Old 01-17-2015, 03:53 PM   #1
2015 25' Flying Cloud
Apollo Beach , Florida
Ford F-150 3.5L V6 Ecoboost
Looking at possibly buying a 25' Flying cloud GVWR 7300 lbs. 2013 Super Crew Cab 4x4. According to Ford the 3.5L with the transmission 3.55 axile ratio is capable of a GCWR of 15,000 lbs. The truck weight with two people and full fuel (36gal)is about 6300 lbs so the way I figure it I should be able to tow up to 8700. Does anyone out there have any real world experience towing a 25' AS with this type vehicle? I have not purchased the AS yet and still researching it. Any comments would be appreciated. Thanks
Guyel is offline   Reply With Quote
Old 01-17-2015, 04:17 PM   #2
2008 23' Safari SE
Oklahoma City , Oklahoma
I bought the same truck in a super cab with 3.73 2011 model with the intention of pulling the same trailer. Like you I haven't purchased the unit yet but would not have bought it if it couldn't handle it. Do a search for the ecoboost engine here and you will find your answer from others who are pulling this same trailer and even the 27'
Good luck
Mike
Rocket53 is offline   Reply With Quote
Old 01-17-2015, 04:34 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I bought a similar truck; I think the yellow sticker in the door makes a difference.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 01-19-2015, 12:16 PM   #4
2013 25' Flying Cloud
Amity , Oregon
Several years ago I would have thought towing with 1/2 ton truck was out of the question. After reading LOTS of discussion on these forums I agree it can be done. We returned in September from the WBCCI Alyeska Caravan and there were four 1/2 ton trucks on that caravan, two F150 Ecoboost and two 1500 Dodge Rams. All 4 performed admirably with no problems; in fact, our travel buddies towed their 30' with an F150 and kept up with us the whole way, only loosing a little ground on the steeper grades. I really like our 2500 Ram diesel with its greater margin of payload, etc., but the 1/2 ton trucks have a lot to offer.
"If Mama ain't happy, ain't nobody happy" ... magnet on our refrigerator...
OregonVista is offline   Reply With Quote
Old 01-19-2015, 01:16 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have real world experience towing a 25' with our Ram 1/2 ton through most of the states throughout the country. We manage our loading within axle and tire ratings, use a ProPride hitch for pleasant towing and absolute stability in all conditions, and the transmission for power up and braking down steep grades.
It's a near perfect match for the task at hand and is a nice driving and riding truck when not hooked up to the Airstream. I would expect at least as good a result with the Ecoboost F-150.
Doug and Cheryl
Old 01-19-2015, 01:20 PM   #6
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
[QUOTE=lbs. 2013 Super Crew Cab 4x4. According to Ford the 3.5L with the transmission 3.55 axile ratio is capable of a GCWR of 15,000 lbs. The truck weight with two people and full fuel (36gal)is about 6300 lbs so the way I figure it I should be able to tow up to 8700. Does anyone out there have any real world experience towing a 25' AS with this type vehicle? I have not purchased the AS yet and still researching it. Any comments would be appreciated. Thanks[/QUOTE]
We purchased a new F150 4X4 SuperCab Echoboost, with 3.55, in 2012 for our 08' 25' AS; now we have same truck (60K+ miles) with our new 25' FC and still going strong! No issues. Did discover recently on trip from San Diego to MT over holidays, that by using higher octane fuel (87+), I got improved mileage both when pulling AS and especially when not pulling anything (20-22MPG at 70+MPH). Truck does fine with 25' AS! I will likely get a new one when the 10 speed transmission is out in 2017! For now, couldn't be happier with our choice.
Old 01-20-2015, 04:40 PM   #7
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I had a 2013 25' Flying Cloud that I towed with a 2013 F150 Ecoboost with absolutely no problem at all. My only reservation is that I did not have enough payload capacity which was my fault for not doing enough homework on the payload thing. Even still I had no problems at all. I have since bought a 30' Flying Cloud so I am going to upgrade my truck to a 2015 F150 Echoboost only this one will have Max Towing and Max Payload.
TinCan
graysailor is offline   Reply With Quote
Old 01-20-2015, 05:38 PM   #8
George
2007 25' Classic
Calgary , Alberta
I'm shopping for a new tow vehicle and was looking at F350's today. The sales guy highly recommended the new aluminum F150's, claiming 2000 lbs payload.
I figure I need about 1900 lbs (includes 1050lbs tongue weight).
However, when I checked the two door stickers on the well-equipped units they had in stock, I found 1568 lbs and 1583 lbs.
You might check your numbers and comfort level.
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Old 01-20-2015, 05:59 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Ford F150 3.5L V6 Ecoboost
They are all different payload ratings as it depends on individual options ordered and packages,Ask for the 2015 Ford towing guide and do your homework.Most salespeople and even the managers ordering the inventory are not well versed on trailer towing requirements.Read the Towing guide carefully as it can seem a little confusing.
Old 01-20-2015, 06:14 PM   #10
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I am planning on the purchase of one too. I have a 25' and I can tell you that my current engine is slightly less power/torque than even the 2.7L eco and it does fine. The 3.5L ecoboost super crew 2WD, in its lower final drive 3:15 will even pull a 25 with no issues. It is rated for 10,200 lbs. or 4WD 3:31 and 9900 lbs. It is a bear of an engine. Note how they lower the final on the 3.5 eco engine whereas on the 5.0 the finals don't go that low. It has a lot of torque early on. The payload is going to be around 2000 lbs.
Moflash is absolutely correct. This weekend I went to look and mentioned payload. They did not know what I was talking about with regard to towing.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 01-20-2015, 06:43 PM   #11
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Hitch
One other thing to be aware of, is the reciever hitch, at least on my 2013 f150 ecoboost, has a rating og 1050lb max for a wd hitch. There is a sticker on the hitch under the bumper with the information. You have to get down and look up to see it. Just throwing it out there.
Mike S. is offline   Reply With Quote
Old 01-20-2015, 06:59 PM   #12
Moflash's Avatar
Final drive ratio? Or axel ratio? 3:15 axel ratio is a very high speed ratio for towing.I would not recommend going that high regardless of torque generated.
Old 01-20-2015, 09:24 PM   #13
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . ahh, the subject that won't go away. My '11 FX4 150 Ecohummer pulls my FC 28 just fine, thank you. (Remind me I said that when I get the rig back from Alaska this Summer). . .regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 01-20-2015, 09:30 PM   #14
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Get a 3/4-ton truck and quit worrying about it.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-20-2015, 10:58 PM   #15
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
We went with a 2014 Tundra Double Cab. With 5.7L V-8, 6 speed trans, and standard 4.30 gears, Factory tow package. It's rated for 10,500 # towing.
It pulls our Tradewind easily and doesn't even notice our mini "Airstream"
The dark grey Tundra was on our test drive of the Tundra, we bought the white one and added an ARE cap.
The Tundra alone get 16-17 mpg and about 1 mpg less with the mini "Airstream"
The Tradewind is still under construction. It started life at 4350# and when done and loaded should come in around 5000 #.
ID:	230817   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-20-2015, 11:16 PM   #16
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I would go with the max tow and max payload too. It's nice to have that extra buffer when you need to carry extra passengers or cargo. I seriously thought about a 2015 F150 3.5 ecoboost to tow my 28' slideout but with the 9200 gvwr and 1100# tongue weight and all the gear I carry, I decided on a 2015 GMC 2500 DenaliHD Duramax instead.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-20-2015, 11:42 PM   #17
2017 27' International
Fall City , Washington
what CAStreamer said.
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 01-21-2015, 05:09 AM   #18
PaulnGina's Avatar
Good Ol' , USA
Thumbs up
LOL!! That's good!
1987 Avion 34W
Old 02-04-2015, 05:43 PM   #19
2006 25' Safari
Images: 8
Moflash said..."Final drive ratio? Or axel ratio? 3:15 axel ratio is a very high speed ratio for towing.I would not recommend going that high regardless of torque generated."
You threw me when you asked this question as I have always heard differential and final drive ratio used interchangeably. So I looked it up to learn some more. To answer your question I refer to the final drive rear differential ratio that Ford uses in its listings for towing. The 2015s look to have four offerings ranging from 3.15 to 3.75. The best mpg but weakest for pulling is the 3.15; however, the power of the engine has much to do about that too. The 3.5 Eco does not show a 3.75 I believe, the most powerful but it does not need it yet note that the 5.0 does have the 3.75 option. My current truck has a 3.55 rear differential. That is the ratio offered in the max tow of one of the Eco engines I remember. I will probably go with the 3.15 in the 3.15 Eco for my payload/tow requirements. Your weights may require more.
Axle ratio I found often refers to gearing at the wheels as in the case of 4wd.
Old 02-04-2015, 09:13 PM   #20
Salem , Oregon
Images: 18
Hi, my 2014 F-150 Ecoboost, with Max Tow Package, has a 3:73 electronic locker rear differential . I believe that ratio is not offered for the same in 2015. With the six speed trans a 3:55 should work fine, but I chose to have the 3:73's.
2005 Safari 25-B
Ford 2014 Ecoboost 150 with Max tow and HD payload Rollster On The Road... 27 01-20-2015 08:10 AM
Ford 150 Ecoboost with Max Tow vs. Big Butt Trailer ShullsinUtah Tow Vehicles 15 09-17-2013 08:45 PM
Ford F-150 EcoBoost review JFScheck Tow Vehicles 387 05-28-2013 04:49 PM
Ford 150 EcoBoost experience RoccoJohn On The Road... 5 11-17-2011 04:59 AM
Ford 150 EcoBoost power in Mountains RoccoJohn Tow Vehicles 31 09-20-2011 05:14 PM
