Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-14-2006, 04:01 PM   #1
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Fuel Additives?
What's the story on Diesel fule additives like Diesel-Kleen, etc?
Are they just a waste of money, or do they make a difference?
Michael
1998 Ford E350 7.3L TD
ArtStream is offline   Reply With Quote
Old 02-14-2006, 04:16 PM   #2
2airishuman
2airishuman's Avatar
Profile:
added for what?
hi art
any of the truck/diesel forums will have massive digital piles on fuel additives. there are a few bits here too.
some additives alter gel point, others boost lubrication, others increase cetane rating, others clean stuff, some absorb water or segregate it, some are fungicides.....and so on.
i use stanadyne because charles on the powerstroke forums told me too
and because it boosts cetane (the most) and lubes and does all that other good stuff...
as i understand it ford is or will be selling the stanadyne under the ford label.
now comes the testimonials..........
so put your tall boots on.....
it also seems to boost my mgp from 1-2 mpg....so when i factor fuel cost + additive cost....it becomes economical....
for reference, i do not have deer sonar things or the air torando on my truck
i spent a few weeks and a few 1000 miles conducting my own trials with it before concluding it was useful...
cheers
2air'
Name:	weird science.jpg
Old 02-14-2006, 05:07 PM   #3
davidh
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
2airishuman You hit the nail right on the head cannot say it any better than that..
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-14-2006, 06:31 PM   #4
Jim Jarzabek
NOT A COMMERCIAL VENDOR
Commercial Vendor
Jim Jarzabek's Avatar
Profile:  1950 25' Cruiser
Lebanon , Ohio
Images: 16
Thumbs up Seafoam works great for gasoline engines...
My experience with gasoline large V-8 engines is that most do not run hot enough to completely burn the fuel because low temperature thermostats are installed in the cooling system. This leads to unburned fuel and soft carbon deposits in the intake system that cause the engine to continue to run after being shut off. The first thing I do when I buy a used gas vehicle is to change the fuel filter (along with other filters) and add Seafoam to the gas tank. At the same time I change the oil & filter & add a can of Seafoam to the crankcase with the new oil. I then change the oil again after 1000 miles. It usually is black with dissolved carbon. Performance and gas mileage is increased and the "dieseling" usually stops
Jim Jarzabek is offline   Reply With Quote
Old 02-14-2006, 07:02 PM   #5
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Mmo
I put Marvel Mystery Oil in my Goldwing and got 4mpg better hauling a passenger than I got riding solo. It seemed to pick up better also. Is it witch's brew or just automatic transmission fluid? You tell me, but I've tried it several times and it always worked.
- Jim
JimGolden is offline   Reply With Quote
Old 02-14-2006, 07:58 PM   #6
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Artist , at Large
Smile
Originally Posted by 2airishuman
hi art
cheers
2air'
Gee, just think of the mileage you could get if you put the air torando and deer sonar things BACK ON
Art
Fuel Consumption: (curious) Drew Airstream Trailer Forums 15 12-26-2002 06:28 PM
cat. heater's fuel supply-Inside?? pebblepoint Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-15-2002 04:02 PM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
fuel pressure PeterH-79MH Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
