Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-03-2005, 07:35 PM   #1
BigAl
Profile:  1994 30' Excella
Mississauga , Ontario
grease seals for wheel spindles
I hope this posts all right. Tried before and didn't see it in the forum.
I have a '94 excella with twelve inch brakes. Does anyone know the part number for the grease seals required when repacking the wheel bearings?
Al
Old 04-03-2005, 07:55 PM   #2
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Good question. While we are at it I need to repack the bearings on our 31' 2003 Classic. What type of grease to use and what are the part numbers for the grease seals. Oh yea, how much do they cost for all four spindles? Anybody!
Tinsel Loaf is offline   Reply With Quote
Old 04-03-2005, 08:14 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Dexter 12" drums use a 2.25" seal. The best seal (double lip, spring loaded) costs $1.69 from Low Cost Trailer Supplies. Get a dozen. http://www.lowcosttrailersupplies.co...s/a-10-36.html
Non-contributing deadbeat.
Old 04-03-2005, 08:23 PM   #4
markdoane
Images: 59
Here are recommended greases from Dexter Axle service manual:
http://i.b5z.net/i/u/1080235/f/6-8K%...talog_3-04.pdf
Recommended Wheel Bearing Lubrication Specifications
Grease:
Thickener Type ............................................. Lithium Complex
Dropping Point ............................ 215 degC (419 degF) Minimum
Consistency .................................................. ....... NLGI No. 2
Additives ............................ EP, Corrosion & Oxidation Inhibitors
Viscosity Index .................................................. .. 80 Minimum
Approved Sources:
Mobil Oil ..................................... Mobilgrease HP, Mobilith AW2
Exxon/Standard .................................................. ... Ronex MP
Kendall Refining Co. ........................................... Kendall L-427
Ashland Oil Co. ................................ Valvoline Multipurpose GM
76 Lubricants ................................................. 76 Multiplex EP
Citgo Petroleum .............................................. Lithoplex MP#2
Mystik.......................................... Mystik JT-6 Hi Temp Grease
Pennzoil Product Co. ............ Premium Wheel Bearing Grease 707L
Old 04-04-2005, 09:52 AM   #5
BigAl
Thanks for the info. Does that mean that the brake assemblies are Dexter? How would I check for sure?
Al
Old 04-04-2005, 10:43 AM   #6
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Thumbs up
Do any of these specs apply to the Henshen(sp?) axles on the newer Airstreams?
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 04-04-2005, 04:21 PM   #7
markdoane
Images: 59
BigAl & RivetED,
I'm going with what I've heard elsewhere, which is that Henschen axles use Dexter hubs and drums. Can't be sure that they don't make their own, or use someone elses.
I sure someone else can provide the info.
Even if they are Dexter hubs, it's possible that the spindle is 2.125" instead of 2.250". Dexter uses a 2.250" spindle, but Henschen's might be 2.125". ??? If that's the case, there is a different seal, also listed at the web site above.
You can measure the spindle, or if you report the inner bearing numbers on your axle, I could look it up for you. .
Old 04-16-2005, 01:08 PM   #8
Loren
Loren's Avatar
Profile:
Originally Posted by markdoane
BigAl & RivetED,
I asked this question at the Airstream factory during the tour a few days ago (mid-April 2005). The axles are Henschen, but all the brake parts are Dexter. I didn't ask about spindles.
I just replaced a grease seal on one of my 12" brakes. I ordered the part from a Dexter supplier, Haskin's Hitching Post in Cincinnati. Their phone number is 513-542-1733. The double-lip seal that they recommended was part number 10-36. The single-lip seal is part number 10-54. I ordered two of the double-lip seals. They came to about $13, delivered to my door. Mark got a better price.
Loren
1997 - 34' Classic Limited Front Kitchen.
2000 Dodge 2500 diesel with Pulliam Pull-Rite hitch.
Loren is offline   Reply With Quote
Old 04-17-2005, 01:34 AM   #9
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I took my old seal to my trailer supply, it was a 2.250" seal they matched it up and I bought enough to do the trailer plus one. Save one old seal and use it to assist in putting the new one in.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Fuzzy Window Seals Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 29 07-28-2007 07:48 PM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
Seals and Weatherstriping niftypkg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 10-29-2002 09:40 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
Window Seals niftypkg Windows & Screens 0 06-14-2002 06:39 PM
