Old 01-01-2013, 07:17 PM   #1
groovzilla's Avatar
1963 19' Globetrotter
Seattle , Washington
Help please regarding brakes - 1969 23' Safari
all,
i plan on picking up my new to me 23' airstream safari tomorrow with my 1994 isuzu trooper - i have a basic trailer light plug in (that i use for my boat trailer)set up with no connection for brakes - will this be an issue moving the trailer??
i was just told that the trailer brakes will remain locked if i don't have the proper brake wiring set up -i can't imagine this being the case but is it correct??
thanks in advance.
groovzilla is offline   Reply With Quote
Old 01-01-2013, 08:06 PM   #2
Originally Posted by groovzilla View Post
all,
thanks in advance.
Might or might not happen.
Knowing what colors each wire represents on the trailer, will help you avoid that.
Old 01-01-2013, 11:40 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
You need to get a 7 pin connector for your vehicle. Any rv dealer can wire it up for you. I recommend getting this done before you pick up your new Airstream. You need to get it done anyway, so why not get it done now.
Welcome to the forums!
Dan
Old 01-02-2013, 06:41 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You need a 7 pin connector for the trailer, and you need a brake controller to make the trailer brakes work. The only "optional" part should be if you wire up a 12 volt charge line now, or later. You also need WD and sway control, but you have to be able to stop the trailer, especially going down any hill or if an ID10T pulls out in front of you.
Lady - A 1969 23' Safari; Update and fixes BoCox 1969 - 1973 Safari 28 08-25-2013 10:00 PM
1969 Airstream Safari Twin eBay Watch Airstreams on eBay 0 10-17-2011 08:40 PM
1969 Safari - Wiring Diagram VeggieBullet Electrical - Systems, Generators, Batteries & Solar 11 10-13-2011 10:12 AM
1969 Airstream safari Vblgrl9 Airstream Registry Discussions 0 10-03-2011 06:32 PM
1969 23' Airstream Safari trailer eBay Watch Airstreams on eBay 0 05-03-2011 10:50 PM
