Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-15-2006, 03:40 PM   #1
Double D
Profile:  Currently Looking...
Grand Rapids , Michigan
Gear ratio
Does anyone know how I can find out what my gear ratio is on my TV? I checked the owner's manual- no luck. Someone told me to look inside the glove box for a sticker. THhere's one there alright, with LOTS of numbers but nothing resembling a gear ratio.
I've got a 2002 Yukon Denali.
Thanks!
Double D is offline   Reply With Quote
Old 02-15-2006, 03:43 PM   #2
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
mine is on a tag under the hood. might check there, as well.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-15-2006, 03:46 PM   #3
Double D
HEy, thanks. I'll look!
Old 02-15-2006, 04:39 PM   #4
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
If you can't find a tag telling you, a surefire way is to take it to a level parking lot, put it in neutral and turn it off. Take a couple of your stronger friends with you. Crawl under it. Put a grease pencil mark on the drive shaft, and also put one on the inside side wall of one of the rear tires. Have your big friends slowly push it forward while you crawl along with it. Count the revolutions of the driveshaft while you make one complete turn of the rear tire.
For example: You mark the rear tire at the 6 o'clock position, straight up from the ground, dead center at the bottom. You then mark the driveshaft. As you skinny along under the truck while your buddies push it by hand, count how many turns the drive shaft makes until your tire mark is back in the same place it started. In our example, at the bottom. If the driveshaft turned about three and 3/4 turns, you've got a 3.73. If it turned a little over four turns, you've got a 4.11, and so on.
You can't just jack the wheels up because the differential slip will allow the wheel to rotate independantly of the driveshaft. Unless you've got positraction, that is.
Now, if you can somehow see the driveshaft without getting under the truck, all the better. You could also have someone you really really trust pull the truck forward one revolution with you under it counting, but I wouldn't recommend that. If it's got posi's, then you can just jack it up and turn the driveshaft by hand until the wheel makes one turn. But if you can determine if it's got positraction, you can probably find the ratio
My truck has it printed on a label inside the glove compartment. You might look there too.
Good luck,
- Jim
JimGolden is offline   Reply With Quote
Old 02-15-2006, 05:25 PM   #5
Partsman
1985 Avion 34v
Partsman's Avatar
Profile:  Fountain Inn , South Carolina
Axle Ratio
You will probably not find a ratio number in the glove box, but all those numbers and letters mean something. So, go to this site and look through all these numbers until you find one that matches a number on you tag. This is a list of RPO's, that is, regular production numbers. It may look confusing but if you print out the page and take it out to your favorite TV you should be able to figure it out for yourself.
http://www.drivetrain.com/GMtrkratio_posidata.html
Have fun and you will be learning something new about your vehicle too!
Chris
Partsman is offline   Reply With Quote
Old 02-15-2006, 05:48 PM   #6
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
You can also take you VIN number to your friendly GM parts counter and ask for a Build Sheet Print out. It will tell you everything that came on the vehicle from the factory including the rear end ratio...assuming a PO didn't change it
Aaron
WBCCI #2449 AIR #2495
Old 02-15-2006, 06:46 PM   #7
Double D
Good luck,
Wow, very interesting. Sounds like something maybe I could get my daughter's boyfriend to do! Thanks!
Old 02-15-2006, 06:46 PM   #8
Double D
Chris
Thanks, will take a look!
Old 02-15-2006, 06:47 PM   #9
Double D
Aaron
This sounds the best yet! Thanks!
Old 02-15-2006, 07:00 PM   #10
62 Overlander
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
Don't know if GM is the same but on Ford there is a metal tag attached to the differential cover. It will tell the ratio and if it is a limited slip or not. Example would be 4.10 L meaning 4.10 ratio with limited slip.
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Old 02-15-2006, 07:51 PM   #11
davidh
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
Double D, There should be a steel tag on the rear end housing where the rear cover bolts to the housing if not on the back check the the front. you will find the info you need, if it is missing just jack up one side of the rear wheels and mark your drive shaft and rotate jacked up rear wheel and count the revelations of drive shaft to one full revelation of wheel.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-15-2006, 08:38 PM   #12
Double D
Cool, if we don't get the 1 to 4 of snow and 1/2 inch of ice predicted tonight, maybe I'll crawl under there a take a peek! Thanks!
Old 02-15-2006, 08:39 PM   #13
Double D
Thanks. Can you explain limited slip?
Old 02-15-2006, 09:10 PM   #14
basecamp
basecamp's Avatar
Profile:  1996 30' Excella
Bowmanville , Ontario
check the glove box, this is where GM lists the option content. Unless this truck was a special order I doubt that it has a 4.10, more likely a 3.73(GT4)
Hensley Hitch, Jordan controller
basecamp is offline   Reply With Quote
gear ratios RVNUTTY Towing, Tow Vehicles & Hitches 11 09-04-2004 03:38 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
Add Running Gear Links Here Action Link Archive 2 09-13-2002 08:01 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
