Old 03-03-2015, 08:16 PM   #29
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
How many Airforum members does it take to change a light bulb?
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-03-2015, 08:34 PM   #30
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
@marter:
"@Al and Missy, I totally get that the yellow (lower) sticker is the key, based on the options installed during build and a full tank of gas. The ProPride itself weighs 195# according to Sean at ProPride, but what I don't know is the transfer to the truck and trailer."
How much weight gets transferred is setup dependent. The only way to get an exact number is to do as others have suggested and weigh your setup. If you don't have a setup to weigh, you'll have to do some estimating as I and others have suggested. For my setup (F-150, 6300# GVWR 25' Safari) the Equalizer transfers about 150# from the TV to the TT. IF you use a number in that vicinity, you should be close.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 03-03-2015, 09:25 PM   #31
Livingston , Texas
Originally Posted by marter View Post
So if I'm starting with 1630# payload, subtract 835# for the tongue weight and 195# for the 3P hitch, I have 600# left for passengers and gear, correct?
Yes, you need to account for the expected weight of the WDH.
If you adjust the WDH to restore the TV's front axle to its unhitched load,
a load equal to about 20-25% of the tongue weight would be transferred to the TT's axle(s).
This mean that the TT-induced vertical load added to the TV would be equal to about 75-80% of the tongue weight.
Ron
Ron Gratz is offline   Reply With Quote
Old 03-03-2015, 10:31 PM   #32
marter's Avatar
2008 19' International
Lincoln , Nebraska
Al[/QUOTE]
Wow. Thanks for your tolerance. I can only hope someone showed you a bit more patience when you started down this path.
marter is offline   Reply With Quote
Old 03-03-2015, 11:05 PM   #33
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
This site has very informative Towing Guides for each vehicle model year, with explanations of all of the different weight ratings:
Trailer Towing Guides | Trailer Life Magazine
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 03-04-2015, 03:04 AM   #34
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
A thought..... Tongue weight, all of it is part of the TV load. None of the tongue weight is carried by the trailer wheels. If one measures tongue weight, unhitched and weight on wheels unhitched, then hitches up, reweighs, the trailer weighs the same. Weight distribution hitches simply move weight from the rear to the front of the TV.
And, Mr Cross, your tires in the photo appear to be nearly 10 years old......approaching the limit, as I understand it, on life span.
If I am incorrect in my opinion, please correct me.
Happy trails and good luck,
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 03-04-2015, 03:12 AM   #35
Msmoto's Avatar
2007 25' Safari
Images: 135
Forgive me: Does tongue weight count against payload?
@ marter......about 600 lbs. for you and your gear
Ms Tommie Lauer
Greensboro, NC
AIR #31871 K4MTL
Old 03-04-2015, 05:31 AM   #36
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Wd & tw.....
Ms Tommie Lauer
Greensboro, NC
No the weight on the trailers axle/axles is not the same hitched and unhitched with WD set properly.
TW only remains stationary when/if your towing without WD.
When set properly the TW is divided between the TV frt axle, TV r/axle and trailer axle/axles.
Note trailer weight on the 2nd & 3rd CAT tickets.
On another note...
Yes, my TV tires are even older now, as that photo was taken several years ago.
But the Burb is a garaged TV not a DD, and I do replace when necessary, or when the ware bars are exposed, regardless of age.
POI...I also have a 63yr old Ford with 15yr old tires.
Sweet Streams....
Old 03-04-2015, 06:25 AM   #37
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Been through this many times personally. Finally in my old age gave up, bought an F350 Diesel and simply don't care about hitch weight, weight distribution or weight of the AS. Not everyone can or wants to do what we did, but it works for us. Now going to add a 50 gallon fuel tank because in Fords attempt to control weight for the Feds they only offer a 26 gallon tank.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-04-2015, 08:41 AM   #38
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Tongue weight is a constant and you should not subtract any WD weight transfer.
Moflash is online now   Reply With Quote
Old 03-04-2015, 09:00 AM   #39
Thumbs up
Exactly....TW is only relevant when the trailer is un-hitched.
TW becomes hitch and or receiver loading when WD enters the equation.
Old 03-04-2015, 11:54 AM   #40
grizbear's Avatar
2004 25' Safari
Crestview , Florida
wt. question
I have been reading all this and I'm getting dizzy ha. I've been to the scales fully loaded the truck alone wt 7480 loaned. The gross wt of TV and the AS was
13700. AS axle wt 5160. tongue wt looks like 1060. With a gross wt of 6300 on the AS tag it appears I'm within 80 lbs of max. Is that correct? If I tighten the hitch WD bars will that increase the amount I can carry in the camper? Thanks Rand
grizbear is offline   Reply With Quote
Old 03-04-2015, 07:05 PM   #41
Livingston , Texas
---If one measures tongue weight, unhitched and weight on wheels unhitched, then hitches up, reweighs, the trailer weighs the same. Weight distribution hitches simply move weight from the rear to the front of the TV.
Do you have weight tickets to substantiate this claim?
If so, can you please post photos of the tickets or post the numbers?
If the TT has independent axles and is in a nose-down attitude when the "no WD applied" measurements are made, a measurement error can be introduced which makes it appear that no load is transferred to the TT's axles when WD is applied and the nose is raised.
Ron
Old 03-05-2015, 11:20 AM   #42
Msmoto's Avatar
2007 25' Safari
Images: 135
Tongue weight
Ron
The assumption is that under all weighing conditions the trailer is level. While there is a small lever moment exerted by the trailing arms of a weight distribution hitch, it is quite small, and the lever length is also small in relationship to the distance from the wheels to the receiver at the front of the trailer.
My point is in terms of what I think the OP was concerned about, that of actually trying to not overload the TV. And, my contention is that a weight distributing hitch will not make any sizable difference in relieving the TV of tongue weight, thus increasing its payload capacity for passengers and cargo.
And, the next time I am crossing the scales, I will make every attempt to do a weigh in with and without the weight distribution bars under tension. At the CAT scales, the first fee is about $12.00 and re-weighs at $2.00 each. So, multiple passes are possible.
AIR #31871 K4MTL
Does hitch add tongue weight dkottum Hitches, Couplers & Balls 37 11-28-2015 07:00 PM
Payload affected by Hitch Weight Tony S Hitches, Couplers & Balls 16 04-14-2011 10:45 AM
how does tongue weight capacity rating affect handling? Smoky Hitches, Couplers & Balls 12 10-06-2008 04:29 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
