Old 06-15-2015, 09:30 AM   #1
1982 27' Excella
Huntsville , Texas
Franklin Div Coupling
The coupling on my 1982 Excella simply states Franklin Div. Class 4 64410200. When I look online for Franklin, I can find no information on the company. Does anyone know something about Franklin? Is the mfg or it a subsidiary of a larger company?
GMarugg is offline   Reply With Quote
Old 06-15-2015, 10:03 AM   #2
1981 31' Excella II
New Market , Alabama
You mean the part the ball fits in? At the front of the A-Frame?
Perry
Old 06-16-2015, 06:29 AM   #3
1982 27' Excella
Huntsville , Texas
The Franklin Div and the Class 4 is just in front of the hole for the power jack and the number is on the street side of the coupling just be hide the part that holds the ball
Old 06-16-2015, 06:47 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Franklin was/is a division of Attwood. Repair parts are available.
88050 264565 2” LATCH REPAIR KIT FOR FRANKLIN 64-4103/ATWOOD MARVEL 88000 88061 264576 2 5/16” LATCH REPAIR KIT FOR FRANKLIN 64-4102/ATWOOD MARVEL 88007
MICHAEL
Old 06-17-2015, 04:35 AM   #5
1982 27' Excella
Huntsville , Texas
Thanks for the information. I was looking at buying an Anderson wd system that is not compatible with several models of the attwood couplings.
Old 06-17-2015, 07:07 AM   #6
AWCHIEF's Avatar
Images: 33
You should have no compatibility issues with the very effective and affordable Andersen WD System. In fact there is not one documented case of a trailer separating from the tow vehicle while on the road and using the Andersen WD system contrary to what one member here keeps parroting.
MICHAEL
Old 06-18-2015, 10:00 AM   #7
1982 27' Excella
Huntsville , Texas
I just received a reply from Atwood. They said that this was their Marvel style coupling and that did not want the WD system used because it would cause force to be applied to the ball clamp and cause undue wear on the coupler.
Old 06-18-2015, 10:25 AM   #8
Gainesville , Florida
Did they mean any WD system or only the Anderson?
Old 06-19-2015, 06:24 AM   #9
AWCHIEF's Avatar
Images: 33
MY Bambi II had a Marvel coupler. It was 50 years old. I used an Andersen WD system on it for for three years with no noticeable additional wear. I went as far as buying a coupler rebuilt kit. I left it unused in the trailer when sold.
MICHAEL
Old 06-19-2015, 07:01 AM   #10
Livingston , Texas
Current Related Thread on Open Roads Forum
Photos of Ball Wear
Ron
Ron Gratz is offline   Reply With Quote
Old 06-19-2015, 07:29 AM   #11
Interesting, thanks for the info.
Old 06-19-2015, 08:02 AM   #12
1982 27' Excella
Huntsville , Texas
Coupling
The discussion is in regards to the Anderson WD system. Apparently it causes increased wear on this type of coupling
Old 06-19-2015, 08:05 AM   #13
1982 27' Excella
Huntsville , Texas
Coupler
From the discussions I have hear this WD system causes increased wear to components that have some normal wear patterns. From your comments the wear is not that dramatic
Old 06-19-2015, 08:08 AM   #14
1982 27' Excella
Huntsville , Texas
Coupler
Were you happy with the Anderson WD system?
25FB vs 27FB - length EXCLUDING the coupling and drawbar Timofeevich 2009-2015 Flying Cloud 15 04-22-2013 08:23 PM
Calder 3 inch Coupling wallygilbert Waste Systems, Tanks & Totes 1 07-27-2009 07:07 AM
LA Times Article on Coupling Dangers fabofabo Our Community 1 12-10-2007 06:13 PM
Sewer Coupling niftypkg Waste Systems, Tanks & Totes 6 02-25-2007 08:20 AM
