Old 06-09-2018, 10:35 AM   #29
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
Best to consult Ford directly. The OEM should be able to advise you. I have a Silverado and they have had anti-sway control standard since 2013. I use a Reese Hitch without sway and am perfectly satisfied with the stability. The Chevy system has sensors to determine the intended yaw and the actual yaw and correct, first by applying the trailer brakes, through the integrated brake controller, and then the truck brakes just as it does other functions with the StabiliTrak system. I have experienced an occasional hint of sway that gets your attention, but never had it oscillate. https://media.gm.com/media/us/en/che...iler_sway.html
Tomzstream is offline   Reply With Quote
Old 06-09-2018, 09:09 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep...thats your goal, to completely forget the Airstream is behind you at 72mph 😂
Use both. 👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 06-09-2018, 09:58 PM   #31
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Never forget - that is a very bad idea. Not nearly as many smiles. Pat
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
BlueOx SwayPro 22FB Ford F150 ? ChrisnPatty Towing, Tow Vehicles & Hitches 12 06-04-2014 11:08 AM
Turn off electronic sway control with Propride? Wanna EB Hitches, Couplers & Balls 7 01-06-2014 10:31 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
