Old 08-25-2017, 12:38 AM   #1
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Ford F-350 and 19' Bambi: WD hitch needed?
In order to accommodate an Alaskan truck camper, I'm considering a new tow vehicle for our Bambi: Ford F-350 Super Duty (not sure about gas vs diesel). Do I still need a weight distribution hitch? My guess is yes, but I'd be interested in any input. Thanks for listening!
-Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 08-25-2017, 04:01 AM   #2
2012 19' International
Southeastern MI , Michigan
I have this combo, and have towed it both ways. The dealer set up the trailer for my Grand Cherokee, which I traded for the Superduty. Had them set it up again for the new truck. I really doubt that 800 lb tongue weight is going to lighten the load on that front axle by more than a few hundred pounds. I've towed tractors and cars on trailers that squat the rear end of the truck a lot more than the 19' and never used WD.
The ride is a little better with the WD, a little less porpoising over humps in the road, but otherwise no different. I use them on long trips but most of the time they sit in the garage. I always use the friction sway device. The truck has trailer sway control too.
Hope this helps. Not sure what the "truck camper" weighs; this may affect the decision. I lug antique car engines around but keep the weight over the axle where possible.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 08-25-2017, 10:51 AM   #3
Long Island , New York
-Jerry
Ditto to Countryboy59's question, how much does the camper weigh, and what will be the total weight of the pickup and camper?
We have a Ford Transit 350 van and a FC20, and use a Reese WD hitch mainly to control hobby-horsing rhythmic bouncing on rougher roads [with 800 pound bars and the WD set very lightly]. IMO your rig would be fine without WD, as would ours.
Good luck!
Peter
PS -- Could you post a link for the camper you are considering? We have often thought that your setup would be the way to go for certain kinds of travel. Thanks
Old 08-26-2017, 12:44 AM   #4
ESCAPE POD's Avatar
2007 19' Safari SE
Ford F-350 and Alaskan Camper
The weight (wet) of the camper is 2,000 - 2,250 lbs. Here's the link to the website:
http://alaskancampers.com
Thanks for your advice!
Jerry
Jerry & Susan
Old 08-26-2017, 04:59 AM   #5
Wow, that's heavy! I'd be careful about using a WD to level that rig. You're getting close to payload assuming 800 lb tongue weight and 2250 over the axle. Might have to re aim the headlights .
Either engine has enough power to pull it.
Hensley Arrow hitch
Old 08-26-2017, 01:13 PM   #6
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I've had a similar setup in the past. I installed air bags on the rear suspension and it made a huge difference in ride and handling.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 08-26-2017, 01:22 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Something to consider about that camper, it's got a *lot* of rear overhang. Getting the hitch ball back far enough will be a bit tricky. On my current setup, the trailer simply would not mate up with that much overhang.
Once you do get the ball back further, things like sway get a bit more exciting....
Old 08-26-2017, 02:36 PM   #8
ESCAPE POD's Avatar
2007 19' Safari SE
Bambi and Alaskan cab
That also occurred to me. I may have to go with a longer truck bed and shorter version of the Alaskan in order to avoid the overhang.
Jerry & Susan
Old 08-26-2017, 03:04 PM   #9
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
The short answer is yes, you do need a quality trapezoid projection hitch to prevent sway. A ball mount will never prevent any sway. Having said that, it seems like driving a tack with a sledge hammer. However, you can still bend the tack. We don't want to bend the tack, or TT/TV either.
guskmg
Old 08-27-2017, 07:35 AM   #10
Half a Rivet Short
Hi
Like all campers, you will loose a lot of the camera based features on your truck. Some are a bit silly others are quite useful. Replacing them all is possible. Integrating all that replacement work into the onboard system .... not so easy. I like the way Ford does the backup camera when hitching up the trailer. I also like the "full view" plot when parking. Neither one would be easy to adapt to other cameras.
Old 08-27-2017, 05:52 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
As a rule of thumb it's 350-500/lbs TW where a WD hitch becomes a requirement.
Misunderstood by most is this: TW is a static representation of a dynamic force. That's a lever back to TT axle. Force multiplies. (It ain't the same as cargo weight).
WD does make a rig respond better. Integrated anti-sway, a no brainer.
And I'll second guskmg recommendation of a Hensley or Propride.
A 4WD pickup is top heavy solo. Loaded with a truck camper this worsens. Let's not have the TT tickle the truck. It's the weak link for stability.
The trailer doesn't really need it. The truck REALLY needs it. Elimination of sway makes a long day much easier.
Have always admired Alaskans. Not something you see down here.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 08-28-2017, 01:08 AM   #12
ESCAPE POD's Avatar
2007 19' Safari SE
Hi
Yeah, the camera is a HUGE asset when hitching, and it would be sorely missed! Haven't looked into tying a third party camera into the onboard system, but that's anyone's first choice. If going with an independent model, any recommendations are welcome (although that probably belongs on another thread.).
Jerry & Susan
Old 08-28-2017, 01:14 AM   #13
ESCAPE POD's Avatar
2007 19' Safari SE
As to center of gravity, I'm hopeful the low-profile of the Alaskan will lower it to some degree. On the other hand, the consensus seems to be that a WD hitch would be wise anyway. Will my Equalizer still be of use, or do I need to step up to a Hensley/Propride? Also, what recommendations on setting up the tensioning on the hitch? If I understand him correctly, Guskmg suggests there can be a point of overkill.
Jerry & Susan
Old 08-28-2017, 06:13 AM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Any WD hitch can be used, but only a Jim Hensley design "eliminates" sway. Other types resist it more or less.
Traditional point for COG with truck as delivered is at top of transmission at firewall. The camper will be at, and above that. A high COG is raised farther.
It's a fair-sized "sail area" along the rig as proposed. How much wind it catches from crosswinds is the thing. The sail area "above" the as-delivered COG is what to consider.
The rear of the camper (squared off ) is where the drag is highest. Turbulence between the vehicles is increased.
The faster one is moving, the sharper the forces involved. It comes down to the truck Drive Axle tires being able to maintain grip (slip angle).
No one would suggest the rig is dangerous, it's that the speed and force of a problem in maintaining lane-centered-ness can be faster and more difficult than one is ready for. Even with practice. Crosswinds natural or man-made are a bear. That, "wrong time & wrong place" problem.
As to hitch settings, it'll be more about feel than anything else. Won't take much, and I think it will be obvious. TV tire pressure is the other. Use a scale to set both. A baseline of numbers for future reference.
FORD F-350 trailer hitch issue polarlyse On The Road... 11 09-29-2016 12:39 PM
E250/350 vs F250/350 kb0zke Tow Vehicles 10 05-21-2016 04:41 PM
2016 Ford 250/350 SUV conversion. Guess I can have my cake and eat it... Danattherock Tow Vehicles 27 07-14-2015 03:10 PM
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 11:00 PM
