Old 12-06-2015, 10:17 AM   #1
2016 27' International
Grand Rapids , Michigan
help, my power hitch will not go up!!
I know this might be simple but need help. Our jack will go down to raise the trailer up. It will drop down however but we have to raise it up manually. Fuse does look good. What else should we look for? We are full timing.
dorrph is offline   Reply With Quote
Old 12-06-2015, 10:27 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If the jack will do the high-torque work (lifting the trailer) but won't lower the tongue, my first guesses are bad switch or a loose connection at the switch.
— David
Old 12-06-2015, 10:31 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I can't offer any specific repair or diagnostic advice for you except to point out that the tongue jack is not an Airstream-specific item and any RV mechanic and repair shop should be able to help you get this straightened out.
Bob Martel
WBCCI# 5766
Old 12-06-2015, 10:35 AM   #4
2019 27' Globetrotter
Salem , Oregon
If you can access the switch you can use a volt meter to see if you have power when the switch is in the proper position. You could also bypass the switch with a short jumper wire. If it works, replace the switch.
NoResults is offline   Reply With Quote
Old 12-06-2015, 10:38 AM   #5
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
Agreed, it's usually pretty easy to diagnose. If it isn't the fuse, then it's the switch. Access to the switch is pretty easy. Just take off the silly leveling bubble by rotating the cap and you can get to the switches. Also check your battery connection.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 12-06-2015, 11:13 AM   #6
Gainesville , Florida
Not sure if your jack is like mine but if you take the cover off the jack there is a reset button inside. Fixed mine, but it is old.
Old 12-06-2015, 11:40 AM   #7
Thanks so much for your suggestions. We will do all those things one at a time until we find the answer.
Old 12-06-2015, 11:43 AM   #8
2015 30' FB FC Bunk
Ayer , Massachusetts
Try replacing the fuse anyway. I had the same issue and that was it.
Ted S. is offline   Reply With Quote
Old 12-06-2015, 11:45 AM   #9
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Try turning the Jack manually with the crank to set the motor in a slightly different position. REMOVE the crank, and then try the switch again. Jim
Jim Flower is offline   Reply With Quote
Old 12-06-2015, 03:25 PM   #10
Manheim , Pennsylvania
What he said. Worked for me once.
Jukeboxfun is offline   Reply With Quote
Old 12-06-2015, 03:33 PM   #11
Mission , Texas
Reading this thread makes me happy I replaced the dead electric jack on ours with a manual jack.
nrgtrakr is offline   Reply With Quote
Old 12-06-2015, 04:42 PM   #12
2005 30' Classic
Mine still works ok - although i did have a problem at one tme that turned out to be a bad ground connection.
But the more I travel with RV's the more I tend to believe in the philosophy that I would rather use a little more manual effort that rely on electrics/electronics.
A nice convenience when they work, but sure can be a pain when they don't!
"KISS" isn't a bad principle to go by!
Brian
Old 12-06-2015, 04:54 PM   #13
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I like the electric with manual backup they have. We did replace our original Barker 3000 with the stronger Deluxe Hi Power 3500 when it stuttered a few times lifting our trailer tongue and rear of the truck to set weight distribution.
Doug and Cheryl
Old 12-06-2015, 04:54 PM   #14
Nirvana
2012 27' Flying Cloud
Gulf Breeze , Florida
I had the same problem - it was sporadic. First I checked fuse and the ground which were OK. I contacted Barker Manufacturing (269 965-2371) . They diagnosed the problem as a bad toggle switch which they furnished and I installed. Simple job. Fixed the problem. Good luck - the manual back-up wrench is a pain to operate....
Don
Nirvana is offline   Reply With Quote
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Help- shore power not engaging Rosie39j Electrical - Systems, Generators, Batteries & Solar 1 03-14-2010 12:03 AM
Hitch help, weight dist. or not reo Hitches, Couplers & Balls 2 03-04-2010 08:26 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
