Old 05-21-2012, 08:41 PM   #1
GD
2007 27' Classic FB
1960 17' Pacer
Bozeman , Montana
GMC Sierra brake controller
We just bought a GMC Sierra 2500 I hooked our 27FB Classic and noticed that the output signal to the trailer was dashes. In the owners manual it indicated that the controller only worked with electric breaks. Has anybody used an after market break controller on their 2012 GMC Sierra 2500?
gduff is offline   Reply With Quote
Old 05-21-2012, 08:56 PM   #2
Connellsville , Pennsylvania
I don't have a specific link for info for you, but many have added the MaxBrake electric/hydralic brake controller instead of the factory offering. I personally love it in my Dodges.
Midnightmoon is offline   Reply With Quote
Old 05-22-2012, 03:06 AM   #3
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
My understanding is that if you've got disc brakes the built-in brake controller won't work. I will say that the one that came built into my 2012 Suburban 2500 (probably the same as in your truck) works just fine with my trailer with it's drum brakes.
If/when I upgrade the brakes to discs I'll be bypassing the factory unit for the Tekonsha P3 that I took out of my old Suburban. It's definitely doable but it's probably complicated for someone (like me) without the requisite technical knowledge. I plan on having the hitch/towing shop do the installation.
phbarnhart is offline   Reply With Quote
Old 05-22-2012, 07:18 AM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
?? yes, since it's electric, it only works with electric brakes. Not e.g. mechanical / hydraulic "surge" brakes, etc. And as noted above, some have reported issues with Kodiak disk brakes. If you have disk brakes, there is some sort of a workaround for this; do some searching. My GMC Sierra 2500 brake controller works great with my (drum, electric) brakes. The really nice thing about it is that the controller reads brake master cylinder pressure, which translates to it reading actual brake pedal pressure, so it "knows" what you are wanting to do, rather than reading deceleration and "knowing" what you actually ARE doing.
AirsDream is offline   Reply With Quote
