Old 02-23-2015, 02:17 PM   #113
Spring Hill , Florida
If you want to lube your moving hitch joints ---- use lithium grease. A little 'dab' will do ya ---- and NO mess like other grease. A little jar will last forever. I used to get it at Camping World.
zekethebear is offline   Reply With Quote
Old 04-02-2015, 08:55 AM   #114
Boxite's Avatar
2008 22' Sport
When I was much younger my balls were much looser and I was lucky to never have any problems from that. Nowadays no common preventatives can be relied upon to avoid problems and I worry for the younger-set.
I've read the concerns about loosening balls with interest and note that EVERYONE should avoid relying upon lock-washers and torque and/or grease to prevent loose balls. Trailer balls should be secured with locking devices such as cotters, pins, or by welding. Some hitches have the balls permanently machined to the hitch (my personal preference... I never want my balls to become separated from where they were intended to be permanently mounted.)
Tow & Stowâ„¢ Adjustable Ball Mounts | B & W Trailer Hitches
I am not a greaser. But I am an inspector and I look the equipment over regularly and replace/repair anything worn out.
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
