Old 04-25-2015, 08:38 AM   #15
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
Question
RAH,
Once I downloaded the manual and started going through it, it dawned on me that there's many components that take quite a bit of abuse over the years which raised a couple of questions:
1. After 21 years, could metal fatigue be an issue. I believe the unit didn't travel very far in the beginning. However I've had it for almost seven years and have put about 20,000 miles on it.
2. What's involved in a total rebuild. In other words, do I consider a rebuild or look at a new unit. Terry mentioned that the old unit could be traded in on a new one (Swift Arrow?).
Then again if looking at a new unit, PP3 could also be considered?
Every answer results in more questions?
Hans Grim
1993 29' Excella
2011 GMC Sierra 2500 HD 6.0L
Hensley Arrow
Hans Grim is offline   Reply With Quote
Old 04-26-2015, 07:38 AM   #16
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
Hensley jack shaft
Using a nutsplitter to break both collars was eventually the only way to remove them. Once accomplished the rest was pretty easy. The 3/16 allen key in the inside collar on the shaft was easy to find eventually under the grease and then tighten against the threaded shaft. I'm glad I had the spare collars in my repair kit. Now the level and angle of the hitch is again simple to maintain.
Thanks for the help.
Hans Grim
1993 29' Excella
Hensley Arrow
Hensley - Bent shaft on frame brackets? timmaah Hitches, Couplers & Balls 12 04-18-2012 08:28 PM
Disconnect Drive Shaft smily Airstream Motorhome Forums 2 02-23-2004 05:51 AM
Instalation of a new drive shaft saxonsraven Airstream Motorhome Forums 5 10-28-2003 08:45 PM
one piece drive shaft john hd Tow Vehicles 11 02-22-2003 11:48 AM
U joints and drive shaft thenewkid64 Mechanics Corner - Engines, Transmission & More... 2 07-13-2002 04:07 PM
