Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 10-28-2014, 02:56 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
Happy Retiree
Just ordered our 2015 FC 28 Rear Bed. Will be towing, hopefully with no problems, with our 2015 Tahoe with Andersen WD hitch. Ordered thru Tampa RV ( Stephen Weaver is awesome).
Anyone with a similar AS and TV rig, I'd like to hear your experience so far?
DeltaRon is offline   Reply With Quote
Old 10-28-2014, 03:16 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
As I commented earlier in your other Andersen hitch question today, it wouldn't work for our 1/2 ton truck/25' Airstream combination because it is not capable of distributing the weight for safe handling (your steering will be too light) in adverse conditions such as slippery roads and heavy crosswinds. Expect to be pushed around by semi truck bow wave a lot, and you won't like Interstate travel when the crosswinds are strong.
Some with heavy duty trucks are satisfied because there is still plenty of weight on the front axle and don't feel weight distribution is as important, but I still wouldn't recommend it because of other problems which are in the looooong Andersen hitch thread.
Doug and Cheryl
Old 10-28-2014, 04:15 PM   #3
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
dkottum, would you recommend the ProPride, or is the problem my Tahoe?
Old 10-28-2014, 04:27 PM   #4
SteveH's Avatar
Common Sense , Texas
Yep, I wouldn't dare tow a 28' with an Andersen hitch either. It just won't distribute the weight properly.
Regards,
Steve
Old 10-28-2014, 04:51 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm not dkottum (obviously) - we both have ProPrides but he has used others (including the Andersen) before.
Depends on what you need and what you're trying to accomplish. The ProPride virtually projects the pivot point toward the rear axle of your tow vehicle which gives it a "5th wheel" kind of advantage. The advantage is prevention of sway (vs. reaction to it) and ability to dial in exactly what you need for weight distribution. Disadvantages are cost and weight. The ProPride on your 28 could possibly make your tongue weight exceed your Tahoe's hitch receiver limit.
What does your 2015 Tahoe manual say about load restoration for towing? My 2013 3/4 ton truck ranges from 0% to 50% to 100% restoration based on several factors. If you don't require 100% restoration, the Andersen might work for you. Advantages are cost, weight and smooth ride according to those who use it. Disadvantages are potential coupler mismatch and inability to move lots of weight to the front axle.
All boils down to what you want and why. There isn't a single silver bullet.
Old 10-28-2014, 04:56 PM   #6
terryV's Avatar
2002 31' Classic
Monroe , Iowa
What about the Equalizer hitch?
terryV is offline   Reply With Quote
Old 10-28-2014, 04:57 PM   #7
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Hello Ron - congrat's on your new purchase! (you will love the trailer)
We have the same trailer and tow it with an F150. I cannot comment on the Tahoe as I don't know anything about them. That said, I can comment that the Anderson hitch will not work that great for you as it will not allow you to move enough weight to the front Axle. This will be a problem as the 28' is very heavy on the hitch.
We use a ProPride and have been VERY HAPPY with it.....
hope this help
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 10-28-2014, 05:46 PM   #8
dkottum's Avatar
Look on page 9-83 of your Owners Manual and you will see the adjustment procedure for a weight distribution hitch on your Tahoe. It requires the front of the vehicle height at the wheel well be returned to its height before the trailer is hooked up.
The Andersen can't do it with your Airstream, you will need a spring bar style hitch such as Reese or Eaz-Lift, or if you want the best for towing comfort and safety a ProPride or Hensley. Contact the manufacturers for proper w.d. bar sizing for your rig.
Doug and Cheryl
Old 10-29-2014, 03:49 AM   #9
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
Name:	ImageUploadedByAirstream Forums1414575584.852453.jpg
Understand everyone's concern over Andersen. However, my Tahoe hitch max is 1,000 lbs. (see pic). The FC 28 Hitch Weight w/LP only is 976 lbs. From what I understand, the ProPride hitch weighs over 90 lbs. which will exceed the Tahoe's safe hitch weight limit. Seems to this novice that neither ProPride nor Hensley will work with my rig. AM I MISSING SOMETHING? If not, then I've just wasted some serious money on a useless TV.
Old 10-29-2014, 04:23 AM   #10
SteveH's Avatar
Originally Posted by DeltaRon View Post
Attachment 225339
Don't know the exact weight of the ProPride because it varies with weight of bars you use, but I can tell you one with 1000 pound bars has a shipping weight of 230 pounds.
Regards,
Steve
Old 10-29-2014, 04:26 AM   #11
W , New England
Is that 976 figure from the factory specs? Many of us have found that figure to be shy of the actual tongue when loaded for camping.
You may be able to upgrade your Tahoe with a class 5 receiver which can handle 1500 #. I'm not very deep on mechanical issues so maybe others can chime in on this. If this is possible for your vehicle, it would cost a few hundred bucks but be worth it to keep the rig you like.
Old 10-29-2014, 04:35 AM   #12
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
976 is from the Airstream specs for the FC 28 rear bed.
Old 10-29-2014, 04:58 AM   #13
Wayward's Avatar
Broadway , North Carolina
Star with gut feel
Congratulations on your retirement and the excellent start on it with the Airstream - awesome.
I do not know a whole lot about the various WD designs but the comments above on the Andersen should be investigated.
I have however towed all manner of trailer and tow vehicle combinations so can add my two cents based on seat-of-the-pants experience.
The max tongue weight spec on your Tahoe is not really a significant factor here. If you put even close to half the real weight of the Airstream hitch out onto the rear, your Tahoe will squat too much to be comfortable to tow any distance.
Our 25' has a tongue weight of about 750lbs without propane and WD parts. For my 1/2 ton truck I set the bars to shift about 500lbs of it off the rear axle. For the 3/4 ton I shift about 200lbs off.
This just about levels the trucks with minimal squat and good neutral steering feel.
(btw the hitch is an a Reese Dual Cam which has the cast iron WD bars - easily adjusted between the two trucks)
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 10-29-2014, 07:00 AM   #14
Livingston , Texas
Attachment 225339
You are missing the high probability that the Andersen hitch will not be able to transfer enough load from the Tahoe's rear axle to the front axle.
When you combine that high probability with the high probability that the loaded tongue weight will exceed the Tahoe's receiver rating, you are asking for trouble.
IMO, the best way to deal with the weight and load transfer problem is to get a WDH which will be able to transfer sufficient load -- the Andersen will not.
Yes, you can save 20-40# by choosing the Andersen over a bar-type hitch.
But, IMO, that's a very bad choice for your situation.
Ron
Ron Gratz is offline   Reply With Quote
Old 10-29-2014, 11:19 AM   #15
Vintage Kin
Fort Worth , Texas
A ProPride is the way to go. After WD is activated the hitch weight comes down to about 75-80 percent of initial
Vent repair saga. Happy, sad, very happy Goin camping Roof Vents, Skylights & Fans 7 06-27-2009 05:26 AM
Happy New Year! PeterH-350LE Our Community 2 01-01-2003 12:47 AM
Happy Thankksgiving to all ALANSD Our Community 5 11-25-2002 05:41 PM
Happy Birthday! Andy R Off Topic Forum 7 06-05-2002 09:33 PM
