Old 06-19-2015, 09:10 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The heavier the trailer, the more likely the higher wear.
As it is, an Andersen cannot exert proper leverage for any but the lightest trailers for correct weight distribution
It's rather an expensive device to take the edge off incipient sway.
A Bambi is one thing, a modern 25' quite another.
Old 06-19-2015, 08:18 PM   #16
1982 27' Excella
Huntsville , Texas
Today Anderson emailed me that the Marvel style coupler was OK and should not be a problem
GMarugg is offline   Reply With Quote
Old 06-20-2015, 06:17 AM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I suspected that would be their response. I was very happy with the Andersen. Unfortunetly I fell for the sky is falling babble here and bought the Blue Ox SwayPro for the Safari. Due to my own personal safety issues with the BO I will be replacing it as soon as I am able with a new Andersen.
MICHAEL
Old 06-20-2015, 08:07 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Chief, just get you a Cub, go for equal squat and never look back again. Your rig can handle the little extra weight. Can use jacks versus snap chains.
Old 06-21-2015, 06:20 AM   #19
AWCHIEF's Avatar
Images: 33
Are you willing to write the check?
MICHAEL
Old 06-21-2015, 07:06 AM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Value versus price problem?
Old 06-21-2015, 07:15 AM   #21
AWCHIEF's Avatar
Images: 33
That does not answer my simple question.
MICHAEL
Old 06-21-2015, 09:17 AM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
You've already answered it yourself: You don't let purchase price get in the way of value.
This type of trailer design is expensive, you've owned several and the same is true for the multiple vehicles you've used to tow them.
And now, hitches. A VPP and/or a custom setup involving of a lot of painstaking details is where value lies. A combination of these may be where it really comes together. Thomson puts these together all the time. The dollars are only relative to performance.
A WDH is a lot more than just moving some weight around. It's a bad assumption about assessing their value to focus on that.
And the answer on the really large costs is that you will spend for value. Despite cheaper alternatives. A hitch is not a large cost.
Going backwards on hitch design is inconsistent with what you've done via TT and TV purchases.
Old 06-21-2015, 09:32 AM   #23
AWCHIEF's Avatar
Images: 33
Ok, so you are not willing to answer my question or put your money where your mouth is. End of discussion.
MICHAEL
Old 06-21-2015, 09:42 AM   #24
Gainesville , Florida
If can am is so into these expensive hitches, then why do they still install eazlift? Probably because the eazlift does the job just fine under almost all conditions at a tenth of the cost. If you gave me the money I would spend it on tires, wheels and maintenance leaving the rest for traveling. Priorities are just different.
Old 06-21-2015, 06:33 PM   #25
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Did you miss it, or do you simply prefer your inconsistency? And worse performance. Which I still find hard to believe.
Old 06-21-2015, 06:37 PM   #26
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
If you can custom build the hitch receiver, and keep a short rear overhang tow vehicle rear axle to trailer coupling to its absolute shortest distance, then, yes, a basic WDH works well for smaller TT and TV.
Should be basic for any TV, this prep, despite the actual hitch. But isn't.
One moves from friction bar and up through integrated antisway to VPP afterwards.
25FB vs 27FB - length EXCLUDING the coupling and drawbar Timofeevich 2009-2015 Flying Cloud 15 04-22-2013 08:23 PM
Calder 3 inch Coupling wallygilbert Waste Systems, Tanks & Totes 1 07-27-2009 07:07 AM
LA Times Article on Coupling Dangers fabofabo Our Community 1 12-10-2007 06:13 PM
Sewer Coupling niftypkg Waste Systems, Tanks & Totes 6 02-25-2007 08:20 AM
