Old 06-04-2018, 04:22 AM   #15
Lakes Region , New Hampshire
Originally Posted by PKI View Post
Bet the coach frame is bolted to the TV frame. There is a poster that wanted similar, but can't find one as they are no longer built.
"Can't understand how it goes around corners" must mean the picture you have does not adequately show the mechanism. But it should make for an interesting discussion. Pat
To all who are waiting, unless the owner sees this post, that picture is all there is, there will be no reveal or final answer.
As for the photography questions, it was taken with a Samsung Galaxy S7 so no compression, you can see the shadow car from my wife's headlights of the trailer on the back of the TV
My thought was also that somehow it is hard connected to the vehicle, but thinking of how a tag axle drags, I'm back to how does he make a right turn.. I was just amazed, I've never seen anything that close before.
This was on 93 NB, north of Concord NH, right around Memorial Day. I believe it is an antique NH plate and it doesn't look like there is a plate in the frame of the TV
RandyNH is offline   Reply With Quote
Old 06-04-2018, 07:55 AM   #16
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Some kind of hitch that pivots on the side the vehicle turns toward? Maybe like a double-swing door hinge?
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 06-04-2018, 10:05 AM   #17
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Yankee inginuity - a friend lived in up-state New York. He said his neighbors went to the dump to recycle cast away stuff before they went to the second hand store. So tight to the TV is not a surprize.
I still think this is a normal hitch, well different, that is connected to the rear axle of the Tow Vehicle. Have heard about them, but never seen one. The tag on the trailer and not the TV is a question. The TV is not that vintage a vehicle and that does not quite fit, but maybe grandpa's rig got a new life with a grand kid.
Very interesting thread. The mystery will remain until knowledge over shadows conjecture. So, for now, waiting. Pat
Old 06-04-2018, 10:32 AM   #18
1964 26' Overlander
Milton , ON
I still think this is a normal hitch, well different, that is connected to the rear axle of the Tow Vehicle. Have heard about them, but never seen one. The tag on the trailer and not the TV is a question. The TV is not that vintage a vehicle and that does not quite fit, but maybe grandpa's rig got a new life with a grand kid. Pat
Maybe a Pullrite hitch with a shortened trailer tongue.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 06-04-2018, 06:25 PM   #19
ITSNO60's Avatar
Tucson , AZ
I was interested in the pullrite for my F350 but if I recall you lose the spare tire storage underneath.
Brian
ITSNO60 is offline   Reply With Quote
Old 06-08-2018, 07:09 AM   #20
2018 27' Globetrotter
Tulare , California
The tow vehicle's rear cargo doors are open giving the viewer an appearance of closeness to trailer. Ha, ha good try for a thread.
HDsteel is offline   Reply With Quote
Old 06-08-2018, 09:12 AM   #21
1964 26' Overlander
Milton , ON
Not sure what you mean. I'm looking at the space between the bumper and trailer as being much closer than normal. I see no indication that the doors are open.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 06-10-2018, 09:49 AM   #22
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
This a pintle hook. It is designed for very heavy loads 30,000 # plus. It makes for very easy coupling. No WD. Overkill is not the right word for the SUV. But hitching is a lot easier.
Happy streaming
gr.austin is offline   Reply With Quote
Old 06-10-2018, 10:58 AM   #23
1964 26' Overlander
Milton , ON
Happy streaming
How does a pintle hook allow the trailer to be that much closer to the vehicle? When I've seen them in use they seem to just replace the ball and coupler and not alter the space between the trailer and tow vehicle required for turning.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 06-10-2018, 11:25 AM   #24
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
GMC is now running the same gizmo on the trailer package, you have to ditch the propane though or move to the rear bumper.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-10-2018, 12:50 PM   #25
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
Look at the back of the TV. Is that a special modification? If so there is a hitch type that is a simicircle contraption the allows a trailer to turn but either edge of the trailer never gets any closer to the TV as the ball travels around the circle instead of the TT pivioting. ??
Kind of like the double coaches on big city busses.
Jekerrville is offline   Reply With Quote
Old 06-10-2018, 03:54 PM   #26
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
This is a Pull rite hitch. They are still available. You see more about their fifth wheel hitch but the trailer hitch is still available. www.pullrite.com
The hitch mounts primarily on the TV. With what looks like a small stub sticking out of the front of the RV. Backing with it is a whole new experience.
cbburke is offline   Reply With Quote
High Rise Hitch Ball compatible with equalizing hitch setup? PA BAMBI II Hitches, Couplers & Balls 3 05-23-2018 08:56 PM
Curt Mfg. Weight Distributing Hitch Setup COArgosy78 Hitches, Couplers & Balls 20 06-28-2016 07:42 AM
Equal-I-Zer Hitch Setup Report JimGolden Hitches, Couplers & Balls 95 01-23-2011 08:03 PM
Hitch height question, is my setup safe? damonbeals Hitches, Couplers & Balls 13 04-16-2008 11:06 AM
Hitch Setup Jabba Hitches, Couplers & Balls 2 10-04-2002 10:33 AM
