Old 09-22-2017, 12:13 PM   #1
Chelsea , Alabama
Help ID trailer hitch
Hello group,
I have a weight distribution hitch that came with my 93 25' excella. I have the 2 bars but am missing the brackets that attach to the trailer. I have looked for a name on the parts wIth no luck. I was hoping to be able to get the brackets IF....this is a decent hitch. Thanks, Jeff
drjeff is offline   Reply With Quote
Old 09-22-2017, 01:05 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you can't find an answer check the spacing on the holes in the shank and see if they will match a Reese. If so a new system may be cheaper than the parts.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 09-22-2017, 02:22 PM   #3
Chelsea , Alabama
Howie, thanks for your reply
Was able to ID the hitch as a Pullrite. I know nothing about them but have spoke to customer service and they are trying to help me find the missing parts. Thanks
Air Safe Air Hitch and WD hitch combo Uptightto Hitches, Couplers & Balls 18 12-22-2014 03:38 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
