Old 01-11-2015, 01:51 PM   #43
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Also, you can but 2 5/16th hitch ball covers. I put one on mine to keep some Grease on it to prevent rust. Also keeps little hands from getting on it painting grease all over the place.
Silverflames is offline   Reply With Quote
Old 01-11-2015, 02:13 PM   #44
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
we use the Reese - Hitch Ball Grease on the ball, and the heads of the WD trunnion bars.
greasing the ball brings the added benefit of keeping the coupler latch lubricated, making it easier to use and minimizing wear.
we store the hitch head coupled and locked onto the tongue, so the grease is not out there to dirty your clothes.
ymmv!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 01-11-2015, 02:40 PM   #45
2014 19' Flying Cloud
Eugene , Oregon
It's true. My boat trailer ball was unwinding from a very well tightened, lock washer-ed stinger. Also, the creaking from my originally not greased AS ball-hitch was excessive. We grease and cover for both reasons, plus the Equalizer bar assembly.
Dave-Nancy is offline   Reply With Quote
Old 01-11-2015, 02:41 PM   #46
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Been greasing trailer balls for the last fifty years , have even gone as far as drilling and installing grease zerts on the top of the coupler to be able to shoot a bit of grease into the hitch and ball every couple of days on long trips without having to unhitch. Chassis grease or wheel bearing grease works just fine .
dannydimitt is offline   Reply With Quote
Old 01-11-2015, 03:48 PM   #47
2004 30' Classic
Hillsborough , New Jersey
greasing hitch ball
Looks like the "greasers" win!!!!!!
wolf146 is offline   Reply With Quote
Old 01-11-2015, 04:22 PM   #48
1981 31' Excella II
New Market , Alabama
Grease is the word.
Perry
Old 01-11-2015, 04:37 PM   #49
2012 30' Flying Cloud
Lake St Louis , Missouri
I use grease, but read a thread that recommended using silicone spray on the ball and a shot into the coupler before each hitch up. Believe the thread was on this forum, but haven't searched. Seems the silicone spray would be cleaner than grease, but don't know if it's better or equal to grease. Anybody using silicone or had experience with it? Thanks in advance.
Barry
WBCCI 11988
AirEgger is offline   Reply With Quote
Old 01-11-2015, 04:44 PM   #50
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The film needs to be thick.
Old 01-11-2015, 05:30 PM   #51
1978 31' Excella 500
Barrie , Ontario
Yes Grease the ball. Other wise it does not let the hitch move freely also cuts down on the creaking and groaning of the metal against metal.
Bev1940 is offline   Reply With Quote
Old 01-11-2015, 05:37 PM   #52
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I spray a little Teflon onto the ball when I think of it. Probably needs more attention then I give it.
TinCan
graysailor is offline   Reply With Quote
Old 01-11-2015, 07:09 PM   #53
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
I find maiden oil works best, but there ya go
JCPOTTERF is offline   Reply With Quote
Old 01-11-2015, 07:16 PM   #54
2007 22' International CCD
My Austrian grandfather always said, "He who greases, travels..."
KE4GNK/AE
Old 01-11-2015, 07:35 PM   #55
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by ROBERT CROSS View Post
Yep.....every time I unhitch....Once a year.
Bob,
In case you might not have seen it, here is a simple way to grease the hitch ball when you have a Hensley fitted without needing a trolley jack. I did mine this way last time.
(See info below from Hensley.)
Brian
Greasing the Hensley Hitch Ball
may 11, 2013 by hensley mfg. 1-800-410-6580 leave a comment
Hensley Hitch with standard jacks.
I promise to make a video of this soon, but a number of you have asked for instructions on greasing the Hensley Hitch Ball. It’s fairly simple and doesn’t require you to lift the hitch head.
1. Hook up to your trailer. Lock the over-center latches but leave everything else unhooked. Leave the tongue jack down.
Hensely Hitch Detail
2. Unlatch the coupler from the hitch ball.
3. Loosen the strut bars until they’re sloppy loose (if you forget to do this, the struts will hold the ball tight against the coupler and you’ll never get it unhooked).
4. Raise the trailer tongue as if you were unhooking from a standard ball hitch. The coupler should lift off the ball. If it doesn’t come off, loosen the struts more or remove them altogether. If that still doesn’t work, you probably have some rust or dirt in the coupler. Get some WD-40 or rust penetration spray and spray up into the coupler. It will work free. If you lube the ball once a year, you should never have this problem.
5. Once the coupler is free, raise it up until you have room to work on the ball. You can pull the tow vehicle forward if you’d like more room.
6. Clean the ball and inside the coupler. Try to get any dirt or rust out of the coupler.
7. Now grease the ball. Any automotive grease will do. Be generous. You can’t over-grease. Use a rag to wipe it inside the coupler as well.
8. That’s it. Now lower the coupler back onto the ball, lock the latch. Many owners actually put a lock through the coupler latch to prevent theft of their Hensley Hitch. Just don’t lose the key!
9. Tighten the struts again. Remember: they should be even on both sides (count the threads) and just tight enough so that the struts don’t rattle when you try to shake them. Check your struts after the next time you tow, they may loosen as the ball settles back into the coupler.
10. That’s all there is to it! Shoot for once a year with this. Thought the ball doesn’t move much inside the coupler with the Hensley Hitch, it does rotate up and down. If it sits for years without lubing, the coupler may rust and damage the ball.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-11-2015, 08:57 PM   #56
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
All trailers and TVs need to be connected together by a ground so the lights and brakes will work properly. The pigtail serves this purpose. For those who only depend on grounding through the coupler why not grease the ball with silicon dielectric grease, the kind we used to lubricate ignition distributor parts. Permatex still makes it. This will allow the ball and coupler to ground with each other.
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
