Old 04-05-2016, 05:25 PM   #1
2008 27' Safari FB SE
Delta , BC
Hitch advice, sway and bounce
I have a 2010 Yukon Denali towing a 2008 27FB trailer. I have towed for many years using just a weight distribution hitch, no sway control and I haven't weighed anything. I notice that everything in the rear of my trailer gets really thrown around, cabinets open while driving, my sub woofer came unattached, the table moves around, even my bike rack bent, so I am thinking maybe I should look a little closer at what I can do in terms of hitch and sway control. I have always just thought it was normal, so I try to store stuff in the bedroom when travelling as the bedroom area is undisturbed. I have a pretty basic hitch, a DSP I believe, came with the trailer. I had a fridge hinge problem and some one suggested trailer bounce could be a problem, although that didn't break the hinge, it may have created the wear and tear. Thoughts? where to look, opinions....
bugman3 is offline   Reply With Quote
Old 04-05-2016, 05:55 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
you have opened a multi-faceted and target rich Thread!!!! Congratulations.. and 'good luck'...
Let the abuse begin...
How is your rig setup on the CAT scales?
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-05-2016, 06:00 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Another fun thread 😈
MICHAEL
Old 04-06-2016, 08:48 AM   #4
Delta , BC
Cat scale??
Old 04-06-2016, 08:59 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by bugman3 View Post
Cat scale??
That is a serious question. A "CAT" scale is an actual scale used to weigh vehicles like 18 wheeler to ensure they are within legal limits, balanced, and can properly invoice the customer.
The advantage to RV's is we can weigh our rigs while setup for camping or empty... This is how you determine the RV and TV weights. Then, balance and tongue weight of RV against the Manufacturer specifications. Now you can compute proper tongue weight and WD transfer.
There is a spreadsheet on the forum where you can plug in the numbers and get the weight targets.
Here is thread link....
http://www.airforums.com/forums/f464...sis-19236.html
There is good info in first post... Spreadsheet is at post 69 I think.
Also, don't forget the TV condition.. If shock absorbers are not dampening the bounce, they may need replacement.
Channing
WBCCI# 30676
Old 04-06-2016, 10:48 AM   #6
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Sounds like a lot of movement to do that much damage. Do you feel any sway while underway?
What tires on ur trailer?
After changing out the ST bombs with larger LTX, I noticed signs of increased vibration. But, it looks like a set of Centramtics took care of that.
(Had to get the ST shot in there....)
boondockdad is offline   Reply With Quote
Old 04-06-2016, 11:26 AM   #7
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Wave Pattern...
What you're describing is a wave pattern from your hitch point. It's much like the wave you see when a rock or boat moves through water - its wake. The more severe the bump or sway, the more intense the wake/wave magnifying itself through your trailer. That's why stuff near the hitch stays stable and midpoint to rear gets tossed. To counteract this you MUST dampen the effect by sway control AND weight distribution technology. Once I did BOTH, the physics of towing a 34' AS changed - no more "earthquake" damage between points A to B.
Urbanologist is offline   Reply With Quote
Old 04-06-2016, 11:58 AM   #8
JimGolden's Avatar
1977 31' Excella 500
Check your tire pressure as well. Running too high a pressure will really bounce things around. Too low a pressure though and the carcass overheats and comes apart. Better to err on the high side, but not too crazy.
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 04-06-2016, 12:08 PM   #9
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
Sway and bounce
Use a sway bar.
paddle whisp is offline   Reply With Quote
Old 04-06-2016, 12:15 PM   #10
2005 19' Safari
GLENDALE , AZ
Bugman3, low tire pressure can sometimes cause a wallowing effect that might contribute to some of your problems.
What kind of tires (specifically, load range) are you running, and at what tire pressure?
Old 04-06-2016, 12:36 PM   #11
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
I'll stay of of the WD / sway comments but I do know that when we had a front bedroom floorplan the kitchen cabinets, drawers opening were an issue. With a rear bedroom layout problem solved.
gwg is offline   Reply With Quote
Old 04-06-2016, 12:52 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
So, two tires walk into the Sway Bar...
Tire1...I think I can get the swing of this!
Tire two... You are so full of hot air...
Channing
WBCCI# 30676
Old 04-06-2016, 01:30 PM   #13
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Sounds like a wireless g-force meter would be an interesting tool to measure improvements ........ or maybe we could just use Lacy? Then again, there is probably an app for it.
Guess if the RVer had filled with N2, slowed down a bit, and inflated to the correct pressure for the load, Tire #1&2 would still be spinning in the wind, instead of wrapped around a sway bar. Pat
Old 04-06-2016, 01:58 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi bugman
Serious problem deserving serious advice so here you go
Yes, go to the scale, cat or otherwise, and confirm all your weights. There are threads on how exactly to do this. The two things you want to confirm are that the tongue weight is around 10-15% of the trailer weight, and that the weight on the front wheels of the tow vehicle is more or less the same with the trailer as without.
Get your trailer tires balanced and make the shop tell you whether/how much of a change in weight they made, if large, that might be your problem.
Check tire inflation, opinions vary, you should either be at the max PSI for the tires or at a somewhat lower PSI based on actual load, depending on what school of thought you subscribe to, or somewhere in between, if not maybe that's your problem.
Check to be sure the trailer shock absorbers are present and working. Opinions vary on how much they help but at a minimum it's something to try. Replacements are not expensive nor are they difficult to install.
Controlling Bounce Whizzo Jacks, Stabilizers, Lifting and Leveling 12 03-17-2013 10:24 PM
Bounce Wiggle Rock Wobble Seesaw P&J Jacks, Stabilizers, Lifting and Leveling 11 02-14-2010 11:34 AM
A new kind of "Bounce" plan COArgosy78 Off Topic Forum 47 01-10-2004 01:04 PM
How much floor bounce/give is normal? JHarper Repairing/Replacing Floor &/or Frame 4 01-07-2004 07:13 PM
Floor Bounce? Jabba Repairing/Replacing Floor &/or Frame 4 05-14-2003 04:12 PM
