Old 01-11-2015, 07:26 AM   #29
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Greaser...Fifth Wheel and Slider Grease...available at every truck stop. Used on the ball and contact points for the tension rods on the hitch but not on the actual cams of the anti sway, weight distribution hitch where I use Vaseline simply to reduce noise.
However, on the cams, it has been suggested to spray with aluminum paint as this allows a bit of lubrication without any grease build up and dirt accumulation.
My understanding is grease allows the dirt to be squeezed out of the bearing surfaces. But, regular grease will accumulate moisture and needs to be replaced at regular intervals.
Or so I have been told.....LOL
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-11-2015, 08:37 AM   #30
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Best I've found is Yamalube -- made for dirt bike parts exposed to dirt and grit. Wipe off with paper towel when dirty, keep ball covered between trips, apply a light coat and go. Messy, but not as messy as other grease.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 01-11-2015, 09:38 AM   #31
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
I do not play tennis. I do not play basketball, pin pong or have a billiard table. Those who play these games have access to balls. I don't have any balls that will fit over the ball to protect it from the weather.
I do have some baseballs. Soft and hard ones. I do not think it practical to try to take either of these balls apart to cover the hitch ball. At some parking lots I see those pickups with the hitch and ball sticking out from the bumper 10 inches or so. It is a shin knocker. You have to avoid them, unless there is a bright yellow or now green tennis ball to "protect the ball" from, what? My shin bone?
Why not just pull the hitch and ball and store it at home? When we park the trailer, I take everything and put it into the back of the pickup. You never know when someone has no ball(s) to use of different diameters. The Airstream balls will not fit the trailer balls pulling ATV's, a boat or a UHaul hauling leaves.
My wife is responsible for the interior of the tailer. The ball selection and greasing is my job. When am backing up to attach the trailer, she will align the ball to the coupler by giving me hand signals. Sometimes she might say something... but lining up the truck to the trailer is helpful having a second person aligning the ball, the driver and the trailer coupler as a package deal.
I found that after four or more years it was time to swap balls. With the hitch in mind and keeping it from wearing. Most any hardware store has a wide selection of balls to choose from. Make certain that you know your balls, as the Airstream has an odd one.
So far there seem to be more trailer owners that grease their balls to tow. Wax paper is next and maybe a couple using plastic to protect their balls from wear and tear. There seems to be no consensus about ball protection. The coupler is much more important than balls, as the ball is inexpensive and readily available.
Up to this point. Nobody on this thread knows any more about balls than I do.
Ray Eklund is offline   Reply With Quote
Old 01-11-2015, 10:05 AM   #32
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I agree with STEVEH, "Save the coupler"
I was a firm believer in not using grease or any lubricant until............ I saw the top of the ball working its way through the coupler on a work trailer. Unless you take calipers to your coupler do you know how much wear has occured? Or will you wait until you can see the ball through the coupler?
Sam
samb is offline   Reply With Quote
Old 01-11-2015, 11:22 AM   #33
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I know a lot about balls also,mine are all the same size, for the As and my car trailers. All my balls get greased every trip, when I unhook I use an old rag and wipe it off. When installing new grease on the balls , I use my finger being very careful not to get any on me or my clothes. My airstream book says to grease the afore mentioned....Now don't get any on you...
Old 01-11-2015, 11:30 AM   #34
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I grease ours and keep it covered. A good friend of ours uses a very different method: He cuts out a chunk of plastic milk carton, folds it over the ball, and drops the hitch on it dry. Seems to work, too.
Lynn
WBCCI 21043
Old 01-11-2015, 11:48 AM   #35
Mineral Bluff , Georgia
Funny, just did this yesterday, getting our CampLite ready for our DL trip.
I brush high-pressure red grease on with a paintbrush, after cleaning old grease and grit off with Gunk. Hitch ball and both ends of the sway control bar. Even a little on the hitch itself where it slides into the receiver, mainly to prevent rust.
The selling dealer said it wasn't important. After driving just one day without grease the chrome on the ball already had a worn spot.
Direct metal-to-metal contact on a moving part under stress is just general not a good idea.
FastEddieB is offline   Reply With Quote
Old 01-11-2015, 12:02 PM   #36
Goal15's Avatar
Dallas , Texas
I use super glue to keep the ball on my foot . . . confounds defenders . . . Maybe I should try grease to help me give'm the slip. Oh, wait wrong forum!
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 01-11-2015, 12:07 PM   #37
Goal15's Avatar
Dallas , Texas
I give both the hitch ball and the trunnion bar receivers a squirt of lithium grease prior to each trip and during trip if it rains
Dana and Olga
2006 Safari 23
Old 01-11-2015, 12:18 PM   #38
2007 27' Classic FB
Ridgefield , Washington
A Tech at Airstream told my Wife about the wax paper method. I would prefer to use grease but its hard to win an argument when she has Airstream on her side. (and a couple pair of trousers with grease stains) Two things about using waxed paper. The paper has for the most part disintegrated by the time we arrive at our destination. The other is, with the paper coming apart, I have had to remove a good amount of waxed paper debris out of the coupler from time to time.
John & Lisa
Woosch is offline   Reply With Quote
Old 01-11-2015, 12:44 PM   #39
Ray Eklund's Avatar
Hey... Eubank. Did you know your milk's freshness date was April 20th? Would that affect the quality of the plastic? Wow... and Raw Milk. I think in Colorado it would be contraband... while you can purchase all of the Pot you can afford.
Is there that much space in the coupler to handle inserting a section of plastic?
Old 01-11-2015, 12:51 PM   #40
SteveH's Avatar
Common Sense , Texas
I've tried the wax paper and the milk carton plastic, and both were on my smaller Casita trailer. Both were gone, worn thru, with scratch marks on the ball at the end of 500 miles.
They are both good ideas that simply will not stand up to the pressures applied, especially if you have a heavy tongued Airstream.
Regards,
Steve
Old 01-11-2015, 01:15 PM   #41
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Grease your Ball for wear and tear?
Buy grease in a tub and wipe the ball clean when you unhitch. How hard is it?
Same for departure. At every one it is required to check lug nut torque and tire pressure. Re grease the ball. Store all those things together. Gloves, paper towels, etc.
Old 01-11-2015, 01:51 PM   #42
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Yep.....every time I unhitch....Once a year.
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
