02-22-2015, 11:41 AM
#101
Vintage Kin
Fort Worth
But is it electrically conductive? You know we're getting older.
02-22-2015, 02:46 PM
#102
1978 25' Tradewind
Metro Phoenix
What a coincidence! I'm a bald geezer!
02-22-2015, 04:06 PM
#103
If you fail to lubricate the ball, you end up with a very basic type of European sway control.
In EU the coupler clamps onto the ball with enough pressure to provide some frictional sway damping by stiffening the tow vehicle/trailer connection.
It's a little bit like having a very small friction type sway control.
Not sure if it has any real effect. This is just a theoretical consideration.
02-22-2015, 06:53 PM
#104
Slympicins
2015 27' Flying Cloud
Sevierville
, Tennessee
Whew. Glad I read this. I will let the DW know to check my balls before we leave.
02-22-2015, 07:24 PM
#105
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro
, North Carolina
Deterioration
Deterioration....like these forum threads can really deteriorate...
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
02-22-2015, 07:44 PM
#106
2019 27' International
2014 25' International
Boulder City
, Nevada
SYNTHETIC BALL GREASE for 2015 30 foot Airstreams
Msmoto... you have to keep greasing the gears if you want things to run properly. Did you know the 2015 30 foot International requires Synthetic Ball Grease? Now, you cannot even use the real stuff any more.
I had considered a Thread covering preferences in Toothpaste or Toilet Paper in public restrooms/RV Parks/ Gas Stations... but with all of the ball greasing going on... it will have to wait.
As a byproduct of my researching ball grease, I discovered that Toilet Paper has become thinner and narrower in public restrooms. Toothpaste comes in larger six month tubes today, while the dentist gives out a week supply to keep your teeth fresh and clean for six month check ups.
There might be a correlation and it will need some help from Airforum members. So many issues... so little snow time to finish them.
It is dumping on Castle Rock. The white fluffy stuff. ATVed the driveway today, shoveled the decks and you would not know it!
02-22-2015, 07:58 PM
#107
1977 31' Excella 500
West Sacramento
The European sway control with minimal friction works best in cold weather.
02-22-2015, 08:30 PM
#108
2007 25' Safari
Greensboro
, North Carolina
Synthetic ball grease
@Ray Eklund
Golly thanks for the update on the synthetic ball grease. Now I know that to be the one who always tries to row upstream, my use of fifth wheel hitch grease on the ball is what I want... it really leaves a nice mark on your leg and washes off only with lots of brushing and soap.......
AIR #31871 KQ3H
02-22-2015, 10:31 PM
#109
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Originally Posted by Msmoto
@Ray Eklund
Of course some of us just leave the mark there ... a red badge of courage - so to speak. Especially good in the summer while wearing shorts! What a collection - some say better than tattoos ... YMMV
How many pairs of pants have I ruined ...? or saved ... If only DW would let me keep the marks ...something about grease on the sheets ...
02-23-2015, 12:30 PM
#110
2013 31' Classic
billings
, Montana
On the other forum their is a lot of talk of loose balls, here we talk of greasing the balls,I wonder if one should grease the balls before or after one tightens them ???
02-23-2015, 01:16 PM
#111
Small Town
No body would want to have their balls categorized as loose !!!
02-23-2015, 01:23 PM
#112
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
I dunno, does your TV wear boxers or briefs?
02-23-2015, 02:17 PM
#113
Spring Hill
If you want to lube your moving hitch joints ---- use lithium grease. A little 'dab' will do ya ---- and NO mess like other grease. A little jar will last forever. I used to get it at Camping World.
04-02-2015, 08:55 AM
#114
2008 22' Safari
Spicewood (W of Austin)
When I was much younger my balls were much looser and I was lucky to never have any problems from that. Nowadays no common preventatives can be relied upon to avoid problems and I worry for the younger-set.
I've read the concerns about loosening balls with interest and note that EVERYONE should avoid relying upon lock-washers and torque and/or grease to prevent loose balls. Trailer balls should be secured with locking devices such as cotters, pins, or by welding. Some hitches have the balls permanently machined to the hitch (my personal preference... I never want my balls to become separated from where they were intended to be permanently mounted.)
Tow & Stow™ Adjustable Ball Mounts | B & W Trailer Hitches
I am not a greaser. But I am an inspector and I look the equipment over regularly and replace/repair anything worn out.
