Old 06-17-2018, 10:24 AM   #1
2018 27' Globetrotter
Pagosa Springs , Colorado
Help !
I own a 2018 GMC Yukon Denali 4WD 6.2L engine. I want to purchase a 2019 Airstream Globetrotter. Will my vehicle tow this safely?
Thumper72 is offline   Reply With Quote
Old 06-17-2018, 10:36 AM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Help !
You are at the limit with that vehicle, technically speaking. It will pull it no doubt - but watch your hitch weight and payload based on the driver side door sticker and owners manual, I believe the globetrotter will likely push you over the limits on both.
The tongue weights listed by airstream are typically lower than in the real world. Payload for your vehicle is probably around 1,500 lbs - which only leaves 500 or so pounds for people and other stuff in your TV. If you want to work within the published numbers / capacities of your vehicle....
wulfraat is offline   Reply With Quote
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
