Old 05-02-2017, 08:07 AM   #1
2007 25' Safari
Southwest VA , Virginia
Front receiver for bikes?
On my 2009 Tahoe, would this be a good idea? I can't envision it, but I seriously don't know where to put the three bikes. Hubby says inside the trailer while towing. But I just do not want to do that at all.
Hopeful1 is offline   Reply With Quote
Old 05-02-2017, 08:30 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
This is one recent thread, there are several more,
http://www.airforums.com/forums/f238...er-161552.html
MICHAEL
Old 05-02-2017, 08:58 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have a rack on the back of the trailer and a front receiver also. Not sure about 3 bikes forward because of lights, vision and cooling questions.
The real advantage of the front receiver is once you are camping it is easy to take the bike off site for the day.
One thing to keep in mind. If you buy a standard bike rake and mount it forward it will sit very high. I had to cut down the rake I mount forward by almost 10 in. to be able to see over the bikes.
2004 Excursion 4x4
Old 05-02-2017, 10:40 AM   #4
2007 25' Safari
Thank you!
Old 05-02-2017, 10:43 AM   #5
Long Island , New York
In addition to Michael's link here are some search results for "front bike rack" --
https://www.google.com/search?q=fron...=airforums.com
The search function in the blue box above works very well to sift through all the information here.
FYI rear bike racks are limited in weight by Airstream to 70 pounds incl. bikes I believe.
Good luck!
Peter
Old 05-02-2017, 11:33 AM   #6
2007 25' Safari
Thank you!
Old 05-02-2017, 11:38 AM   #7
1986 31' Sovereign
Miami , Florida
Carried two bikes on the front of my bike for years. Only two downsides; the bikes get really dirty, buggy. And, the bikes partially occlude the headlights so are probably not legal at night -- we never tow at night so it wasn't an issue for us.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-02-2017, 11:53 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a front receiver on my Tundra to carry a 2 bike carrier.
It is a Curt brand front receiver that was less than $100 on Amazon and literally a 10 minute install with the existing tow hook bolts. Remove bolts and tow hooks and re-install them with the receiver sandwiched between the truck's frame and the tow hooks. Easy.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-02-2017, 03:33 PM   #9
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
I am an unabashed customer of the Arvika rack. Picture attached. They do have a 3-bike model. Check them out at www. Arvika. ca. Canadian company. BTW, they have a specific Airstream model as ahowm
ID:	284599   Click image for larger version
banderabob is offline   Reply With Quote
Old 05-02-2017, 08:24 PM   #10
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I've been carrying one or two bikes in front of my 2000 Tundra for several years. I take the seats off the bikes and position the bikes so that the handlebars are on the passenger side. No vision problem whatsoever. Big advantage for me is that I have two trailers; no need for a bike carrier on each trailer when I have one on my tow vehicle. Plus, I take seriously what many have said regarding adding extra weight to the rear of an Airstream.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
Old 05-03-2017, 10:51 AM   #11
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I mounted a front receiver on my 2004 RAM 2500. Then put a Thule rack on it. Then I started dragging it when going into parking lots. Then I took it off, and now it all sits in my shop.
SuzyHomemakr is offline   Reply With Quote
Old 05-03-2017, 11:53 AM   #12
m.hony's Avatar
2013 30' Classic
I have never bottomed out my bike carrier mounted in a front receiver.
I have, however bottomed out the back of the trailer while the bikes were on the front...
TAC #MS-10
Airforums #70955
Old 05-04-2017, 06:15 AM   #13
2007 25' Safari
I love the tips, links, and stories. I'm looking into all of it.
Old 05-04-2017, 07:03 AM   #14
2005 30' Classic
Burlington , Ontario
we have carried our bikes this way on three tow vehicles.
lt has worked fine for us - in each case I had a local trailer shop install the front hitch receiver.
On our latest vehicle, a GMC 2500HD, it isn't quite as convenient as the hitch receiver hole comes right out behind the license plate so I had to make an adapter for the plate - but also, it means that to install and release the bike rack. I need to lie on a tarp under the front of the truck to install/remove the hitch pin. Not really a big deal though.
As well, because the hitch receiver is higher from the ground in this truck, the bikes were initially riding too high and into the fiel of vision, so I cut down the the bike rack and re-welded it to a more appropriate length so that I just barely see the handlebars and seats almost level with the truck hood and all is fine.
Never had any problem with the bikes being too low and touching the ground on steep drives & such.
I suppose headlights are affected very slightly but we generally are not on the road at night anyway so this has never been an issue for us.
Been carrying the bikes this way for about 20 years.
It is true that the bikes can get a bit dirty, but our bikes are no $6000 specials! More like $250 about 20 years ago so in our case that is no a concern at all.
I can understand that folks who are really into expensive bikes might not be so happy with this, but for us a quick wash and clean up when we arrive is all that is needed.
As for legality - I am not sure - I can only say that no police have ever expressed the slightest concern all the time we have carried the bikes this way. I suppose technically they could make an issue regarding the headligts
although the impact is minimal.
Old 05-04-2017, 07:37 AM   #15
m.hony's Avatar
2013 30' Classic
Even before daylight the bikes on the front carrier aren't an issue.
The headlights seem to shine right through the bicycle wheel spokes.
We seldom ever travel after dark, but we occasionally travel before day.
TAC #MS-10
Airforums #70955
Old 05-23-2017, 11:31 AM   #16
Milwaukee , Wisconsin
When we want to bring all 4 bikes, 2 go on the front hitch and 2 go in the camper.
RinconVTR is offline   Reply With Quote
Selecting the best option for front mounted hitch for bikes SilverEagle6 On The Road... 31 12-04-2015 04:05 PM
Want to carry bikes on front of truck!? 3campers On The Road... 29 11-30-2014 08:25 PM
Front receiver for bike carrier Tino643 Hitches, Couplers & Balls 19 06-25-2013 06:57 PM
Front hitch/Receiver - 4x4 only? az-streamer Hitches, Couplers & Balls 6 01-09-2012 05:29 PM
Front Receiver gowyn Hitches, Couplers & Balls 12 05-14-2008 07:31 PM
