Old 03-09-2018, 03:51 PM   #1
1999 28' Excella
New Orleans , Louisiana
Hensley help!
We are full-time and have towed for five years with a 2003 Hensley 1000 lbs. One of the zerk nipples has sheared off so we have to replace it. The hitch still works. So we have talked to Hensley and can get the part but we are average mechanical.
We are now in Georgetown, TX and looking for some maintenance on our hitch. It does not have to be in this area of TX or maybe NM where we are going next. I am a hands on person and just do not know how to fix this..afraid to just take it apart.
Any suggestions?
badkat is offline   Reply With Quote
Old 03-09-2018, 04:12 PM   #2
dznf0g's Avatar
Oswego , Illinois
I assume it is the spring loaded nipple on the inner end of the zerk fitting, right? That is a consumable maintenance item. Replace both and carry a spare. Loosen the lock nut and screw the whole assembly out. Thread the new one in, while holding the spring bar in its bushing. Keep screwing the retainer body in until the nipple is engaged in the slot in the spring bar. Lift the Jack end of the spring bar and continue to screw the retainer body in until the threaded body bottoms out against the spring bar. Back the body out about 1 to 1.5 turns and lock the jamb nut down. Grease 'er up and carry on.
-Rich-
Old 03-09-2018, 04:39 PM   #3
1999 28' Excella
Ours is off on the outside and having a hard time understanding..will read a few more times.
Old 03-09-2018, 04:40 PM   #4
dznf0g's Avatar
Oswego , Illinois
Off on the outside? Don't know what you mean. Picture?
-Rich-
Old 03-09-2018, 05:01 PM   #5
1999 28' Excella
Ok!
Old 03-09-2018, 06:16 PM   #6
1999 28' Excella
here you go!
Old 03-09-2018, 06:23 PM   #7
dznf0g's Avatar
Oswego , Illinois
So the zerk just snapped Off? That's very odd.
-Rich-
Old 03-09-2018, 06:25 PM   #8
1999 28' Excella
Campers Clinic II just dropped our trailer on its spring bars and said someone went over our hitch and it was fine ..now we have this.
Old 03-09-2018, 06:36 PM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Loosen the nut on the zerk fitting. Go to Home Depot and get a bolt extraction tool like this https://www.homedepot.com/p/Bosch-Sc...215/203598110.. Follow the instructions on the extractor kit to remove the zerk fitting. Put in a new one.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-09-2018, 07:15 PM   #10
dznf0g's Avatar
Oswego , Illinois
Um, the whole fitting was $16 last time I bought them. Probably not worth messing with, since OP said they are quit old and presumably a lot of miles. At 14 years, it probably due for a teardown and full maintenance.
-Rich-
Old 03-09-2018, 07:17 PM   #11
dznf0g's Avatar
Oswego , Illinois
Oh yeah, I read that. Bet they hit it. Grease zerks just don't break by themselves.
-Rich-
Old 03-09-2018, 07:17 PM   #12
1999 28' Excella
Where?
Old 03-09-2018, 07:18 PM   #13
dznf0g's Avatar
Oswego , Illinois
Where?
From Hensley, but that was in 2011 or 2012.
-Rich-
Old 03-09-2018, 07:23 PM   #14
1999 28' Excella
Would you just buy another brand new?
Hensley Hitch Bars Help frjeff Hitches, Couplers & Balls 2 08-03-2017 08:33 AM
HELP!!! Hensley vs ProPride 3P sempi2 Hitches, Couplers & Balls 91 12-08-2014 09:43 PM
Hensley or not hensley socool69 Hitches, Couplers & Balls 45 11-21-2014 08:28 AM
To Hensley or not to Hensley Aquabud Hitches, Couplers & Balls 86 12-22-2010 08:10 PM
Hensley Arrow, will it help? 74SovereignInt. Hitches, Couplers & Balls 20 04-05-2003 10:36 PM
