Old 10-27-2017, 11:00 AM   #1
Lynnsr
lynnsr's Avatar
2018 20' Flying Cloud
Colorado Springs , Colorado
Generator mounting ideas
Has anyone found a way to attach a small generator on the rear of a Air stream
Lynnsr
lynnsr is offline   Reply With Quote
Old 10-27-2017, 12:01 PM   #2
2007 22' International CCD
There is a basic problem with mounting anything to the rear of an Airstream. The construction of the frame and shell does not have enough strength to do so successfully. The design uses the shell to hold up the frame somewhat, and extra weight can easily make it sag.
There is also an issue of stability--weight that far to the rear causes possible instability because it reduces tongue weight and can make the rear end too heavy.
There have been many documented cases of trailer sway caused by adding too much weight to the rear end. Best place for a generator is inside the Tow Vehicle, mounted over the A-frame, or simply carried in the AS forward of the axles...
I have a smallish (3200 Watt) dual fuel Champion Inverter generator--it lives in the bed of my pickup under a tonneau cover when in motion, and chained down when in use as far as I can get it from the AS.
Old 10-27-2017, 01:43 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
If you are near a good welding shop they would be able to fabricate a rack to mount your generator on the tongue between the propane cover and the AS. I know that Can-Am RV in London, ON makes and installs them.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 10-27-2017, 02:24 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've carried a Honda 1000i on my 2007 20' strapped to the top of my battery box. A 2000 would fit, but it risks wearing the front panel of the Airstream if you take the generator out a lot. I pop riveted aluminum angle iron to make a track for the gen so it wouldn't slide around. NY to AK and return with no problem.
2012 Dodge Durango Hemi/AWD
Ideas for roof mounting Omni antennas w/o crank up TV antenna? dustent Electronics & Connectivity 14 01-05-2019 08:48 PM
Ideas for roof mounting Omni antennas? dustent Electrical - Systems, Generators, Batteries & Solar 1 08-04-2016 08:53 AM
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Bumper Storage Compartment Door Mounting Ideas dbj216 Exterior Storage Compartments & Access Doors 9 07-23-2015 09:58 AM
Mystery Mounting Points ??? Any Ideas Bootsinister All Argosy Trailers 5 04-28-2012 01:32 PM
