Old 01-12-2015, 10:24 PM   #71
Mixter's Avatar
1976 27' Overlander
The mess, I guess. But I've never greased, so I'm continuing to watch to see if there's something I'm not saving, but not greasing.
Mixter is offline   Reply With Quote
Old 01-13-2015, 03:48 AM   #72
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Grease/no grease
it sure is obvious we have all gone stir crazy waiting for Spring to arrive. John
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-13-2015, 05:13 AM   #73
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I agree with you John. Can't wait for my Spring trip.
Ron
Ron A is offline   Reply With Quote
Old 01-13-2015, 05:20 AM   #74
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
How about those pesky windows that won't open with those MM lift latches.
A light coating of silicone grease wiped on the weatherstrip seals will help a lot!!
A great addition to the AS tool box.
Old 01-13-2015, 07:22 AM   #75
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Good idea. I have also put Armorall or similar products on the rubber.
We don't tend to open our windows a lot so they do get stuck at times.
I carry a large suction cup (maybe 4-5"D.) with pull handle and vacuum release in the trailer and if a window is badly stuck, just pull it open from outside. Works well.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-14-2015, 03:10 PM   #76
2015 27' FB International
mesquite , Texas
like brilcream, a lil dab will do ya.
must be a reason they invented grease!
moxie t. moto is offline   Reply With Quote
Old 01-14-2015, 03:18 PM   #77
Originally Posted by NavyCorpsman View Post
Turn your head and cough, maybe?
I leave mine lubricant free. It also serves as a path to ground on the TV in addition to the grounding wire. Grease can electrically insulate or impede that function. I have ruined more than on pair of pants on a greasy hitch too.
x2, I have owned my trailer with an equalizer hitch for ten years and towed at least 50k miles. There is shiny metal but no visible wear on my hitch or ball. I hear my hitch squeak and groan once and a while but I ignore it.
Dirty, nasty grease has a way of flying off metal parts and attaching itself to my hands, shirt and pants without me touching a thing.
handn is offline   Reply With Quote
Old 01-14-2015, 03:29 PM   #78
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I usually put a leftover chicken thigh, boneless, over the ball, and then drop the hitch. Oh wait, wrong forum.
To heck with the greasy or dry balls, we all need to go camping!
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 01-14-2015, 04:05 PM   #79
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Now THERE'S a sentiment I can get behind!
Stephanie
Old 01-15-2015, 09:33 AM   #80
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
For you fellows using vasaline on your balls, you should rub vicks on the outside edges to keep the flies away........
Old 01-16-2015, 07:36 AM   #81
Kevin245's Avatar
We use milk jug material. Just cut the corners from the bottom of an empty jug and set one, or two over the ball before lowering the hitch. They wear fairly well and there's no mess.
Eleanor Roosevelt
Old 01-16-2015, 09:08 AM   #82
mefly2's Avatar
2015 25' FB Eddie Bauer
FWIW, I am watching this thread develop with great interest to see what I'm missing, because I have never greased a ball in my life, and been towing bumper hitches for 26 years....
To me, it looks like a total mess. Of course, this is just my experience, so I'm open minded and waiting to see some compelling evidence that I'm messing something up.
Are you telling us that you do not see any galling on the ball (and hidden on the under side of the coupler)? You must be a very lucky man... as for me, galling is apparent on the coupler from when the AS was towed to the dealer from the factory! Maybe the composition of the metal has changed over the past 26 years ???
It is a lot of pressure on a very small area ~ 800+ pounds on less than a square inch of contact surface... 800+psi ??? ... judging from the wear "spot"/halo at the upper curved surface of the ball surrounding the flat spot on the top. Very little of the ball is in contact with the coupler at any given time - although most of the ball is in contact at some time. YMMV
Grease on the ball, lighter lube on the torsion bar pivots, please. Imagine just how much $$ the 18 wheelers could save it they didn't grease the load plate on their trailer connection to the tractor!
So, what do you do when your ball gets itchy? Leave it dry or more lube; that is your decision? Spring is nearly here - itching to get out; let's get out camping in these beautiful Airstreams.
Old 01-16-2015, 09:47 AM   #83
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Bears
I've heard that the ball grease attracts bears. Isn't there some sort of graphite based lube ?
timhortons is offline   Reply With Quote
Old 01-16-2015, 11:53 AM   #84
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Maybe it's better they focus on the hitch ball. Chum for chumps.
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
