:44 PM
Loose Ball Nut - CAUTION Driver1 Hitches, Couplers & Balls 22 06-01-2008 12:16 PM
screen door retaining latch 77 R GO C MH Doors & Locks 1 05-12-2005 12:33 PM
