01-13-2016, 07:44 PM
#21
Oswego
I think the stickiness is because the PP stinger ramps go all the way to the corners and the haha are shorter block ramps. I never had sticking until I got Sean's adjustable stinger for haha. I just apply dry lube every couple months. The PP design is better, as you don't get distortion of the box opening like you do with haha stinger.
-Rich-
01-13-2016, 10:12 PM
#22
2015 30' Classic
Pleasanton
The angle at which I can hitch and unhitch is somewhat restricted (+/- 30 degrees or so) in my PP setup due to not being able to raise the jack foot and have the foot clear the WD bars, even with the WD bars swinging freely. Someday I'll figure out how to remove the jack foot so this is not an issue.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
01-14-2016, 05:35 AM
#23
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
The PP's cost too much.....
We buy the most expensive trailer then......Rationalize $2%.
"You don't know where you've been until you leave, enjoy life" RLC
01-14-2016, 06:27 AM
#24
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We are using the Hensley on the 23D and the stinger was both bent and shortened for the Mercedes when we got the 25FB. We have no bump when braking. It likes frequent applications of grease.
The ProPride is installed on the Classic and the Dodge 2500HD Cummins pickup. Occasionally, I get the bump. I have to check the centering more often with the ProPride.
The ProPride was less expensive than the Hensley that was purchased two years earlier. The ProPride is more user friendly. But the Hensley does the job well on the 23D.
01-14-2016, 06:59 AM
#25
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Here is my take.
If I never towed above 60MPH, I would not need sway control, and any hitch would do for me including towing on the ball.
Well, that isn't realistic for me. The Hensley totally changes how the trailer tows, making my combination a joy to drive.
I highly recommend this design hitch. I bought mine used for about $1,100, but after using it, I would pay full price for either the Hensley or the ProPride.
My used unit seems to be older, with a serial number in the five thousands, it is still in great shape, all I have had to replace is the weight bar end brackets, a cheap and easy fix.
A couple of weeks ago I took it down, inspected it, and popped the caps that cover the bearings, it is still tip top.
Brevi tempore!
01-14-2016, 07:03 AM
#26
Oswego
I found mine in 2012 or 13 for $800. It is also an early one and serial number was missing...but it didn't have a lot of miles nor wear on it. I completely disassembled, sandblasted, painted (frame color), replaced some bits and pieces, repacked, got a PP for HAHA adjustable stinger, and I love it. That said, I'd opt for a PP when/if I have to replace it.
http://www.airforums.com/forums/f44/...gue-95502.html
-Rich-
01-14-2016, 07:05 AM
#27
1972 31' Sovereign
Benton
, Arkansas
About porpoising, the setup will do this if the WD bars are too TIGHT also.
It seems that there is a natural desire to tighten those bars down tight to totally restore the tow vehicles attitude, but for me, ride and control is better when I resist the temptation and leave a little more tongue weight on the truck than is commonly recommended on this forum and others.
Brevi tempore!
01-14-2016, 07:18 AM
#28
Oswego
The "Goldilocks Zone" is important and is unique to each setup, TV, trailer, and TV load...IME and O.
-Rich-
01-14-2016, 07:21 AM
#29
1994 30' Excella
alexandria
, Kentucky
That's interesting because I have found just the opposite that when the truck bed is loaded down and the trailer is packed I need to tighten the jacks up to get rid of porpoising. A half inch difference in jack height will make the difference.
When we host a unit rally we take a lot more stuff than normal..........firewood, food, tables, etc.......
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
01-14-2016, 07:24 AM
#30
1972 31' Sovereign
Benton
, Arkansas
Mine is old, but was obviously hardly used. The original paint is slightly faded, but otherwise good.
I considered taking mine apart and painting it a couple of weeks ago, but it still doesn't need it yet so I put it off for a different year...
Brevi tempore!
01-14-2016, 07:33 AM
#31
2013 30' Flying Cloud
Virginia Beach
, Virginia
Hensley vs all other hitches
Having towed with the Hensley for about two years now it finally has become a familiar piece of equipment. The learning curve on hitching is steep and frustrating but there are lots of techniques folks have shared that make hitching less painful. I will defer to others and you will develop your own technique. In level of pain we have progressed from impacted wisdom tooth to smashed thumb although the thumb is no longer throbbing when I hitch.
As others have commented towing is rock solid and simply unresponsive to vehicles passing or crosswinds. When braking hard to avoid my fellow motorists odd maneuvers I have experienced the bump although I never knew it had a name. I'll need to check the hitch setup to ensure I haven't missed something. I can't change the occasional encounter with - aw, you know.
The hitch is a heavy, complicated design that demands attention to detail in pre-travel inspection and mid-tow walk-around. That's one small price to pay for the fabulous, solid performance.
According to the factory rep I spoke with the trailer and truck must be absolutely straight to unhitch/hitch. No angles allowed as with a ball hitch. I learned that when we recently camped at a site that had one of those little half-moon pull-through designs. Our combination's length just did not permit getting the truck/trailer straight on that - the last remaining - site. For some happy reason I chose not to unhitch before getting advice and the factory rep told me that the truck/trailer needed to be straight. Eh? That was a new and mildly unwelcome fact. Have others had experience with this?
With use over the past two years the hitch is showing wear although I have used the available cover. The increasingly ratty appearance will need attention this summer. The powdercoat finish has begun to chip and parts are showing wear and surface rust.
On balance the compromises are acceptable to obtain the great towing performance. I would buy and use the HAHA again.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
01-14-2016, 07:34 AM
#32
Oswego
What I have found:
Too tight caused small, hard oscillations, as the suspensions can't do their job.
Too loose causes large, soft oscillations...this is my definition of porpoising...feels and looks like a porpoise diving and rising in the water.....
-Rich-
01-14-2016, 07:39 AM
#33
Oswego
"According to the factory rep I spoke with the trailer and truck must be absolutely straight to unhitch/hitch. No angles allowed as with a ball hitch..."
That's the easy answer from the rep, IMO. It is definitely easier with a near straight alignment, but, as you gain experience and can visualize the relative motion on uneven ground and larger angles, you can hitch up easily from pretty radical angles. When respective differences in side to side tilt of TV and AS are encountered, you can just use the jacks to introduce a matching tilt to the head relative to the receiver opening. I just takes visualization and analysis of your positioning.
-Rich-
01-14-2016, 10:26 AM
#34
2007 22' International CCD
Corona
Hensley Hitch
I've found that straight is flat not necessary. Just have to move the head by hand to the angle I'm approaching with the TV, fiddle the jacks to the correct roll angle, and find the opening with the stinger. That's the fussy bit.
Once I'm aligned, a gentle push with the TV gets the stinger seated.
True, straight and flat takes less planning, but I've been able to hitch up without a backup camera by just getting out and looking multiple times or have someone guide me a little. Takes practice and a little luck, but I can hit it on the first try.
For the record, I have a ProPride setup.
01-14-2016, 11:01 AM
#35
2005 30' Classic
Burlington
, Ontario
A few very minor but helpful tips I have picked up from Terry at Hensley .........
(1) If the stinger doesn't seem to want to go in the last 1/2" or so, sometimes you can just pull it it with the camlock type latches on the hitch. (in my experience, If that doesn't wok, you probably need to pull your tow vehicle ahead and try lining up again!)
(2) A bit of spray silicon on the stinger - and maybe also inside the hitch - can help
things. (I used to use a type of spray grease, but the silicon does seem to help and is a whole lot less messy.)
(3) To make for a simple unhitching, you can watch the point where the stinger enters the hitch pocket on your tow vehicle - or even put a finger or thumb at this junction.
As you operate your tongue jack, you can then see or feel the point at which the bar becomes loose in the tow vehicle. You then know for sure that there is no downward force tending to bind the stinger in the hitch, and everything unhooks easily.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-14-2016, 11:16 AM
#36
Oswego
As far as lube goes....I have settled on Mountain Bike chain lube. Think about it....it is designed to lubricate, be waterproof, shed mud and sand, etc, and stick to the chain.
Sounds just like what we want to do here. Just dab it on the ramps about every 2 - 3 months, let it dry to a paraffin-like coating, and forget about it. Doesn't make a mess or get on your clothes, etc.
-Rich-
01-14-2016, 11:21 AM
#37
2012 27' Flying Cloud
W
, New England
Hmmm - sorry to be dense. What are the "ramps" and is Mountain Bike the brand name or the type of lube - do you have a pic of the product? Thanks!
01-14-2016, 11:25 AM
#38
Oswego
The ramps are the "wedges" on the stinger that center and have the force of the cams on them against corresponding ramps inside the head box.
Not a brand. There are many brands of mountain bike chain lube...here's one that I've used,
White Lightning Clean Ride Self Cleaning Lubricant 4oz
I also use it on door and compartment hinges...anywhere I don't want dirty oily stains on the AS. Works well on the BAL stabilizer screws too.
-Rich-
01-14-2016, 11:30 AM
#39
1972 31' Sovereign
Benton
, Arkansas
I have found that I have no trouble hitching using the get out and look method so long as I don't have a helper telling me which way I need to move. This screws up everything.
I have hooked painlessly when the TV is turned to the left or the right relative to the trailer.
The worst thing I have done with the hitch is when I unhitched one night when I was in a hurry. I had forgotten to remove the safety chains.
The stinger came part way out of the hitch head when the chains caught.
I couldn't get enough slack in the chains to get them off because the hitch head moved to the side cocking the stinger in the hitch head.
I couldn't go forward and I couldn't go back. It took me a few minutes to sort that one out.
I was in a hurry, and being in a hurry made me even more late.. Imagine that...
So, the moral is don't forget to unhook your safety chains when unhooking.
Brevi tempore!
01-14-2016, 12:41 PM
#40
W
, New England
Awesome - thanks muchly!
