Old 10-31-2017, 01:46 PM   #1
70CT's Avatar
1974 21' Globetrotter
2016 30' International
Houston , Texas
Ford Optional Trailer Camera and TPMS
https://accessories.ford.com/kit-tpms-sensor-11804.html
Anyone use this on an AS? My fancy new pickup came with the ultimate trailer tow camera package which means I have the “privilege” of purchasing this. I won’t lie, I am intrigued and the price seems okay. What I am most curious about is if anyone has mounted the camera to a newer AS that is pre wired for a Furrion camera. Is this essentially plug and play?
Danke
70CT is offline   Reply With Quote
Old 10-31-2017, 01:58 PM   #2
Florence , Alabama
Multiple threads on this already. Look around
joshjack is offline   Reply With Quote
Old 10-31-2017, 02:47 PM   #3
70CT's Avatar
Houston , Texas
Really? Haven’t been able to find one that addresses using a ford camera for a furrion pre-wired trailer. Found plenty addressing the use of the Ford camera in general.
Old 10-31-2017, 03:10 PM   #4
Florence , Alabama
ZOINKS! My bad, I read this too quickly and categorized it as yet another Ford trailer accessories question
Old 10-31-2017, 03:17 PM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The simple answer is that the Ford camera does it's own thing and the "stock" AS wiring is not a lot of use. You still need to do a bit of this and that to get it hooked up.
Old 10-31-2017, 07:23 PM   #6
2005 28' Classic
Nicholasville , Kentucky
Josh,
I have a 2017 F250, installed the TPMS to my 2005 Airstream and this works great, over the next week I’m planning on the camera install. Look into YouTube, there are a few that have installed the camera.
Plus I’m a newbie to Airstreams, second post.
KYShelby is offline   Reply With Quote
Old 10-31-2017, 09:37 PM   #7
70CT's Avatar
Houston , Texas
No worries, you just built my hopes up then crushed them.
Old 11-01-2017, 04:59 AM   #8
Florence , Alabama
So in an effort to be helpful this time...
The Furrion camera is wireless, meaning the prewire will be power only.
Looking at the Ford system you mentioned and looking in some of the Ford forums it seems like their system is totally hard wired, meaning video and power. So I don’t think it’s possible to use the Furrion pre-wire in the manner you hoped.
If I am incorrect and the ford system is wireless, then it should be really simple to connect the 12v prewire to the Ford camera.
Old 11-01-2017, 06:04 AM   #9
Zionsville , Indiana
I installed the Ford camera on the back of our 2017 26u. After looking at the field of view the camera has, I decided to mount it to the rear of the trailer, centered just above the license plate. Ran the cable under the trailer, came up into the rear bumper storage area and then up to the camera from there. I did this to avoid any new holes in the roof and to have a place to store the huge coil of excess cable. The black cable running up above the plate doesn’t look as clean as a wireless, but it is the best you can do without serious surgery on the AS. Be advised - the camera only works when in reverse as the AUX input on the Sync display, has no guide grid or lines, and the bracket is painted steel. I mounted the camera to an aluminum plate and then mounted the plate to the AS. Used stainless steel hardware and liberal amounts of 30 year rtv to prevent leaks and corrosion. I also placed 3M chafe tape behind the plate and cable on the run from the bumper to the camera. To turn the camera into an active rear-view camera you can see while driving down the road, you need an after-market “enabler” that allows the Sync3 head end unit to display the camera while in forward motion. I am looking at a device from NAVIKS - they are in final testing and claim it will be available in the next few weeks for around $250. You need to dismantle the center dash and gain access to the rear of the Sync head unit to install the device - which is not as difficult as one may think.
Good luck and enjoy the truck and AS.
DRPREECE is offline   Reply With Quote
Old 11-01-2017, 07:31 AM   #10
2016 28' Flying Cloud
Brandenburg , Kentucky
I have looked at this TPMS/Camera kit for my 2017 F250 Lariat. Think for right now, just getting and install the TPMS portion. Not thrilled about not having a clean install solution for the camera wiring. For the TPMS wireless transmitter, where did you install it? Certainly would like to see any photos of your install(s).
Tsunami-v2 is offline   Reply With Quote
Old 11-01-2017, 10:16 AM   #11
La Quinta , California
2017 F-250 here, I mounted the camera inside at the rear window on our 2017 Classic, ran the wiring inside then out at front where other wiring coming out to batteries.
NordSailOne is offline   Reply With Quote
Old 11-01-2017, 10:41 AM   #12
2005 28' Classic
Sailone, I like the idea of your installation, could you pass on any tricks on this, or anything that you would change? I have a 05 Classic 28’, thank you in advance.
Old 11-01-2017, 03:17 PM   #13
Nothing I would change.
I would say I spent more time investigating and planning the best route down through the coach than I did installing.
Advantage I have in the 2017 Classic is the hydronic heating which runs around the perimeter of the coach with aluminum covers over it. This helped to run the wiring without being able to see it.
Old 11-01-2017, 07:30 PM   #14
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I mounted the TPMS signal box to the center of my forward axle on our 28ft International.I used large zip ties for this and smaller zip ties for the cable routing to the front of the trailer.Took approximately 1.5 hours due to being anal retentive.Initial setup was a breeze.Maiden voyage of 3500 miles proved this system value.Have held off on rear camera install due to time restraints.
Ford TPMS Kit mikeinca Wheels, Hubs & Bearings 36 11-02-2018 10:34 PM
2017 Ford Ultimate Trailer Camera & TPMS Airdog9 Towing, Tow Vehicles & Hitches 42 04-30-2018 08:22 PM
Ford-trailer TPMS system GoWhereTowed Towing, Tow Vehicles & Hitches 2 07-11-2016 10:12 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
1968 Airstream Price Schedule and Optional Equipment Uberphotos Trailer Values 5 05-28-2008 11:47 AM
