Old 01-11-2015, 09:57 PM   #57
1998 31' Excella 1000
Bellevue , Nebraska
I agree with Mark Doane re; unlocking/unscrewing the ball from the hitch pin bolt. We use Vaseline jelly instead of grease. We had a neighbor who drove a semi tractor trailer and he spent a lot of time grease his 5th wheel on the tractor, I see no difference. Ron
panora2 is offline   Reply With Quote
Old 01-12-2015, 06:30 AM   #58
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
sorry, but dielectric grease is insulating, not conductive.
instead, in some cases, you want an electronic connector lubricant, or a conductive grease.
what dielectric grease does includes protecting the metal from dirt, moisture, and corrosion.
these notes may be helpful - Silicone grease - Wikipedia, the free encyclopedia
and Dielectric Grease vs Conductive Grease
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 01-12-2015, 07:01 AM   #59
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
NoAlox is conductive, but not meant for high pressure.
Old 01-12-2015, 07:47 AM   #60
Kevin245's Avatar
Originally Posted by guskmg View Post
All trailers and TVs need to be connected together by a ground so the lights and brakes will work properly. The pigtail serves this purpose. For those who only depend on grounding through the coupler why not grease the ball with silicon dielectric grease, the kind we used to lubricate ignition distributor parts. Permatex still makes it. This will allow the ball and coupler to ground with each other.
Grounding through the hitch is unreliable and dangerous. Slop in the hitch and coupler typically lead to inconsistent grounding which means inconsistent lighting and inconsistent braking. The umbilical is the correct route for grounding.
Eleanor Roosevelt
Old 01-12-2015, 09:08 AM   #61
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
GREASE and GROUNDED- Grease your ball
My grease technique compared to post #55 by Wingeezer and the Hensley ball TEN grease steps. I am sure that this is a fine hitch, just a bit more effort required to follow.
Equalizer Hitch
(1) Grease Ball
(2) the end
As far as the grounding of the ball and coupler... you have forgotten one thing. Actually two of them:
I have two heavy duty CHAINS connecting the trailer to the tow vehicle. I guess if you depend on the small wire that will engage the trailer's brakes as the only ground connection, you do have a point.
If high temperature wheel bearing grease works for thousands of miles... I might have to get into the tool box and begin to use it to protect my ball and coupler assembly. I think that anything someone uses to prevent damaging your coupler and the ball is positive. How you do it is secondary. Just do something...
Ray Eklund is offline   Reply With Quote
Old 01-12-2015, 10:17 AM   #62
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Wingeezer View Post
Bob,
In case you might not have seen it, here is a simple way to grease the hitch ball when you have a Hensley fitted without needing a trolley jack. I did mine this way last time.
(See info below from Hensley.)
Brian
Thanks Brian...but you know me, rather anal about Hensley maintenance.
It comes off every Fall and re-installed in the Spring, ball greasing is just part of the routine.
Happy Trails
Old 01-12-2015, 11:03 AM   #63
mefly2's Avatar
2015 25' FB Eddie Bauer
Call me a greaser but you better smile when you say that...
Quaker State (golden) chassis lube:
Wipe off old grease from ball - with disposable rag
Spray on some light oil and wipe off again (LPS works great)
Smear on a fresh light coating of QS gold ( I use a screwdriver dipped into the jar of grease)
Hitch up
Repeat for each outing ... cost is very minimal and I don't worry about galling the ball or coupler ... or loosening the ball from turning torque. Cover the ball with commercially made ball cover or we use a large pill bottle cut to fit (actually, the same one for two years now - even stays in place when we roll the TV down the road without the AS).
Old 01-12-2015, 12:58 PM   #64
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We grease the ball with Equal-i-zer grease. It comes in a convenient little tube and is easy to neatly carry & use. Per the owner's manual, we also grease the pivots in the hitch head, into which the spring bars are inserted.
We don't grease the spring bars anymore, as we now use Equal-i-zer sway bracket jackets.
Rocinante is our 2014 International Signature 27FB
Old 01-12-2015, 01:30 PM   #65
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Equalizer Hitch
(1) Grease Ball
(2) the end
Hi Ray,
The difference with the Hensley and Propride hitches is that unhitching the trailer in the normal way does not expose the hitch ball at all, that is why the extra steps.
There is almost no motion at the ball with this type of hitch and really it is questionable if you even need to grease it once a year. I have sometimes left it a couple of years and even then, it didn't really look as though more grease was needed - I cleaned / re-greased it anyway of course.
Some folk add a zerk fitting to the coupler and never do lift it off the ball to grease. I had initially planned to do that, but it is such a simple process to do (takes much longer to describe than to do) that I decided there was no need.
Hitch ball, safety switch cable, chains, none of these provide a good ground IMHO. You have a properground connection via your seven pin connector.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-12-2015, 02:41 PM   #66
2004 25' Safari
2006 31' Classic
Lake Saint Louis , Missouri
I just bought a can of Boeshield T-9 and I am wondering if it would be good for this purpose. It self cleans and applies a dry waterproof lubricant. It was developed by Boeing for Aircraft. Has anybody tried this stuff? I really don't like the idea of having Greasy balls and I appreciate that someone started this thread so that I could say that in a post.
richarus is offline   Reply With Quote
Old 01-12-2015, 02:51 PM   #67
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Grease your Ball for wear and tear?
Thick film needed. High pressure application. Aerosol can products won't work well enough.
Old 01-12-2015, 08:48 PM   #68
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
FLUID FILM - I use Fluid Film on my equalizer, trailer ball and hinges, etc.
http://www.fluid-film.com
Ron
Ron A is offline   Reply With Quote
Old 01-12-2015, 09:45 PM   #69
Mixter's Avatar
1976 27' Overlander
FWIW, I am watching this thread develop with great interest to see what I'm missing, because I have never greased a ball in my life, and been towing bumper hitches for 26 years....
To me, it looks like a total mess. Of course, this is just my experience, so I'm open minded and waiting to see some compelling evidence that I'm messing something up.
Mixter is offline   Reply With Quote
Old 01-12-2015, 10:19 PM   #70
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
What are you saving by avoiding?
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
