Old 03-16-2012, 11:15 PM   #1
GreggH's Avatar
2005 31' Classic
Castalain Springs , Tennessee
Hensley teardown/repaint
After 6 years and 60K+ of towing (including 3 months in Alaska) with the haha decided to take it apart to have it sandblasted and repainted. No need to post photos as the ones on the "ultimate haha user guide", page 37 post 505 show enough.
Did a complete tear down and found:
No water or dirt inside so only replaced grease seals and repacked bearings.
Replaced upper dust caps only for cosmetic reasons since doing a repaint. Cleaned and reinstalled two of the old ones for the bottom.
Replaced grease fittings (zerks)-the plunger that holds the spring bars in place did have a little wear but had much more life in them. Wasn't necessary to replace but since I had it apart figured I would and saved the old ones for spares.
Replaced the spring bar U-brackets. The elongated holes which the pin slips through to connect the strut assembly to the spring bar enlarged due to wear and/or compression. The hole enlarged to 1/8th " closer to the edge. On the new brackets, the hole begins 3/8th " from the top edge of the bracket but on the old brackets, the hole wore to 2/8th " from the edge. This is the only part I felt needed replacing because of the wear and stress by the spring bar tension and probably is something haha owners should add to their frequent checklist. I don't know how much that hole can enlarge before it poses a threat of failure or effects towing.
The twin bushing located on the bottom of the hitch box, where the ends of the spring bars insert, had some wear on the interior ends but not as much as in the photos mentioned above. I called Hensley and was told as long as the spring bars stay inserted no action is necessary.
Replaced the collar with set screw which holds the strut assembly to the frame bracket only because the set screws were rusted, another cosmetic thing.
Replaced the 4 shear bolts because of rust.
It was an easy tear down, no special tools or complicated parts. As said in previous posts, if you can do wheel bearings you can do this, although after doing it and inspecting mine, I'm not sure it is necessary. I think if you pop off the upper and lower dust caps and you can see no water is getting inside and the grease looks clean, you'll be fine. My son-in-law sandblasted the parts and repainted them a shiny black used for farm equipment which should last longer than the original paint job.
So, after 6 years and a lot of miles the Hensley was in good shape. The only necessary fix, and only in my opinion, was replacing the spring bar u brackets and getting the whole package painted.
Next project, brakes.
GreggH
GreggH is offline   Reply With Quote
Old 03-17-2012, 10:49 AM   #2
Vintage Kin
Fort Worth , Texas
Nice description. And similar to my experience.
Something that should be purchased along with the hitch itself. They wear quickly (mine looked lousy by 5k miles).
Old 03-17-2012, 11:05 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
GreggH,
Great post!!!
Do you leave it on 365.
Found that by removing it every Fall your almost forced to do the needed maint as you re-install in the Spring.
I use the cover during the Season and after 8years don't have cosmetic problems yet.
The haha head looks better than mine.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-17-2012, 11:54 AM   #4
GreggH's Avatar
2005 31' Classic
Bob,
Yes, we leave it on all the time as we camp all year long. We're usually home around this time of year so I do all major maintainance and inspections now, before spring. We'll be heading for the South Carolina coast in a couple of weeks. Most of our camping is done along the coast from Florida to Prince Edward Island, Canada, so the trailer is exposed to the salt air probably 5 months out of the year. Covering it would have been a good idea, now that it's freshly blasted and painted I'll probably start. Taking it off would certainly give a good opportunity to thoroughly check it over. Hopefully this paint job will last longer then the original.
GreggH
Airstream / Hensley / Tundra? davidmenges Towing, Tow Vehicles & Hitches 52 04-27-2015 12:12 AM
Hensley Cub? AWCHIEF Hitches, Couplers & Balls 9 09-18-2012 09:28 AM
Hensley self tapping shear bolts adonh Hitches, Couplers & Balls 24 04-17-2012 11:01 PM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
