08-08-2016, 08:30 PM
#21
Cloudland2
2016 25' Flying Cloud
Trenton
, Georgia
Originally Posted by minddr
I am told the fuse for the power jack is a 30 amp slow blow glass fuse. I cannot find one anywhere, including stores, Amazon, or any internet merchant. Is there such a fuse? I can find fast blow fuses in this category, but no slow blow.
If you have a 2016, you may have an Atwood jack instead of a Barker. Barker may use a special fuse. My 2016 has an Atwood and I took the fuse out it is a standard 30 amp glass fuse, not a slow blow. Check yours and see.
08-08-2016, 11:16 PM
#22
Salem
, Oregon
Originally Posted by ROBERTSUNRUS
Hi, I installed a 30 amp self re-setting circuit breaker on my tongue jack.
Originally Posted by featherbedder
I don't like self resetting fuzes, as blowing fuze and auto reset could cause further damage to item connected to.
Hi, it's not a fuse; It's a circuit breaker with the same rating as the fuse, so it won't / can't cause any damage. I have been using these since the early 70's as a Lincoln - Mercury mechanic and never had a problem.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-09-2016, 12:17 AM
#23
Erie
We had the exact problem on our 2017 Classic. The ground wire was attached to a screw with some paint on it. We just scraped off the paint, reattached the ground wire and it has worked perfectly ever since. So I'd check the ground wire. You need to fully remove the cover to do so but it's a 10 minute fix if that's the problem. Hope it helps
Beth & Lori
Newbies with a 2017 Classic
Change = Opportunity
08-09-2016, 05:37 AM
#24
Mantua
, Ohio
Try Ace hardware for fuses.
08-09-2016, 06:55 AM
#25
Curtis Wright
Eyren Haven
, South Jersey
MDL 30 is the designation to ask a NAPA clerk. They will never find slow blow fuses or delay fuses on the computer. Technically, MDL are fine for DC.
08-09-2016, 07:53 AM
#26
Durango
Had to replace a tongue jack on my car trailer recently and found that the vast majority on the market are Chinese. I too use a 30 amp reset fuse. However, it doesn't make any difference how it's grounded or fused, the motors are crap. Be sure you understand how to use the crank to raise and lower your trailer before leaving home.
If you don't go first class, your heirs will!
08-09-2016, 12:19 PM
#27
Salem
, Oregon
Hi, when my tongue jack failed, on the opposite side of the country, I was glad that I had a bottle jack with me to get un-hitched, so I could go buy another one. [tongue jack]
08-10-2016, 12:45 PM
#28
2015 27' FB International
Seminole
One last thought- If you change the design of your electrical system (AKA, using different components than originally installed) make sure that you know the potential consequences. Voltage ratings determine whether the fuse or CB can safely open the circuit at the specified current and time. DC ratings will always be much lower than AC. If not rated for DC?????
The length of the time delay on either fuses or CBs is important and must be coordinated with the protection ahead of it in the circuit, because you can potentially cause a fire in the wiring ahead of "your protection".
From my personal experience, CBs are never as reliable as fuses. They are mechanically activated devices. Large CBs are controlled electronically and yet they still protect the CB with fuses.
In the end, if you guess wrong and have a fire, it will be between you and the insurance company experts to decide whether you guessed right.
IMO Never guess.
06-27-2017, 09:20 AM
#29
2012 27' Flying Cloud
Miami
Originally Posted by CruizinDux
I just went to three auto parts stores trying to find a 30 amp slow burn fuse for the Barker hi-power 3000 lift jack on my 2012 flying cloud 27 fb and could not find one. When I called Barker, they were very gracious and agreed to send me some fuses for free. They said that in the interim I should use a 40 amp glass fuse, not a 30 amp standard glass fuse.
I post this to echo the sentiments of Bob, above, and to confirm that Barker is still providing this kind support as of June 2017
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Power jack getting power.
OffTheCouch |
Electrical - Systems, Generators, Batteries & Solar |
11 |
01-01-2016 11:39 AM |
Barker High-Power Jack Blows Fuse While Driving
Woodguyco |
Jacks, Stabilizers, Lifting and Leveling |
23 |
09-19-2015 09:15 PM |
Blowing fuse on Power jack.
StreamRollin |
36 |
07-19-2015 10:10 PM |
Help please re power jack fuse/breaker
Namron Yaf |
4 |
06-11-2014 06:28 AM |
power jack keeps blowing fuse?
Jetset Jenna |
6 |
08-01-2009 10:38 AM |
