Old 09-23-2012, 03:44 PM   #1
Mulligan's Avatar
kettering , northants
Help required '53 Chevy
Hi, On our furum in the UK a new member has a 53 Chevy 3100 1/2 t Pick up. He's trying to find out what the towing specs are for this truck
He is looking to tow a 77 Overlander (rear bath double) can anyone help please
Many thanks
Tim
Mulligan is offline   Reply With Quote
Old 09-23-2012, 04:29 PM   #2
Wayward's Avatar
Cary , North Carolina
It looks like it has a curb weight of about 3200lbs and a GVW of between 4200 and 4800lbs.
A 77 Overlander has a tongue weight of 580lbs so it looks good to go.
Keep in mind that GVW is based on 1953 tire technology that would put it on the conservative side if new load range D to E tires are added. High load tires and upgraded springs should add a substantial safety margin. Lower gears in the rear axle will bump the towing capacity.
I am no expert on old trucks but you may not be able to find "towing capacity". That truck was built in the day when people used common sense and just hooked up things safely. Towing capacities that everyone frets over so much these days are half math and half legal CYA.
I worked in a marina in college that used a 1960 1/2 ton Chevy with a small block v8 and a 2 speed automatic to tow some massive boats. It saw 8,000 - 10,000 lbs on a regular basis with no WD or anti sway. Ah - the good old days
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Help required Mulligan WBCCI Forum 2 07-19-2012 06:06 PM
Should Profile Info be required? rfield54 Our Community 44 12-12-2005 06:01 AM
Newbie needs info on what is required for maiden trip Diesel Pusher On The Road... 10 06-02-2004 07:42 PM
Power required to run A/C Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-29-2003 10:02 AM
