Old 04-23-2014, 11:34 AM   #1
AKristine's Avatar
East Falmouth , Massachusetts
Ford Expedition and towing
Good afternoon -
For the past year I have been all around the mulberry bush, attending RV shows, looking at lots of Airstreams and Interstates -- eventually I will make a decision.
One of my all time favorite Airstreams is the 27 foot International Serenity--I just love it. Yesterday I telephoned Can-Am RV Centre up in Canada to ask for advice on using a Ford Expedition as a tow vehicle the 27 footer. A gentleman by the name of Philip Tipler told me that if I had a Prodigy P2 brake controller and a weight distribution hitch installed, I would be fine with the Ford Expedition.
If anyone has anything to add to this, I would be grateful for your comments/observations.
Many thanks.
Kristine
AKristine is offline   Reply With Quote
Old 04-23-2014, 12:41 PM   #2
Road Ruler's Avatar
Images: 38
Good day Kristine..... Many of us here have Can Am set ups. They have a reputation for getting it right. Andrew T from Can Am is a Forum Member and he has praised the Expeditions on some of his posts ( mostly the newer ones with IRS suspension). If you do a search on Andrew T's posts you may find more info.
You are right, the 27IS is real nice!!!!!
Old 04-23-2014, 02:39 PM   #3
Likes Shiny Tings
MaryC's Avatar
1958 26' Overlander
Portland , Oregon
We tow our 26' Overlander with a 2008 Ford Expedition Limited. (V8, fully loaded with gizmos) Factory installed towing package and using a Prodigy brake sender. So far on several long and short trips, we find the Expedition more than enough vehicle for our needs up and down mountain passes etc. Although our 58 (remodeled interior) is probably much lighter than a new Airstream, we do find that we have far more power than we need... which means just the right amount.
MaryC is offline   Reply With Quote
Old 04-23-2014, 06:23 PM   #4
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I tow your exact trailer with my 2003 Ford Expedition. Use the Equal-i-zer hitch. My 65lb Shorthair Pointer sits in the rear (third row seats folded flat). Wife and I up front and odds and end in second row seat. Tows like a champ!
kscherzi is offline   Reply With Quote
Old 04-23-2014, 07:45 PM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
To make your Ex a super great towing machine, add a Firestone air bag setup on the rear springs, a Transgo Tugger Shift Kit in the tranny and a Mike's 5 Star SCT towing program. Also, if your Ex has a 3.73 rear end ratio, then that's good. If it is a 3.55, then I hope you have a newer EX with the 5 or 6 speed tranny.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-23-2014, 09:29 PM   #6
kscherzi's Avatar
Images: 24
This is my 2013 27FB Airstream attached to my Expedition. As long as you have the 5.4L engine should be no problem towing. Payload on all Expeditions is in the 1,600lb area so no problem with the trailer.
Old 04-24-2014, 07:27 AM   #7
AKristine's Avatar
Many thanks for your comments. I am so pleased to hear about Andy's endorsement of the Expedition. I'm just not comfortable with a 3/4 ton truck which many on the forum seem to feel is the best match for 27 > airstreams.
I appreciate your kindness!
Kristine
Old 04-24-2014, 08:01 AM   #8
andreasduess's Avatar
1984 34' International
Toronto , Ontario
It's not so much about what you tow - you can tow most Airstreams with a modern SUV, van or 1/2 truck - some even with a sedan. It's more about what you choose to carry.
Right now, we're towing our 1984 34' trailer with a Honda Odyssey. It's a stable, safe and economical tow vehicle with a 1400lbs payload. It works because we travel relatively lightly, weekends and holidays rather than full time. I am a huge fan of this set-up.
However, I can see a point in the future, when the kids are older and we'll start carrying bikes and canoes, that we'll be buying a truck to help carry all of that stuff. Part of the plan is also to travel across Canada the year after next, and the Odyssey, as perfect as it is now, would not be the best vehicle for that trip.
Even then, I will be keeping the truck as small as I can, probably a Ford Ecoboost with a 6' bed, to stay as close as possible to the driving characteristics of a car. Independent suspension and a low centre of gravity are good things in a vehicle, whether you're towing or not. Unfortunately the kind of vehicle that can carry a high payload typically comes without these niceties, so there'll always be a compromise.
Your Ford is a nice and capable vehicle, enjoy.
andreasduess is offline   Reply With Quote
Old 04-24-2014, 09:04 AM   #9
AKristine's Avatar
Thank you! Your comments are reassuring and I appreciate your kindness.
All good wishes.
Kristine
Old 04-24-2014, 09:55 AM   #10
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
We tow with a 2003 Expedition 5.4L 4x4, with a P3 and 800lbs Reese Dual Cam setup, and pull a 1998 31' and a 1979 25' Safari. We have not had any issues over the past 6 years. We also have dogs and they enjoy the 2nd row of seats. We only get about 9-10mpg while towing.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 05-07-2014, 09:58 AM   #11
CanoeU70's Avatar
2011 25' FB Flying Cloud
Ocean Springs , Mississippi
2012 Ford Expedition towing 2011 Flying Cloud (25 ft)
As a former loyal Suburban owner (I traded #4, a 2009, when I discovered that they no longer provided fuel filters to prevent the fuel injector system from getting clogged).
The $300 apiece injectors have an "individual internal filter" which is rediculous because to "service" that filter means a new $300 injector...try THAT 8 times!
I now love my Ford Expedition even without 4-wheel drive.
Gosh, the dealer let me take it home un-purchased to see if the transmission could handle backing my trailer into its shaded shed (the 4 suburbans had 7 transmissions). The Expedition worked fine.
However, I just recently discovered that the "HD Towing Package" does not include air boosted rear shocks. That is a separate option; go figure: "HD" for heavy duty and that does NOT include an air boosted rear end leveler?
So I am online today seeking an aftermarket solution. I called my dealer and it's too late to install the air system on my Ford.
The attached photo shows my rig in what NavArchs call a "condition of sag" (the bow and stern riding on 2 wave tops) and this leads to frequent scrapes on entrances with rain inclined pavement.
Name:	AirStream Rig Apr2014.JPG
CanoeU70 is offline   Reply With Quote
Old 05-07-2014, 06:25 PM   #12
AKristine's Avatar
Why is it too late to install rear boosted rear shocks? What do expect that to cost and who will do the installation?
Thanks. Kristine
Old 05-07-2014, 06:35 PM   #13
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
You don't need air shocks to level the truck and trailer, you just need to adjust your hitch setup,
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 05-07-2014, 08:32 PM   #14
Toronto , Ontario
That's what I thought - it looks like the hitch isn't dialed in properly. Hard to see exactly what's the culprit, but I'd start with the WD.
How much tow weight is reasonable for a 2008 Ford Expedition? davidceder Tow Vehicles 8 08-31-2009 08:57 PM
2003 Ford Expedition 5.4L w/ Tow Package savage_here Tow Vehicles 32 07-17-2009 12:54 PM
2008 Ford Expedition towing capacity. jdwdks12345 Tow Vehicles 10 02-16-2009 07:40 AM
Ford Expedition as a TV Relentless Tow Vehicles 22 07-02-2007 02:44 PM
2007 Ford Expedition EL outthere Tow Vehicles 15 04-14-2007 07:56 PM
