Old 01-10-2015, 07:59 PM   #15
SteveH's Avatar
Common Sense , Texas
I don't lubricate mine to save the ball, I lubricate to save the coupler.
Regards,
Steve
Old 01-10-2015, 08:09 PM   #16
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by slowmover View Post
With the HA we grease the ball at assembly.
Yep. Was going to say that but figured it was a given.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-10-2015, 08:14 PM   #17
sandlapper's Avatar
1993 34' Excella
York , South Carolina
x2.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-10-2015, 08:15 PM   #18
Southwestern , Ohio
For others, what does Airstream and what does the hitch manufacturer say?
The fact that Reese sells hitch ball grease might tell you something. . .
White Grease Hitch Ball Lube Reese Accessories and Parts 58117
Nuvite-F is offline   Reply With Quote
Old 01-10-2015, 08:19 PM   #19
NukeSubSailr's Avatar
2010 20' Flying Cloud
Surry , Virginia
My owners manual from Equal-izer said to put a light coat of grease on the ball, so I do.
NukeSubSailr is online now   Reply With Quote
Old 01-10-2015, 09:04 PM   #20
ottawa (greely) , Ontario
I grease the ball with wheel bearing grease ,all it takes is a little dab ,it also stops rust . a simple ball cover on the ball stops the grease from getting on your pants.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-10-2015, 09:05 PM   #21
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
A quart size zipper zip lock bag zipped on your greasy b sure helps save from lubricating your personal parts you might not want lubed. Quick too.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-10-2015, 09:09 PM   #22
1981 31' Excella II
New Market , Alabama
I use spray on lithium grease. You need something to lube that ball. You will get accelerated wear without grease not to mention potential binding or as was said above, it could lead to the ball coming loose. You will eventually cause the coupler to wear out and become loose.
Perry
Old 01-11-2015, 03:37 AM   #23
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I apply grease with an old toothbrush which would otherwise be useless. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-11-2015, 04:57 AM   #24
dznf0g's Avatar
Oswego , Illinois
A Friend of mine owns a turf business and he has a utility trailer he never greased. After many miles the top of the coupler had a "smiley face" hole completely worn through. It was about 120* around the front of the coupler head at the contact point with the ball. Grease 'em!
-Rich-
Old 01-11-2015, 05:55 AM   #25
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Airstream...ball & socket,cleaned/greased every Spring when the Hensley gets re-installed.
Boat...wiped clean, thin layer on the ball and a dab of grease inside a split tennis ball.
Old 01-11-2015, 07:01 AM   #26
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Prior to our Hensley, Teflon grease seemed to be the most effective, the easiest to apply and the easiest to clean off. After unhooking, a couple of sheets of those blue shop towels easily cleans the dirty grease on your ball and the ends of your spring bars - regrease prior to hooking up the next day.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 01-11-2015, 07:05 AM   #27
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Clean the coupler!
I'm a greaser I keep the ball covered with a zip bag when I'm not towing.
That grease accumulates in the coupler and attracts a lot of grit. About once a year I wipe the accumulated grease with paper towels then further clean the coupler with spray can brake cleaner before re-applying new grease.
Alan
Old 01-11-2015, 07:22 AM   #28
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I use the wax paper method for a small luggage trailer I built to tow behind our motorcycle - seems to work fine and no mess.
As for the AS trailer, we use a HA and I lube it every couple of years as per manufacturer's instructions.
Although with the HA, there is not any horizontal rotation on the ball, I guess there is slight vertical rotation, hence the recommendation to lube.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Reducing wear and tear on Propane Tank and Storage plate ghaynes755 LP Gas, Piping, Tanks & Regulators 3 06-16-2014 06:14 PM
Belly Pan Wear & Tear TinLoaf Belly Pans & Banana Wraps 4 03-06-2012 12:34 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
This may bring a tear to your eye ROBERT CROSS Vintage Kin 5 01-16-2009 06:00 PM
Ball Grease or Not? rickandsandi Hitches, Couplers & Balls 30 10-26-2006 09:16 AM
