Old 09-28-2017, 05:30 AM   #15
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Hi
You are in for a bit of work to check them out if this happens.
Just happen to have checked all four of mine last Saturday. In this picture, the magnet, lower center, was pulled far enough forward to latch up the rear brake shoe. 1-7/16" nut or 36mm in a pinch and big-o torque wrench. The magnets look bad, but were flat and just discolored. Attachment 295729Click image for larger version
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-29-2017, 07:42 AM   #16
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by james.mileur View Post
Just happen to have checked all four of mine last Saturday. In this picture, the magnet, lower center, was pulled far enough forward to latch up the rear brake shoe. 1-7/16" nut or 36mm in a pinch and big-o torque wrench. The magnets look bad, but were flat and just discolored. Attachment 295729Attachment 295730
Hi
If you leave the disconnect plug out to the "flat battery" point, you will need to unwire each of the magnets and check their resistance. Next step would be to put 12V on them and check for proper operation. As you have nicely shown, those checks also need to be followed up by a visual inspection ...
Lots of fun ...
Old 09-29-2017, 08:27 AM   #17
Obviously-NOT
Kalispell , Montana
Well, this picture was there when I posted the first time. Click image for larger version
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Help-Hitch Ball problem Chitown AirStreamers Hitches, Couplers & Balls 4 07-22-2003 12:35 AM
Hitch ball height... drboyd Hitches, Couplers & Balls 2 06-30-2003 05:29 AM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
