Old 08-07-2016, 05:05 PM   #1
2016 30' International
Sarasota , Florida
Fuse for power jack
I am told the fuse for the power jack is a 30 amp slow blow glass fuse. I cannot find one anywhere, including stores, Amazon, or any internet merchant. Is there such a fuse? I can find fast blow fuses in this category, but no slow blow.
minddr is offline   Reply With Quote
Old 08-07-2016, 05:16 PM   #2
2016 25' Flying Cloud
Holly Springs , Mississippi
They're available thru NAPA--usually not a stocked item, but can be at the store within a day. I'll get the part number next time I'm at the trailer. I suggest getting the five to a package; it was about $7.50.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 08-07-2016, 05:43 PM   #3
Sarasota , Florida
I went to Napa and they said they did not carry them! Did you find slow blow or fast blow"
Old 08-07-2016, 05:47 PM   #4
Sarasota , Florida
I just searched their online store without any luck
Old 08-07-2016, 05:47 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
http://www.alliedelec.com/bussmann-b...tmihoCMJbw_wcB
or
https://www.amazon.com/BUSSMANN-EATO.../dp/B011NBNTSY
If it was me, I would go by the automotive supply store and buy these. Not the slow blow, but will do the job.
http://shop.advanceautoparts.com/wcs...p_pri_larg.jpg
edit:
Found these at NAPA, called time delayed, not slow blow.
https://www.napaonline.com/napa/en/p...335/BK_7821335
Alan
Old 08-07-2016, 05:55 PM   #6
SMLJeep's Avatar
2017 27' Flying Cloud
Moneta , Virginia
I sent a email to the manufacturer and they sent me some at no cost.
SMLJeep is offline   Reply With Quote
Old 08-07-2016, 07:16 PM   #7
Sarasota , Florida
or
edit:
Thanks for the information. The voltage rating seems to be 32 volt. Is this correct or do I need one rated for 240 volt?
Old 08-07-2016, 08:08 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My local NAPA stocks them. They are made by Balkamp, Inc. packaged for NAPA. I have a pack in my hand as I type this.
782-1335 MDL-30. QTY-5
MICHAEL
Old 08-07-2016, 09:06 PM   #9
CruizinDux's Avatar
Tracktown USA , Oregon
If you have a Barker Jack, call them they'd be glad to send some. NAPA has them, although my 2X5 packs were next day. Seems it cost me about $7 per pack...kinda doesn't matter tho.
other sources are in this thread...as well as a discussion re conversion to the blade type which are easier to find.
http://www.airforums.com/forums/f44/...ml#post1795027
and
https://www.amazon.com/Bussmann-MDL3.../dp/B00139MFXM
they may look different than the OEM's
CruizinDux is offline   Reply With Quote
Old 08-07-2016, 09:13 PM   #10
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Barker just sent me three...no charge.
Mike
Caffeinated is offline   Reply With Quote
Old 08-07-2016, 09:23 PM   #11
Southwestern , Ohio
No, the jack runs off of 12 Volts DC so the 32 Volt fuse rating is fine.
Nuvite-F is offline   Reply With Quote
Old 08-07-2016, 10:05 PM   #12
Sarasota , Florida
Old 08-07-2016, 10:05 PM   #13
Sarasota , Florida
Ok, makes sense, thanks
Old 08-07-2016, 10:50 PM   #14
Long Island , New York
To echo Bob's earlier link to a specific post, this thread has lots of leads:
http://www.airforums.com/forums/f44/...se-151073.html
including details about some NAPA clerks not finding the slow-blow fuse in stock on first try.
Power jack getting power. OffTheCouch Electrical - Systems, Generators, Batteries & Solar 11 01-01-2016 12:39 PM
Barker High-Power Jack Blows Fuse While Driving Woodguyco Jacks, Stabilizers, Lifting and Leveling 23 09-19-2015 10:15 PM
Blowing fuse on Power jack. StreamRollin Electrical - Systems, Generators, Batteries & Solar 36 07-19-2015 11:10 PM
Help please re power jack fuse/breaker AFUser Electrical - Systems, Generators, Batteries & Solar 4 06-11-2014 07:28 AM
power jack keeps blowing fuse? jlemmons Jacks, Stabilizers, Lifting and Leveling 6 08-01-2009 11:38 AM
